Re: Clutch lever & pull
I think Dick's suggestions are your best bet.
If your surgery doesn't correct your grip, there may be some other mods you could do to increase the mechanical advantage of the lever. Maybe a change in pivot point, etc. There may be a way to increase the slave diameter or similar. All will be experimental and probably be "special".
Of course, a "Cheater" on the end of your clutch lever would help, but, probably look bad.
Let us know how you end up, there are probably others that would prefer an easier pull.
Joe
2005 KLT "Old Blue"
Bruno the "Bugg"
