Re: How much DOT 4 brake fluid needed?
OK but I don't see the need to use a vacuum bleeder when the servo pumps will push out the fluid 10 times faster than you can suck it out. I just put a speed bleeder bag on the nipple and hit the key open the bleeder and squeeze the brake lever. You can pump out a pint in 10 seconds. The trick is keeping up with the flow, that is what makes the funnel so valuable. Hope your "lovely assistant" has x-ray vision since the reservoirs are black plastic and you cannot see the level except through the fill hole.
