Antennae Replacement - BMW Luxury Touring Community
post #1 of 9 Old Feb 1st, 2010, 9:43 pm Thread Starter
AlReich23's Avatar
Now that I've replaced the top trunk with a rear rack, I'd like to replace the whip anntenae with something shorter. Anyone with a suggestions?
Thanks.
- Al 2004 LT (Black)
AlReich23 is offline
post #2 of 9 Old Feb 1st, 2010, 10:05 pm
Re: Antennae Replacement
I just took mine off as I don't listen to the radio anyway. I haven't taken off the mount as of yet and it does still pick-up local stations. A little searching on this site will turn up some who have installed hidden antennas.
_____________
Kim Thomson
Motorcycle Cigar Smoker
85 K100 Standard - Big Red
Gone, but not forgotten...
85 K100RT - (wore out)
alabrew is offline
post #3 of 9 Old Feb 1st, 2010, 11:12 pm
shoswell's Avatar
Well, not sure what type antenna you have (they have two OEM models) But I reworked mine and saw a little less performance for my troubles. Removed the OEM shaft, went to Pick-n-pull and got a GM standard antenna for $2.00 took it home and chopped off the end to my liking. I did it to match my FRS antenna mounted inplace of the CB antenna.
or find it...
http://s619.photobucket.com/albums/t...0LT/?start=all
Hoss
'05- K1200LT - Gretchen
MOA, IBA, EXR & RCB and TMI
shoswell is offline
post #4 of 9 Old Feb 2nd, 2010, 4:45 pm Thread Starter
AlReich23's Avatar
or find it...
You've got a beautiful bike, brother.
You have me thinking, could I cut off 18 inches without significant loss of signal?
post #5 of 9 Old Feb 2nd, 2010, 8:14 pm
shoswell's Avatar
YMMV- I'd suggest you not cut the OEM as it may or may not work... Get a spare or alternate....
Hoss
shoswell is offline
post #6 of 9 Old Feb 2nd, 2010, 9:58 pm
IIRC, Barbara sported a short stubby antenna in her past life. I think Grif got it at Radio Shack. Don't know if it worked well or not, butt he wuz pleased, I think.
post #7 of 9 Old Feb 2nd, 2010, 10:50 pm
shoswell's Avatar
It has the same RS one when I got her. I lucked into the OEM one. Still the reception is crappy comparatively..
Hoss
shoswell is offline
post #8 of 9 Old Feb 3rd, 2010, 1:59 pm
jaskjb's Avatar
here is a picture of my antenna from Crutchfield.
I used the original antenna bracket and added a small bracket to it to hold the antenna.
The reception is good, probably less static than I was getting with the original LT antenna
Hope the picture helps, if not I can take more.
http://www.bmwlt.com/forums/attachme...chmentid=20387
Jim G - Rochester, MN
BMW MOA #123976
2000 K1200LTC
jaskjb is offline
post #9 of 9 Old Feb 3rd, 2010, 5:23 pm Thread Starter
AlReich23's Avatar
This is the look I'm going for.. Thanks.
O2 Sensor Replacement - Placebo Effect (and another interesting fact)? hallzee K1200LT 13 Jan 24th, 2010 11:32 am
07 radio with Com to 05 w/o for replacement nearmisses Other Stuff 3 Jun 20th, 2008 6:48 pm
HID Replacement Bulb sorchilla K1200LT 4 Mar 26th, 2008 8:15 pm
HID replacement high beam? TonyS Lighting 8 Jul 1st, 2006 11:49 am
CB Antennae JohnR K1200LT 3 Jan 30th, 2006 4:42 pm
