Has anyone ever seen a fuel filter failure? - BMW Luxury Touring Community
post #1 of 33 Old Feb 5th, 2010, 5:00 pm Thread Starter
Just wondering....I have the bike apart to replace the shocks. Since its got all those parts off it would be easy to replace the fuel filter, but my questions is, Why? Do they they ever fail?
3444 is offline
post #2 of 33 Old Feb 5th, 2010, 5:06 pm
Palerider's Avatar
Re: Has anyone ever seen a fuel filter failure?
Yes, they can fail.............Yes, it could save you a hassle..........But hey, I'm sort of one of those guys that just thinks fresh maintenance items just make the bike run better.........and I'm also one of those guys that likes to tinker..................$ .02................
Palerider is offline
post #3 of 33 Old Feb 5th, 2010, 5:12 pm
hmmmm90s's Avatar
fuel filter failure on all k-bikes is a frequently observed condition - there's a very good reason your maintenence schedule calls for the filter to be changed out every 24,000 miles.
the failure mode is kinda gnarly, too - if the filter has absorbed enough water or other contaminants from the fuel, it will stop being able to flow enough fuel for the bike to run - first it will lean out at full throttle, then it will stall at idle, and if its serious enough, you will walk wherever you're going.
change the filter. routinely.
g.
greg shamieh boof # 93 k-whiner # 83
jefferson, maryland
2000 K1200LT --- "darkside"
75R90S -- "esssss"
73R75/5 -- "mojo"
hmmmm90s is offline
post #4 of 33 Old Feb 5th, 2010, 5:19 pm
seahabit's Avatar
Your fuel filter is a throw away item. It collects any sediment in the fuel. If you never change it, eventually it will plug up and starve your engine of fuel. A fuel filter failure would be more like it not filtering the contaminants out, and letting any debris continue into the engine.
You are right. You're there, so you should change it and anything else, like maybe the air filter
seahabit is offline
post #5 of 33 Old Feb 5th, 2010, 5:55 pm
SilverBuffalo's Avatar
It could happen, I had one fail (not on a K12LT)
back in 1996 my fuel filter split on a brand new (under 500 miles)
K1100LT Those filters are a lot easier to get at.
I think it's a good idea to go ahead and change it while you're right there,
but I don't agree with the two previous poster that it's a frequent or certain item to fail,
I personally know of several bikes that went 60 and 80 thousand miles without fuel filter changes.
With no problems.
So you might ask yourself (with my best Dirty Harry voice)
do you feel lucky,....well do ya ....
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #6 of 33 Old Feb 5th, 2010, 6:01 pm
atrovarious's Avatar
I drive around with my head in the tank hoping to see exactly this!
Ghaison (Jason)
2004 K1200LT FOR SALE!!!
Bluefield, VA
atrovarious is offline
post #7 of 33 Old Feb 5th, 2010, 6:02 pm
What I'm confused about is why are beemers different from bimmers?? My riding buddy(K12lt and now a R12rt) is an independent foreign car mechanic(mostly BMW, Mercedes, Porsche) told me he can't remember the last time a car came in with fuel filter problems. His theory is the filtering at the pump and careful handling during transport result in a cleaner product in your tank.
FYI my '67 Cessna with 39 gallons on each side has only a coarse fuel screen in the carburetor and a sediment bowl at the lowest point of the fuel system. Pre-flight is a matter of draining a bit of fuel to double check for water (most common if old,leaky, fuel caps and the aircraft has been sitting outside in the rain). I don't know about the newer fuel injected Cessna's, may be lacking a fuel filter also.
Bruce,
beartooth is offline
post #8 of 33 Old Feb 5th, 2010, 7:17 pm
LAF
LAF's Avatar
I belive it is called for every 12,000.
I will do it every 24,000 I think. It was not bad at all on the 12,000 and I wanted to replace the inside outside clamps and install QD's at the same time.
I ran gas, swirled, tapped both ends over fresh white shop towels and very little to see even with a jewlers glass.
Guess just luck on my gas choices. Never fill up where a truck is dumping gas, or in pouring rain, unless you can't help it of course.
And the rain is not so much an issue in large, newly built Sheetz and such. Older stations filler caps are not the most water tight things, and a lot of times the fills are sunk with no drainage, bad news in a rain storm.
Air filter was clean also. I used a K&N and will clean and reoil every 24,000 with the fuel filter.
It is also a good time for washing and cleaning and inspecting things you dont get to see very often. Well, hopefully
Lee
17.5 R1200 GSW Black Low
ATGATT I am breathing proof.
BMW MOA #135959
LAF is offline
post #9 of 33 Old Feb 5th, 2010, 7:58 pm
It's cheap enough and easy enough since you've already got all the bits off I'd just change it out for insurance.
Do replace the two clamps though, as if one of those slips off under pressure the bike won't run, even with a full tank. BTDT, less than 10 miles after a service (where I though the old clamps were "good enough"), had to call my buddy to bring his trailer . . .
BTW, the newer Slant/4 Beemers don't have a separate fuel filter, just an inlet screen.
post #10 of 33 Old Feb 5th, 2010, 8:51 pm
Bruce,
FWIW My Lincoln MK VIII would not start one day and I traced it to a clogged fuel filter. It took a while to find the issue because "they never go bad". Now I have a fuel pressure guage.
post #11 of 33 Old Feb 5th, 2010, 9:11 pm
K&N Filters hmmmmmm???
Check this link
Don't be fooled by the hype over efficiency.
You are sacrificing the filtering ability of a filter to get sound,
not worth it in my mind.
08 K1200GT
08 F800S
00 K1200LT
Rickmick is offline
post #12 of 33 Old Feb 6th, 2010, 12:59 am
Check this link
Well I don't doubt that more air in means more dust in.... nevertheless more air is in....the same air I breath.......
Secondly I'm interested to see if the added flow in will match up with the added flow out made possible by my Remus exhaust.....
Ghaison (Jason)
Bluefield, VA
post #13 of 33 Old Feb 6th, 2010, 9:50 am
[QUOTE=atrovarious]Well I don't doubt that more air in means more dust in.... nevertheless more air is in....the same air I breath.......QUOTE]
Point is not the volume of air "in" but the amount of "chit" going beyond
the filtering abilities of the K&N filter itself....next stop your internal components
of your engine. I know there are alot of advocates of these filters, but the question
I have is....When do u know that it is not being effective in its function?
Much like a fuel or water filter, what is the indicator that alerts u that,
particulates, bacteria, etc. are now passing through.
Over time these do in fact add up to significant amounts that may or may not
affect your engines efficiency, wear, performance, life span, etc. But I am betting
it does no good to have it pass through.
I guess I just don't get it, for the meager HP increase on bike with 152HP already
I find it easier to just huck out the old paper one and replace it on a regular basis.
08 K1200GT
08 F800S
00 K1200LT
Rickmick is offline
post #14 of 33 Old Feb 6th, 2010, 9:50 am
LAF
LAF's Avatar
Not going to debate a K&N but use them in every car, truck, bike I have owned over the last 15 years with no issues. They are made to work better as the oil attracts dirt, period. And in the LT it is work to get it in and it seals VERY tight. Tighter seal then OEM for sure.
No worries on the K&N.
If you don't know when the fuel filter was changed last, then I would change it and the internal and external clamps as I said. There are two sizes and Beemer Bone Yard can fix you up on both sizes in fuel injection clamps. After that 24,000 would do IMHO.
Lee
BMW MOA #135959
LAF is offline
post #15 of 33 Old Feb 6th, 2010, 10:07 am
RonKMiller's Avatar
Check this link
I completely clogged BOTH K&N air filters in my Mercedes with sand and dust several years ago while driving through a nasty sandstorm at the California border. There was no place to hide and pulling off and waiting it out was not an option since it continued all day long due to a persistent pressure gradient including 60 mph gusts. It did $10K in cosmetic damage to the exterior - really trashed it.
Here's the stuff the K&N's kept OUT of the engine - the other side of the air box was as clean as a whistle.
Needless to say, I'm a fan of oiled air filters... especially in dusty environments.
Name:	Moo and Mercedes Wheels 108.jpg
ID:	26149   Click image for larger version
Name:	Moo and Mercedes Wheels 112.jpg
"Like Butt-ahh!"
RonKMiller is offline
post #16 of 33 Old Feb 6th, 2010, 10:36 am
LAF
LAF's Avatar
Utt Ohh, real world experience with documented proof versus a "written article". Uhh must be a placebo effect
Lee
BMW MOA #135959
LAF is offline
post #17 of 33 Old Feb 6th, 2010, 12:00 pm
Likewise.... never put one on a bike yet but that's because I don't remember ever changing an air filter on a bike.... not that I haven't .... just don't remember it.
Ghaison (Jason)
Bluefield, VA
post #18 of 33 Old Feb 6th, 2010, 12:37 pm
wa1200lt's Avatar
Took our son to freshman year of college in Denver, CO in our 36' flat nose motorhome. Coming home it "missed" a couple times going up the continental divide. Nothing really serious but it was noticeable. No issues until I got 5 miles from Mountain Home, ID where with a headwind top speed had been reduced to 20 mph. This was a 460 Ford which didn't slow down for much. Pulled off the freeway and parked against the shady side of the WalMart store, dropped the electric levelers on the left side to jack it up and installed my emergency replacement filter. Took less than 10 minutes. Could not blow through filter it was so tightly plugged.
Now, the motorhome had nearly 30,000 miles at the time and at 5mpg average it had consumed nearly 6000 gallons of fuel which would be the equivalent of 270,000 LT miles at 45mpg.
That's a lot of miles before failure. Not saying it shouldn't be changed.
WAK1200LT
Loren
wa1200lt is offline
post #19 of 33 Old Feb 6th, 2010, 2:06 pm
Documented proof of what? that it worked for a day in a sandstorm, thats excellent
if you drive in sandstorms, why u would I do not know, what if it didnt work?
Anyway "written article" is a result of testing multiple filters, not sure how else
results could be published.
"Placebo effect" not sure what that means in relation to this?
Point being K&N performed well for this motorhome, on that day, so thats
excellent.
Never seen K&N publish any info on how there product is superior to a quality
paper filter.
Having seen far to many filthy K&N and other branded oiled filters in engines
because owners figure they are bullet proof long lasting wonder filters,
I personally am not a fan.
BTW "written article" is a non-biased test based on facts.
08 K1200GT
08 F800S
00 K1200LT
Rickmick is offline
post #20 of 33 Old Feb 6th, 2010, 2:48 pm
excellent.
You must read "written article's" like you do posts .... he was talking about a fuel filter .... the title of the thread.... oh you might have missed that as well
I'm just funnin' witcha .... but you asked for it too
I again will say that, and I'm not alone in that with more air there will likely be more dust.... however we breath unfiltered air and last longer than any motor I've ever owned....
If you want anecdotal evidence of performance and durability in an overpriced item.... I think K&N is a poster child.....
I still love you though and you are invited to my Superbowl party!
Ghaison (Jason)
Bluefield, VA
post #21 of 33 Old Feb 6th, 2010, 4:28 pm
Actually we do have a sort of "oiled" filter in our sinuses and Trachea that collect alot of that dust before it gets to our "internal " delicate parts (Alveoli). Unless you happen to work in a coal mine in the 40's. But we don't have a fuel filter...
post #22 of 33 Old Feb 6th, 2010, 7:25 pm
LAF
LAF's Avatar
excellent.
paper filter.
Hey guy use what you like.
Placebo is a reference from another debate, on another product, in a Galaxy far away.
Do you have any clue to all of the dirt running machines that use oiled air filters?
What you have seen is some ass wipe that is too lazy or stupid to take care of a filter and assume all do that, and that is how we all take care of them? I mean I been using the 2.5" diameter by 14" Cone on my intake on my Turbo for 7 years and my car does just fine at 21 Lbs. of boost.
I also have read and re read the Oil study that Amsoil publishes and believe it is a pretty unbiased study. I still run plain old Dino Castrol GTX.
You can believe everything you read, or believe everything you have tried over extended periods of time and know works.
Guess you never flipped a round ring, paper air cleaner cover over inverted on a motor, and had fun as a kid. Never killed anything I drove then, but a 350 sounded good as hell that way. Then I found oiled filters on my dirt bikes, and then K&N specific OEM specific, and have used them over 20 years now that I think about it. My 89 Tacoma had one in it and at 79,000 miles it was still fine when I sold it.
Your bike your money spend it how you like.
But don't just throw a article out in front of yourself and say it is so.
If you used one and blew a motor because of it let us know. If you know of a incident of where it has happened please post a link.
Now OP replace the fuel filter every 24,000 and make sure you replace all clamps the first time you do it.
Lee
BMW MOA #135959
LAF is offline
post #23 of 33 Old Feb 6th, 2010, 8:28 pm
shoswell's Avatar
That was a tank your head was in...oooooohhhhhhhhh
p.s.- ain't dry humor great!!!
Hoss
'05- K1200LT - Gretchen
MOA, IBA, EXR & RCB and TMI
shoswell is offline
post #24 of 33 Old Feb 6th, 2010, 10:08 pm
BURRRRN! Well played!
Ghaison (Jason)
Bluefield, VA
post #25 of 33 Old Feb 6th, 2010, 11:12 pm
Laf
I am sorry if somehow I have offended you with my opinion on air filters, apparently "your"
opinion carries more weight.
Having driven and flown hundreds of different motorized pieces of equipment as a
heavy equipment operator and pilot, I am not" just throwing it out there". I too use
oiled filters in my dirt machines, and it is not about blowing up motors, its about
what people perceive as better quality for the task at hand.
As far as substantuating, can't really because I never tested a vehicle with and without
a K&N to see what lasted longer. Have you? So before you get so high and mighty about your vast knowledge, why don't you prove somehow that they are superior.
Remember opinions are like assholes, everyones got one.
08 K1200GT
08 F800S
00 K1200LT
Rickmick is offline
post #26 of 33 Old Feb 7th, 2010, 12:14 am
Re: Laf
I don't think you offended anyone anymore than I believe that you are indeed sorry LOL
Seriously though, there are pro's and con's to any purchase.... and everyone has reasons for making certain decisions.... and some feel more strongly than others about those decisions and then there are those of us that don't take ourselves too seriously and are entertained by those who do.....
Ghaison (Jason)
Bluefield, VA
post #27 of 33 Old Feb 7th, 2010, 12:21 am
Re: Laf
[QUOTE=atrovarious]I don't think you offended anyone anymore than I believe that you are indeed sorry LOL
Seriously though, there are pro's and con's to any purchase.... and everyone has reasons for making certain decisions.... and some feel more strongly than others about those decisions and then there are those of us that don't take ourselves too seriously and are entertained by those who do.....[/QUOTE
Very true
BTW whats a SuperBowl?
Indy by 12
08 K1200GT
08 F800S
00 K1200LT
Rickmick is offline
post #28 of 33 Old Feb 7th, 2010, 7:37 am
haughty's Avatar
ITs the AMerican Stanley CUP only played on turf........
We also have- sometimes , not as frequently.. brawls (not enough at times like in wrestling- you know the Jerry Springer type)..
Lots ot going back and forth.. NO icing tho, usually called incomplete pass..
We have beer..
and the trophy isnt as big as the CUP..
ALSO a superbowl IS a big bowl of doritos and salsa/beandip/ cheese dip... guacamole...Any high calorie intake..........
Beer is a FOOD group.. Veggies so ya dont have ta eat them carrots and celery sticks
Don't be afraid to say what you feel, as those that matter DOnt mind and those that mind Dont matter.
Dr.Suess-
1980 YAMAHA XJ650 MAXIM (RIP)
1982 YAMAHA 750 VIRAGO (SHES GONE)
1982 SUZUKI GS1000 (GONE)
2001 BMW K1200LT
2004 BMW R 1150 RT Sold.....
2007 BMW R 1200 GS
1986 BMW K100RT WITH A FLEXIT SIDECAR
1985 BMW K100 RT ( parts bike, but its too nice to do that, so it runs)
haughty is offline
post #29 of 33 Old Feb 7th, 2010, 8:51 am
LAF
LAF's Avatar
Re: Laf
No worries dude, use what you want your bike and money.
Again I have used them for too many years to worry about it, have you?
My point is you post an article that says it is so, so it must be? Hmmm Pluto was a planet, but not now. I can post a article to support any view or opinion I have, don't make it so.
It is a oil/tire/spark plug/oil filter debate that can not be won. It is personal preference.
While I liked to be informed I don't like a "sky is falling" type of hype where an article is posted not in one post, but in another by someone who is just trying to save others money. I know your intentions are well intended but an article is not proof. And while the artical may be technically correct, does it even matter in real word?
Again I don't care if you run one or not. I, like others have seen they work and have no adverse affects that have hurt the motors they are run on. Your experience may be different and I would like to hear those experiences.
Ron shared a picture of what it stopped. My Father/Brother/Uncles and a bunch of others have run them for years. If there was an issue I would think we would have needed to have the injectors/float bowels of our vehicles cleaned a bunch from the dirt swirling with the air in the mixture. Never a injector/carburetor problem in 20 years or so.
No worries on opinions, I just put more faith in those formed by experience rather then a article.
Use one in something for 10 years then let me know.
Lee
BMW MOA #135959
LAF is offline
post #30 of 33 Old Feb 7th, 2010, 9:11 am
Lee
Good point, I should try em before I knock em, and I apologize for being harsh(bad day)
I guess what I should have said is I don't care for the results of the study showing
the difference in filtering qualities. But as you and others have mentioned, all appears
to be well with your engines, so the proof is there.
Just over analyzing stats again (winter blues)
Still going with Indy by 12
08 K1200GT
08 F800S
00 K1200LT
Rickmick is offline
post #31 of 33 Old Feb 7th, 2010, 9:56 am
LAF
LAF's Avatar
Re: Lee
No worries dude as you said opinions and such
At least you (we) did not start, or participate in an oil thread
We had 20" of snow yesterday to dig out so I also understand Winter Blues, or at least my back does this morning
Again we agree to disagree and that is cool, and for sure would love to spin some tires up in your neck of the woods.
Lee
BMW MOA #135959
LAF is offline
post #32 of 33 Old Feb 7th, 2010, 2:29 pm
Colts by 10... Football it's like hockey with real athletes JK actually pro hockey is fine by me... baseball is the sport I despise I would rather watch grass grow!
Ghaison (Jason)
Bluefield, VA
post #33 of 33 Old Feb 7th, 2010, 2:36 pm
Just like golf, bowling, baseball is a particpant sport, otherwise
08 K1200GT
08 F800S
00 K1200LT
Rickmick is offline
Alternate Fuel Filter saddleman K1200LT 8 Aug 23rd, 2009 7:26 pm
Fuel Injector cleaning-on the bike PhillWard Australia, New Zealand, and AsiaPac 4 Nov 28th, 2008 1:02 pm
Fuel Filter outside the fuel tank strsout Bike Talk 4 Aug 2nd, 2007 6:45 am
Fuel filter replacement...Necessary? BLBantz K1200LT 20 Feb 19th, 2007 9:50 am
