Hydraulic center stand repair, I didn't realize it would be so easy! - BMW Luxury Touring Community
post #1 of 13 Old Jan 28th, 2010, 11:29 am Thread Starter
SilverBuffalo's Avatar
My schedule and personal problems haven't allowed me to have any spare time for the last several months,
yesterday I took some time for myself and tackled my hydraulic center stand
which hasn't worked since I got stuck in a wet grass culvert a couple of months ago.
The first thing I did is read Ari's write up and the joegottberg write up.
After that it was time to get my hands dirty.
Probably the hardest part was securing the LT on my lift,
I just wasn't very comfortable with just a couple of straps holding "her" upright.
Once the wrenching began I couldn't believe how simple it was with all the "guidance" from the forum friends.
My problem turned out to be a stuck brush inside the motor (some gunk)
I went ahead and flushed the unit out, cleaned it up and put it back on and she works like new.
It was a lot easier than I thought it would be, except for replacing the center stand spring (ouch)
A big "thank you" to Ari and Joe as well as all of the other contributers.
Do any of y'all know where I can get some replacement brushes?
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #2 of 13 Old Jan 28th, 2010, 11:35 am
JPSpen's Avatar
Re: Hydraulic center stand repair, I didn't realize it would be so easy!
An electric motor repair shop should have brushes.. You do know what size you need don't you ?
That's the rub.. Next time it quits. Take it apart and then go to the motor shop with the old brushes and/or the motor... They should be able to fix you up.
91 R100GS "It'sNotAMoneyPit"
JPSpen is offline
post #3 of 13 Old Jan 28th, 2010, 11:40 am
joegottberg's Avatar
Hey Hans,
Glad to hear it went OK for you. Sounds like you didn't damage your shaft seals and didn't overfill. Great job.
I happen to have the same problem you are experiencing (worn brushes). I am looking at options. I thought the local guy that rebuilt starters/alternators could help, but, looks like that work is no longer performed "locally".
I am actually looking to buy a replacement 12 VDC motor and see if I can go that route. I have some old brushes (from a scrap car started motor) that I was going to "rig", but, thought better of it.
My research is still on going, I rarely use the center stand, since I need it for maintenance and I'm worried how many cycles are left in it.
Someone else may have got lucky, but, if not, I'll let you know if I have success. A motor has got to be cheaper than the entire unit!
Joe
2005 KLT "Old Blue"
Bruno the "Bugg"
joegottberg is offline
post #4 of 13 Old Jan 28th, 2010, 3:50 pm
pozo_izquierdo's Avatar
Hi Hans,
nice to hear you had use for Joe's and my pics.
I have actually fiddled with thses DC-motor brushes with my garage door opener. I learned that if you don't find the correct size from your local electric motor shop you can easily use a fine file and make an oversized brush to fit in the holder. So don't try to find the exact fit, because that can be hard. You can surely find brushes that are larger (and the wire length is correct) you can resize them very easily.
Regards
Hyvinkää, Finland
pozo_izquierdo is offline
post #5 of 13 Old Jan 28th, 2010, 6:37 pm
Many corded drills and woodworking tools (routers, circular saws etc) have brushes. Look for a local Black and Decker shop or one of those old school hardware stores that carry corded power tools.
Very likely you can match the size and length of the brushes from the kick stand to something similar from a circular saw.
good luck
'00 Blue K1200LT
'02 XR650L (sold)
Todd
Minnesota
MNTodd is offline
post #6 of 13 Old Jan 28th, 2010, 7:57 pm
Enjoy The Ride
saddleman's Avatar
Originally Posted by joegottberg
Hey Hans,
Joe
Joe call Phil Camp owner of Phil's Starter & Alternator at 704-435-2934 his shop is in Cherryville NC. Tell him it's for a BMW bike & Dave from Penske Engines recommended him. If he can't help you he will know who can.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #7 of 13 Old Jan 28th, 2010, 10:36 pm
Thanks Dave,
If I can get the whole motor (if it's reasonable $), then everything is new and no worries. I'm not confident I'll get lucky enough.
I'll give him a holler and see what he thinks. Maybe I'll just swing by and show him what I got.
2-B-Continued
2005 KLT "Old Blue"
Bruno the "Bugg"
post #8 of 13 Old Jan 29th, 2010, 11:20 am
A "semi" hijack......Since everyone in the thread is familiar with the Power Center stand, and I am sorta considering a new K1200LT, I'm curious if it is possible to remove the power center stand and replace it with the old mechanical one?
I hardly ever use the center stand and am not interested in the extra weight, hydraulics and motor. If it is an easy conversion, I'd be happy to do a trade if my plans for the new bike occur.
post #9 of 13 Old Jan 29th, 2010, 11:39 am
Hey Dan,
I know there have been a few who have converted the older "non-hydraulic" center stand to the post 05 center stand. Bolt on retrofit. There is no reason to think it can't go the other way. I've even thought to go back since when the unit is busted, you can only use the side stand and for maintenance you need the center stand.
If you do go for the new bike, I'd love to talk about getting your hydraulic one.
You will have the "un-used" button for actuating the stand if you swap back, but, shouldn't cause any problems.
If you use the "cheater handle" to get the bike on it's center stand now, that will also have to be added.
Joe
2005 KLT "Old Blue"
Bruno the "Bugg"
Last edited by joegottberg; Jan 29th, 2010 at 11:40 am. Reason: Additional information
post #10 of 13 Old Jan 31st, 2010, 1:36 pm
Hey Dan,
Joe
I'll let you know if I trade up. ...... Some people have said to use the handle on the left rear storage compartment to lift up the bike on the pre 05 center stand. Seems a little too weak, but if others have done it, it might be stronger than it looks.
post #11 of 13 Old Jan 31st, 2010, 1:38 pm
jwb4207's Avatar
Hey Hans,
Joe
Joe, here's another location you could check out if you go the repair route. THE MOTOR SHOP in Gastonia 704-867-8488. Took the motor to them about 5 month ago they were able to repair, works like new every since. Lot better that buying new. I know they replaced brushes and and something else inside (can't remember what that was)
jwb4207 is offline
post #12 of 13 Old Jan 31st, 2010, 1:40 pm
Well I know "for a fact" you can use it to help right a sleeping LT!
I know on my other bikes that the manual stand is an acquired technique, you don't need to muscle it.
Joe
2005 KLT "Old Blue"
Bruno the "Bugg"
post #13 of 13 Old Jan 31st, 2010, 5:42 pm Thread Starter
Hey Dan'o
Before you seal the deal on the hydraulic center stand swap,
I highly recommend you "give it a try" first!
The weight difference is insignificant and once you get used to
"the button" it will bring a smile to your face every time you use it.
Worth having even if you do have to fix it every 4-5 years!
Hans
St. Petersburg FL
2002 K1200LTE
2005 LT
"Esperanza"
REPORT: Retrofit '01 with a Power Center Stand midwilshire K1200LT 55 May 10th, 2016 11:51 am
Hydraulic Center Stand Rebuild and Flush Procedure joegottberg K1200LT 5 Apr 19th, 2010 9:42 pm
2002 k1200ltc center stand retrofit? rogerK K1200LT 14 Nov 26th, 2008 12:07 am
On Center Stand Made Easy donsobeck K1200LT 8 Mar 30th, 2007 10:31 am
05 Hydraulic Center Stand on Ebay sprdoorman K1200LT 0 Nov 10th, 2005 9:25 pm
