How to remove front speaker cover from the dashboard - BMW Luxury Touring Community
post #1 of 11 Old Jan 21st, 2010, 5:12 pm Thread Starter
Vilssi's Avatar
Hi,
My lefthandside front speaker doesn't work. Now I just need to know, how can I remove the speaker cover. Or do I have to unscramble the whole dashboard.
Thanks for the information
Vilssi is offline
post #2 of 11 Old Jan 21st, 2010, 7:33 pm
Re: How to remove front speaker cover from the dashboard
Yes as it has tabs on the back side.
Better to remove the tupperware and check all connections as often they become a bit corroded and you will loose a speaker that way. A clean up and a light coating of dielectric grease is all that is needed to restore sound. You have to remove both sides and loosen the sting ray (radio module) and slide it back to get to the front speaker connector.
post #3 of 11 Old Jan 22nd, 2010, 4:17 am
You can´t remove the speaker without basically removing most of the tupperware as well as the screen and, to make things easier, the handlebar plastic covers.
I would suggest that if you do think that it is a malfunctioning or broken speaker, that you purchase one before disassembling the bike. That way you will have the procedure fresh in your mind when assembling it again.
All four speakers are the same.
Good luck.
simoncharles is offline
post #4 of 11 Old Jan 22nd, 2010, 3:35 pm
Defaoite's Avatar
See attached photo`s of what the dash looks like to get to the speakers.
Not a big problem to get at - just time
Sláinte
Derek
ID:	26025   Click image for larger version
May you be in Heaven half an hour before the Devil knows your dead
Defaoite is offline
post #5 of 11 Old Jan 22nd, 2010, 5:00 pm Thread Starter
Vilssi's Avatar
Okay,
I cant wait tomorrow to get to the bike. Thank you all for the information!
Vilssi is offline
post #6 of 11 Old Jan 7th, 2019, 1:12 pm
What fasteners are used to secure handlebar covers. I need to remove mine to be able to put the speaker gill cover back in place. I cannot see what fastener is being used. I don't want to strip them.
thanks,
Alex
865 617 2093 cell
Alex Cuningham
865 617 2093 cell
acuningham is offline
post #7 of 11 Old Jan 7th, 2019, 2:38 pm
3 mm Allen on the handle bar covers. Drape a towel over the opening so you don't drop a screw into the abyss.
post #8 of 11 Old Jan 7th, 2019, 3:11 pm
John,
Thanks for your help.
I am trying to reassemble my bike after a crash in October that broke the control arms off of the windshield adjustment assembly. I got some new parts and rebuilt the assembly. In order to remove the old assembly, I had to remove the dash/speaker grills and remove the instrument cluster. Now that I am putting this back together with the assembly in place, and the instrument cluster in place, I have an interference fit trying to put the dash/speaker grill back in place. So I thought if I removed the handlebar covers I could lessen the interference.
Any suggestions or old posts on how this goes back together? The correct sequence?
Alex
Alex Cuningham
865 617 2093 cell
post #9 of 11 Old Jan 8th, 2019, 9:29 am
This is as good as it gets. For the handle bar covers (remember the towel) put the lowers on loosely until you have them aligned then snug them down. Slide the tops on and be careful to not cross thread those M 4 screws.
Name:	Speaker covers.PNG
ID:	149279   Click image for larger version
Name:	Instrument Cover.PNG
ID:	149281   Click image for larger version
Name:	front fairing.PNG
ID:	149283   Click image for larger version
Name:	Handle bar trim.PNG
post #10 of 11 Old Jan 9th, 2019, 6:02 pm
JZ,
On page 4, #8. Are these screws the same length or different as they appear to be?
_____________
Kim Thomson
Motorcycle Cigar Smoker
85 K100 Standard - Big Red
Gone, but not forgotten...
85 K100RT - (wore out)
alabrew is offline
post #11 of 11 Old Jan 9th, 2019, 10:32 pm
They are very different like 1/4 and 1 inch and the long one goes where you would think the short one does.
Trike cover modifications Triker Trailers, Sidecars, & Trikes 2 Jun 1st, 2008 1:26 pm
Ohlins shocks sanjaun2 Shocks and Suspension 35 Jul 16th, 2006 3:01 am
Help-how to remove nose cone cover motogpmgr K1200LT 7 Jun 25th, 2006 10:09 pm
Front strut removal? bmwbasalt K1200LT 4 Apr 3rd, 2006 9:01 pm
Remove speaker grilles ? STARFIGHTER K1200LT 13 Jan 13th, 2006 1:48 am
