Relocating Nav III on to shelf - BMW Luxury Touring Community
post #1 of 7 Old Jan 28th, 2010, 11:59 pm Thread Starter
SoberBiker's Avatar
Hey all, I put this request on the GPS thread and got one reply but it just didn't seem like that would solve my problem. I have an '08 Lt and the Nav III was mounted on the stingray. I know some of y'all have moved them up to the BMR shelf, which is what I am trying to do. My problem is that the cabling doesn't quite reach that far. How did you resolve the short cabling? If there is a extension I could buy, that would be the way I would prefer to go cause I an not that proficient in soldering...especially with wires that tiny. The cable I have is the stock "short" cable that BMW installs for the stingray mount (See attached) I need it extended approximately 6". Can anyone suggest how I can accomplish that?
Name:	Nav III Wire.jpg
Regards,
Woody aka SoberBiker
I know that you believe you understand what you think I said...
But I'm not sure you realize that what you heard is not what I meant
~Author Unknown~
'18 K1600 BGA (Yet to be named)
'16 Goldwing F6B (Traded)
'08 K1200LT - (Traded)
'07 K1200GT - (Sold)
SoberBiker is offline
post #2 of 7 Old Jan 29th, 2010, 8:15 am
mwnahas's Avatar
Re: Relocating Nav III on to shelf
You're looking for something like this if not this.
http://www.amazon.com/Garmin-Motorcy.../dp/B0000ESZV4
This is the one I got for the garmin 2820.
http://www.gpscity.com/garmin-street...and-cable.html
Just Go
Cleveland Ohio
mwnahas is offline
post #3 of 7 Old Jan 29th, 2010, 10:28 am
atrovarious's Avatar
This is also what I was going to suggest. I believe these wires are designed to run to the battery or a power distribution block and then you are still able to pipe the audio into your radio via an aux input.
Ghaison (Jason)
2004 K1200LT FOR SALE!!!
Bluefield, VA
atrovarious is offline
post #4 of 7 Old Jan 29th, 2010, 12:32 pm
jhsonderb's Avatar
I don't think the above solutions will fully solve your problem if you intend to use the BMW Cradle (with the buttons) with your NAV III (unless you want to forgo the use of the button functionality). You will still need to extend the round connector.
Jim S.
'07 SturmGrau K1200LT
jhsonderb is offline
post #5 of 7 Old Jan 29th, 2010, 12:46 pm Thread Starter
SoberBiker's Avatar
That's been my feeling all along. I have been concerned about plug & play functionality.
I have called about anyone that could possibly give me an answer and no one seems to have a positive answer. I am guessing that I am going to have to try cutting the wires and extending them and crossing my fingers that this will work.
I have been told by TVNav that BMW doesn't even make the cables that I presently have to hook-up the Nav III on the stingray any longer. So if it doesn't work I'll have to beg one from someone or go without.
Regards,
~Author Unknown~
post #6 of 7 Old Jan 29th, 2010, 1:08 pm
I'm not familiar with the unit or it's functions. I apologize. I thought the only integration was that of the sound..... However, I don't think you will have any trouble doing as you have described. I had a wiring harness burn up from the headlight to the taillight and every wire in between and I repaired and replaced every single wire on the bike by hand. Took my a whole day but everything now works, so it can be done. Especially off the bike, this should be easy.
Good luck.
Ghaison (Jason)
Bluefield, VA
post #7 of 7 Old Jan 29th, 2010, 1:37 pm
jhsonderb's Avatar
Before cutting the OEM cable, maybe you could find compatible male and female molex plugs from a boneyard bike and/or an old unused NavII/NavIII wiring harness from any BMW (not just an LT) bike that the BMW Navigators could be installed and make your own extension cable(s). Only as a last resort would I consider cutting the original functional OEM cable. I'm not questioning your desire to move the GPS to a shelf but if you do there will be mounting holes to deal with in the stingray if the NavIII was previously mounted there.
Jim S.
Another option for Zumo and TOM TOM ONE Mounting on K1200LT--BMR Shelf petevandyke GPS 5 Dec 14th, 2007 8:12 pm
Factory GPS wiring & BMR shelf sonnata GPS 0 Nov 24th, 2007 1:03 pm
Painting a BMR Co-pilot Shelf HammerStar GPS 3 Dec 5th, 2006 9:43 pm
