Replacing Grips - BMW Luxury Touring Community
post #1 of 31 Old Jan 24th, 2010, 5:32 pm Thread Starter
cccpastorjack's Avatar
Replacing Grips
Noticing that several people have wanted to replace their stock BMW Grips but weren't sure about how to do it and retain the heated feature, I thought I would take a few pics and describe the procedure here. Tony, since your grips literally had a hole worn in them and I had a new set of grips here, I used your bike as a model. It really is not difficult at all. Here goes:
1. VERY CAREFULLY cut the exisitng grip off the heated sleeve. NOTE: This must be done delicately so as not to cut into or through any of the wires in the heating element. (see Pic 1).
2. Pull old grip off the end of the handlebar and clean remaining surface and let dry (see pics 2 & 3).
3. Apply a liberal coat of either grip cement (or contact cement) to the heated element and the INSIDE of the new grip (pic 4).
4. Carefully work the new grip on to heated sleeve BEFORE the glue dries (pic 5). Note: Once the grip is in place and the glue begins to dry it is VERY difficult to move the grip around so make sure you get it all the way onto the bar and in position before your stop pushing.
5. Enjoy your new grips! And yes...the heater still works! (see pic 6)
ID:	26056   Click image for larger version
ID:	26057   Click image for larger version
ID:	26058   Click image for larger version
ID:	26059   Click image for larger version
Jack Homesley
Cornelius, NC USA
Too many others to list...
cccpastorjack is offline
post #2 of 31 Old Jan 24th, 2010, 5:48 pm
sheldan2's Avatar
Smile Re: Replacing Grips
Good job Jack, glad those grips came to good use.
Courage doesn't always roar. Sometimes it is the quiet voice at the end of the day saying " I'll try again tomorrow".
sheldan2 is offline
post #3 of 31 Old Jan 24th, 2010, 6:20 pm
shoswell's Avatar
Re: Replacing Grips
Good info, I replaced mine a year or so back for non-oem (I've got big hands). To prevent me from being stupid I slid a long handle feeler gauge under the grip when I cut the old one off. First cut the top of the grip so you can get it in, then slice away. nice to have a piece of metal under the razor!!
Hoss
'05- K1200LT - Gretchen
MOA, IBA, EXR & RCB and TMI
shoswell is offline
post #4 of 31 Old Jan 24th, 2010, 6:23 pm Thread Starter
Re: Replacing Grips
Now, there ya go! What a great tip! I suppose it would have to be a "thicker" feeler gauge, but what a great safeguard! And Mike...thanks for the grips!!! They look good on Tony's bike.
Jack Homesley
Cornelius, NC USA
post #5 of 31 Old Jan 24th, 2010, 8:25 pm
BlauBeeMr's Avatar
Re: Replacing Grips
Will it be equally as easy to remove the new grips that you glued over the heated sleeve? Just follow the same procedure with the extra long feeler gauge? Just had new OIM ones installed....but this is a great reference to keep in my favorites for future use!
Thanks!
There are two kinds of motorcyclists.....those that ride BMWs....and those that wish they did!
Later,
BlauBeeMr
1999 Basalt Grau K1200LT
2004 Desert Tan M2A3 (Jul 2005 - Apr 2008)
BlauBeeMr is offline
post #6 of 31 Old Jan 24th, 2010, 9:13 pm
Re: Replacing Grips
I take it then that the OEM grip is not glued on and is just a friction fit. I would think with adhesive it would not be possible to use a feeler gauge as a cutting guard, right?
post #7 of 31 Old Jan 24th, 2010, 9:15 pm
Re: Replacing Grips
Is the notch shown in picture 3 there by design or is that just wear on the heating element?
Was the new grip a BMW replacement or an aftermarket item?
Nice work and picture documentary!
post #8 of 31 Old Jan 24th, 2010, 10:05 pm
Gino's Avatar
Re: Replacing Grips
Having just recently replaced mine, that notch is where the wire connects to the heater element and "folds back" into the bar end, IIRC.
I replaced mine with OEM rubber grips, and they are not simply friction fit. They WILL slip with just the slightest bit of moisture (easy to get when the heat is applied), so some grip glue is required. The OEM grips are, however, friction fit (as well as tapered with barbs, IIRC) on the plastic carrier that's used if you have NON heated grips. That carrier needs to be removed when installing the OEM grips onto a heated setup.
I wasn't happy with the overall diameter of the grip, so I made them bigger by installing TWO grip puppies over each grip - pretty comfortable and a cheap way to make the grips bigger.
Gino
Modesto, CA
'02 Silver
For they passed a noble law,
Gino is offline
post #9 of 31 Old Jan 24th, 2010, 10:27 pm Thread Starter
Re: Replacing Grips
I think the "notch" you are speaking of was a result of the previous grips being worn intirely out to the place that the wire was actually exposed. I rode the bike recently after repairs and had no gloves. I turned the grip[ warmers on and noticed a VERY hot spot. looked down and there is was...an exposed wire...almost burnt me! That's when I decided to replace the grips. Rather than try to bend it back straight, I just left it alone since it wasn't broken. I feared that trying to straighten it, might cause it to break.
Jack Homesley
Cornelius, NC USA
post #10 of 31 Old Jan 24th, 2010, 10:30 pm Thread Starter
Re: Replacing Grips
Thanks!
They may be a bit more difficult to remove, but not really that tough. I have never tried the feeler gauge method anyway. I am just REALLY careful when I'm cutting and use a new blade. It just cuts right thru it. Once you get it going, you can grab one side of the cut and pull it upward (which lifts the grip off the element) and you can cut the grip w no fear of damaging the elements.
Jack Homesley
Cornelius, NC USA
post #11 of 31 Old Jan 24th, 2010, 10:40 pm Thread Starter
Re: Replacing Grips
Here is a clearer pic of the two areas of discussion with some notes:
Name:	Grip diagram.jpg
Jack Homesley
Cornelius, NC USA
post #12 of 31 Old Jan 25th, 2010, 9:50 am
Re: Replacing Grips
Where did you purchase the grips and do you have the part numbers? Thanks
BEhrler is offline
post #13 of 31 Old Jan 25th, 2010, 10:12 am Thread Starter
Re: Replacing Grips
Mike St. Just purchased the grips...not sure where he got them, but they are "Motoboss Custom Foam Grips". This number was on the package M05-0145 They were 14.99
Jack Homesley
Cornelius, NC USA
post #14 of 31 Old Jan 25th, 2010, 6:04 pm
shoswell's Avatar
Re: Replacing Grips
IIRC- Cyclegear
Hoss
shoswell is offline
post #15 of 31 Old Jan 25th, 2010, 7:31 pm
RVB1019's Avatar
Re: Replacing Grips
I swapped my rubber grips for the Kuryakyn grips using the method posted here by DShealy and Silver Buffalo.
I wonder if this would work on the GT or the RT as well?
Rob V.B.
2015 Triumph Explorer 1200
2007 BMW GT (SOLD)
2003 BMW LT (SOLD)
RVB1019 is offline
post #16 of 31 Old Jan 25th, 2010, 11:24 pm
Re: Replacing Grips
What was the diameter of the replacements?
post #17 of 31 Old Jan 26th, 2010, 9:00 pm
Raymarks's Avatar
Re: Replacing Grips
I thought the stock grips were too small. I have large hands too. I went to the local Hog-Dog shop and picked up a set of Drag Specialties Sundance replacement foam grips. One grip has a plastic sleeve inside of it. I pulled out the sleeve and put a little dish soap on the inside of the foam grips and slid them over the stock grips. It made the grips thicker and reduced the vibration I felt from the stock grips. If they ever wear out I'll just cut them off and install new ones and the stock grips will never see any wear. Over 70k miles and they show no sign of wear yet. The heat comes through fine in low or high position. The part number is DS-243125. I like the look of the grip too.
Ray Marks
The only safe intersection is the one you just passed.
2002 LTE My Blue Mistress
Raymarks is offline
post #18 of 31 Old Jan 27th, 2010, 9:07 am
BlauBeeMr's Avatar
Re: Replacing Grips....the "cheap"way
Here's an inexpensive (er..."cheap") solution using something you probably have laying around unused in a kitchen cabinet or somewhere in the garage.
Ingredients: two neoprene "Koozies", 16" of male/female velcro, the wife's sewing machine (when she's not looking or at home....mine caught me! and the willingness to say you used a sewing machine!
One day after a ride I noticed a slight numbness in my hand and thought it would be nice to wrap the brand new OEM grips (old ones were worn and replaced by the dealer) with something that would soften the vibration and increase the diameter of the handlebars. I rolled into the garage and....there on my workbench sat two "koozies" completely unused (the fridge isn't too far and the amber beverages never last long enough to get warm)!
I decided to cut the bottom of each koozie off and cut the seam on one side to create a 4.5" long piece. I decided it would be easier to beg forgiveness than to ask ahead of time to use der frau's sewing machine ....read the instructions and read them again 'cause I didn't want to break something. I then cut two lengths of velcro (male and female) for each wrap and began sewing. Ok....I know it isn't "manly," but I was on a roll! I did make a few mistakes (didn't realize there was a reverse button on the machine...missed that in the instruction reading! ) and had to start over. Eventually, after about 20 minutes, I completed the modification of the koozies to something I could easily put on or remove. Below are the pictures of the two pieces with the labels of how to connect them.
A & B = female velcro piece sewn onto the black side (which will be the exposed side)
C & D = male velcro piece sewn onto the colored side (which will wind up being the inside)
Wrap A to C (you need to measure this before sewing) and then D to B.
The end products are shown in the last two pictures.
Final preparation: take wife out to dinner with the money you save after putting up her sewing machine!
Later!
ID:	26076   Click image for larger version
ID:	26077   Click image for larger version
ID:	26078   Click image for larger version
Later,
BlauBeeMr
post #19 of 31 Old Jan 27th, 2010, 7:56 pm
That is a neat idea, but given that I paid only $8 for m Grip Puppies, and that included shipping, even 20 minutes of time isn't all that good of a deal.
At least I'm not quite THAT cheap, and I'm pretty cheap!
post #20 of 31 Old Jan 27th, 2010, 10:13 pm
Later!
I saw these.. they looked good! effective.. and you can add/remove to fit your hand or for a "change of pace" on long rides...
good idea.
post #21 of 31 Old Jan 27th, 2010, 11:01 pm
Razmataz's Avatar
+1 here too. Especially the last line...
BMW 1200 LTC 2002
Razmataz is offline
post #22 of 31 Old Jan 27th, 2010, 11:41 pm
BlauBeeMr's Avatar
Re: Replacing Grips
Dang....only 8 clams.....now I find out! Oh well, I learned on both accounts!
Later,
BlauBeeMr
post #23 of 31 Old Feb 1st, 2010, 2:16 am
JCarver's Avatar
Re: Replacing Grips
Jack:
I have a somewhat different problem with my right grip, mainly the heater. When I first turn them on both warm up rather quickly. But as time goes by, the right seems to loose its warmth, meaning it is not heating as much as the left side. Any clue on what could be causing this?
tia, tcars
John Carver
K1200LTC, AMA, BMWMOA
Greensboro, GA
JCarver is offline
post #24 of 31 Old Feb 1st, 2010, 8:11 pm
Human Behaviour Analyst
Installed Grip Puppies and can't get the throttle side to stop slipping when I attempt to accelerate. To fix it I have gone so far as to tighten it on with 5 zip ties ... UGLY!!
Suggestions ??
Keir
wkclark is offline
post #25 of 31 Old Feb 1st, 2010, 10:58 pm Thread Starter
Re: Replacing Grips
Originally Posted by JCarver
Jack:
tia, tcars
Nope. But, I did notice that if I removed either hand from the grip (to change radio, scratch an itch, etc) that particular hand would take a while to heat back up. The cool air seemed to cool the grip and hand taking it a while to recover. Try and notice if that is the case.
Jack Homesley
Cornelius, NC USA
post #26 of 31 Old Feb 1st, 2010, 11:00 pm Thread Starter
Suggestions ??
Keir
I have never had that problem. Now...they do sell two sizes and I have always installed the smaller diameter ones. I usually use an air compressor hose to get them on and they hold really great! Check and see what size you ordered.
Jack Homesley
Cornelius, NC USA
post #27 of 31 Old Feb 2nd, 2010, 1:47 am
JCarver's Avatar
Re: Replacing Grips
Jack:
No, this is when the hand has been on it for say 30 minutes, never taken off, it does not warm as much as the left side. Now there have been times when I have switched them off, then back on and it would heat up again, but still not as hot as the left. The only time it is as hot as the left is when they are first switched on, like in the first 5-10 minutes.
tia, tcars
John Carver
Greensboro, GA
JCarver is offline
post #28 of 31 Old Feb 2nd, 2010, 2:01 am
shoswell's Avatar
Re: Replacing Grips
Just becasue I am a Smart A$$....
Can the mods start a new section for us? I think the heading
"ASK PASTORJACK"
Has a very nice ring to it....
Hoss
shoswell is offline
post #29 of 31 Old Apr 4th, 2010, 12:50 pm
Seagull's Avatar
Re: Replacing Grips
Does anyone happen to know what size the replacement grips should be?
2002 K1200LT SE
Seagull is offline
post #30 of 31 Old Apr 4th, 2010, 1:33 pm
RocketRon's Avatar
Re: Replacing Grips
Pastor Jack...
My grip warmers blow the fuse.....but not instantly. They'll heat up for one ride....maybe two. Then the next time I try them, they won't work...I check the fuse and it's blown. Can you, or anyone else, suggest a place to start looking for the problem? Should I assume it's under the grips and cut them off to see what I find?
Thanks!
Ron
Rocket Ron
2002 LT
2005 Triumph Rocket
2002 Honda VTX1800R (gone)
RocketRon is offline
post #31 of 31 Old Jun 13th, 2010, 10:18 am
Re: Replacing Grips
What size Grips did you use (1"). Also how is the heating working?
JanP is offline
Hand Grips tonyn1 K1200LT 31 Aug 21st, 2009 5:45 pm
Replacement grips WAL Bike Talk 9 Jun 8th, 2009 8:13 pm
Replacing electric hand grips CaptainTom K1200LT 14 Aug 23rd, 2008 6:24 pm
Adding heated grips to an LTC Holy Cow K1200LT 9 Jul 23rd, 2008 10:08 pm
gel grips roadcrave Other R-Bike Discussion 0 Jan 14th, 2007 8:04 pm
