Quick Disconnects, High beam HID, Canisterectomy, Brown wire, Speedo Mod, etc - BMW Luxury Touring Community
post #1 of 19 Old Jan 21st, 2010, 11:28 am Thread Starter
atrovarious's Avatar
Quick Disconnects, High beam HID, Canisterectomy, Brown wire, Speedo Mod, What am I forgetting?
Well I have an o-ring leak on my fuel tank and my fuel level tube is bent so I'm going to do the above repairs etc.
I'm wondering if there is anything else I should do or take into account. I'm going to do it all at once so want to make sure I have everything.
I also would appreciate suggestions on where to purchase the above as well. The quick release disconnects at $75 surely there are better options.
Thanks in advance.
Ghaison (Jason)
2004 K1200LT FOR SALE!!!
Bluefield, VA
atrovarious is offline
post #2 of 19 Old Jan 21st, 2010, 11:50 am
SLTex's Avatar
Re: Quick Disconnects, High beam HID, Canisterectomy, Brown wire, Speedo Mod, etc
Might as well change the fuel filter and the hoses leading to and from inside the tank. While the tank is off, check the air filter.
Ride 'em if you got 'em.
SLTex is offline
post #3 of 19 Old Jan 21st, 2010, 12:02 pm
Does the 2004 have the (in)famous brown wire ?.
simoncharles is offline
post #4 of 19 Old Jan 21st, 2010, 12:25 pm
zippy_gg's Avatar
Thanks in advance.
Your 99 does not have the brown wire. Instead disconnect the temperature sensor at the airbox, on the front left side. Easier done with the tank removed, although some have done it with the tank in place. Installing Quick Disconnects will make future maintenance easier, since your 99 does not have them. Check the A&S BMW site or beemerboneyard for those QDs. They aren't cheap, but don't substitute those with plastic ones.
For the fuel level tube I would try ltparts.com or beemerboneyard.
Also based on your year/mileage you may want to replace the slave cylinder and drill the weep hole as a preventive measure.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #5 of 19 Old Jan 21st, 2010, 12:27 pm
zippy_gg's Avatar
My 03 did have it, so I suspect your 04 has it too. 05 and newer don't have the issue.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #6 of 19 Old Jan 21st, 2010, 1:16 pm
sheldan2's Avatar
You can possibly straighten out your tube by running a socket down the inside of it. If it is too far gone, you might also check out www.cyclesrecycled.com for parts.
Courage doesn't always roar. Sometimes it is the quiet voice at the end of the day saying " I'll try again tomorrow".
sheldan2 is offline
post #7 of 19 Old Jan 21st, 2010, 5:38 pm Thread Starter
So I have a new transmission and clutch with weep hole currently.
I have an external fuel filter and I think I will stick with it though I am going to upgrade the lines and the filter. Not sure. May put it back inside.... May go with stainless steel braided lines and a fancy metal filter.....
May as well ad the Rhinewest chip as I already have a Remus Exhaust.... Where is the best price on those these days? Anyone know?
Ghaison (Jason)
Bluefield, VA
post #8 of 19 Old Jan 21st, 2010, 5:58 pm
mwnahas's Avatar
You can try the boneyard.
http://www.beemerboneyard.com/cpcqkdiscon1.html
http://www.beemerboneyard.com/cpcqkdiscon.html
Just Go
Cleveland Ohio
mwnahas is offline
post #9 of 19 Old Jan 21st, 2010, 6:59 pm
seahabit's Avatar
With most of the plastic off, it's a good time to flush brakes and clutch.
seahabit is offline
post #10 of 19 Old Jan 21st, 2010, 7:04 pm
zippy_gg's Avatar
Speaking of stainless steel braided lines, maybe now would be the time to replace the rubber brake lines. Probably a good preventive maintenance on a 99, regardless of mileage.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #11 of 19 Old Jan 21st, 2010, 10:10 pm Thread Starter
It is an 04 with 30k but I may still consider it if the price is right. Thank you for all the suggestions....
Ghaison (Jason)
Bluefield, VA
post #12 of 19 Old Jan 22nd, 2010, 3:50 pm
Defaoite's Avatar
Got my QD`s from Beemerboneyard.com @ $75.95 not cheap but great quality.
My HID low beam upgrade from XenonDepot.com @ $169.99 using discount code BMWLT.com - plug & play - no problems.
Sláinte
Derek
May you be in Heaven half an hour before the Devil knows your dead
Defaoite is offline
post #13 of 19 Old Jan 22nd, 2010, 6:26 pm Thread Starter
Sláinte
Derek
I'm pretty sure I spent half that 2 years ago... I would think they would be around 50 these days... H9? high beam on an 04?
I may go ahead and get the disconnects though I'm tempted to just put a coupling in there that can be clamped off. Seen too pricey for something I may never remove again...
Ghaison (Jason)
Bluefield, VA
post #14 of 19 Old Jan 22nd, 2010, 6:44 pm
zippy_gg's Avatar
Sorry Jason, your RS is a 99. then don't worry about it yet.
The high beam on your 04 is an H3, low beam H7. See here for pricing from DDM Tuning on HID motorcycle kits.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #15 of 19 Old Jan 24th, 2010, 8:51 pm Thread Starter
Thanks bud. I think I bought my low beam from cq.... it's been two years though.
Ghaison (Jason)
Bluefield, VA
post #16 of 19 Old Jan 25th, 2010, 1:40 pm Thread Starter
I just bought all new low and high beam sets for the bike and car. I did so because I wanted the additional wattage and wasn't happy with my other HID set and because I like some continuity.
Ghaison (Jason)
Bluefield, VA
post #17 of 19 Old Jan 25th, 2010, 1:49 pm
You can go to home depot and check out the plumbing section. From there you can get a brass couping for a few dollars. I think you need 1/4 inch, plus you'll need the metal ties (i forgot what they're called)
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
ebay is great for parts, but this late in the winter it will be a little hard to find used parts.
02 LT
Caveno is offline
post #18 of 19 Old Jan 25th, 2010, 2:49 pm Thread Starter
Yeah I thought about going that route as well and just clamping the hoses when I take it apart but I sprang for the quick disconnects...... I figured since I was going to take pictures I might as well make it look nice.....
Ghaison (Jason)
Bluefield, VA
post #19 of 19 Old Jan 25th, 2010, 3:24 pm
AlaskaFish's Avatar
Wink Re: Quick Disconnects, High beam HID, Canisterectomy, Brown wire, Speedo Mod, etc
That is exactly what I did when one of my Plastic QD's which I had installed years ago broke. In fact, even though I have since replaced the QD's with metal ones, I still carry the two brass barbed couplings just in case I might need a fix on the road some day.
John & Marilyn Fisher
'00 K1200LTC "Katie"
'95 Triumph "Tigger"
Hillsboro, Oregon
AlaskaFish is offline
CQ Lights - HID low beam not working... Ted Shred Lighting 2 Feb 11th, 2009 8:30 pm
Which CQ HID to replace the high beam H-9? sheinzer Lighting 5 Dec 28th, 2005 3:41 pm
Oops, I let out the magic smoke jkersh1 K1200LT 4 Oct 27th, 2005 9:36 pm
Piaa 910 wire to High Beam... Mike_the_Rat K1200LT 1 Oct 8th, 2005 7:22 am
