'05 LT ABS Module needed - BMW Luxury Touring Community
post #1 of 12 Old Jan 24th, 2010, 1:09 pm Thread Starter
pb4ugo's Avatar
Fault lights indicated I had an intermittent problem with the braking system. If I don't grab a hand full of front brake the system works fine. Hard braking (front) results in residual braking effect.
After determining the front & rear master cylinders were full, I figured the front simply needed a rebuild kit. The parts guy at my local dealership convinced me that the system is much more complex than I may realize so I took the bike on down and asked them to run a diagnostic test. Long story short: My ABS module has to be replaced at a cost of $2468.00 plus labor.
There's gotta be a junker/clunker out there somewhere that can be parted out. Anybody have an alternate fix? Anybody...
C'est la Vie
pb4ugo is offline
post #2 of 12 Old Jan 24th, 2010, 1:38 pm
Re: '05 LT ABS Module needed
There are some places out there that claim they can rebuild the ABS modules. Somewhere I have the phone number of one of them. I will try to find it and give you a pm later.
jrlakin is offline
post #3 of 12 Old Jan 24th, 2010, 5:56 pm
I had a problem with the warning lights on the brake system coming on every time I crossed a cattle guard or such bump. I would have to stop and turn off the engine to reset. Had in serviced at Accolade BMW in SLC and the technician, found that one of the ties on the break line bundle was too tight, he took the ties off and rerouted the line, it works fine now. You may want to look at the way the break bundle is routed.
walkingdude is offline
post #4 of 12 Old Jan 25th, 2010, 1:23 pm
There are 2 "circuits" on the ABS brakes for 05 LT.
The "master" cylinders are part of the primary.. they only "send the pressure signal" to the ABS unit. Squeeze hard, more pressure (not so much fluid)
The ABS actually "sends" pressure through Hydraulic servos (pumps) built into the unit from the "secondary" / ABS unit to the calipers.
It is VERY possible you need to have the ABS system "flushed"... that will replace all fluids and "top off" the ABS reservoirs ... (yes, the reservoirs in the ABS hold the fluid that ACTUALLY goes to the Brake Calipers.
post #5 of 12 Old Jan 25th, 2010, 2:29 pm Thread Starter
pb4ugo's Avatar
cfell, your response offers some hope. Although the BMW tech bled the system and topped everything off, a system flush was not accomplished. With nearly 49,000 miles on the odometer it certainly wouldn't hurt.
I've owned this beast since it was new and, sad to say, it has found a way to 'gently' lay on its side more than once (but not within the past year) so I suppose its possible a bubble or contaminant has been introduced into the ABS reservoir.
Thanks to everyone for your help.
C'est la Vie
pb4ugo is offline
post #6 of 12 Old Jan 25th, 2010, 2:46 pm
I "flush" the ABS yearly... every December...run almost a quart through the system... the tech's have the "process"..
Definitely check the "wheel sensors" too.. if they are loose or cables tied off too tight in the wrong place they could cause the fault.
Also, don't overlook possibility of a weak battery.. or connection... vibration such as you mention could shake things enough to cause bizzare symptoms
post #7 of 12 Old Jan 25th, 2010, 5:09 pm
Question Re: '05 LT ABS Module needed
I am experiencing the same problem, only my ABS faults when the ambient air temp. is 40 deg. or colder! Go figure! If I stop and turn off the ignition and restart the ABS resets until the next stop. As soon as the air warms up then no problem. This is a daily driver, 2003 with 16,000 miles. Any thoughts?
longryder is offline
post #8 of 12 Old Jan 25th, 2010, 7:10 pm
not the same system.. sounds like you could have a faulty sensor in the rear reservoir
post #9 of 12 Old Jan 25th, 2010, 9:02 pm
I would have to say weak battery as this only occurs at low temps when the battery is stressed.
For the 05 guy looks like the dealer rang it out on the moditiec tester so you may just have a bad unit. There have been a few of those fail. Mostly if they have not been flushed on a regular basis, but there have been some "brain" circuit board failures as well which has nothing to do with a flush.
post #10 of 12 Old Feb 4th, 2010, 11:56 am
Re: '05 LT ABS Module needed/ what about a '00 LT
Hello all; I ask this last year but been away a few months; my abs lights are wig-waggin, Lone Star in Austin said I need the $2500 fix, but figured I needed to flush the complete system, abs and all since the bike set up in a garage for awhile. 2000 model with 18K miles, now 26K. I bleed front and back and it looked like root beer, but didn't spent the time for abs flush or know-how to do it. Is it fairly simple to do the complete flush?
cadillac is offline
post #11 of 12 Old Feb 4th, 2010, 12:43 pm
Your bike has the ABS II system and it flushes just like a car. The fluid goes in the front reservoir and comes out the caliper bleed port on the front brakes. Like wise for the rear. This also flushes out the ABS unit.
This one requires intervention to reset once you have fixed the fault. There is a long post about how to do it by jumping wires or find some one listed in the GS-911 registry to help you out. You really need to know the fault code to tell what is wrong. Sensors are fairly easy and the ABS unit "stuck piston" fault can be corrected most of the time by a little bit of dissassembly and cleaning. The long post I mentioned also has a method on how to read out the codes if you can't find someone with a GS-911 unit.
post #12 of 12 Old Feb 4th, 2010, 2:02 pm
Thanks, I will get another bottle of fluid and flush front and rear again, Terry
cadillac is offline
Where do I find a used ABS II module for a '99 LT??? st2en K1200LT 2 Jan 21st, 2009 11:35 pm
Abs Module nige-h2008 K1200LT 6 Oct 14th, 2008 1:38 pm
