Cruise control inoperative - BMW Luxury Touring Community
post #1 of 5 Old Jan 20th, 2010, 8:28 pm Thread Starter
Thanks to all that pointed me to the diagnostics. The test showed the throttle stop switch at fault. Do I have to pull the tank etc to get to it or is it accessible an easier way? Also when I get to the switch are there specific specs for the adjustment or repair?
2001 BMW LT
2007 Kawasaki 900 LT
JJensen8 is offline
post #2 of 5 Old Jan 21st, 2010, 8:27 am
bigbear's Avatar
Re: Cruise control inoperative
What do you mean by "throttle stop switch"? Is this the switch located by the throttle bodies? If yes and your 01 is like my 02 this is adjusted by the throttle cable adjustments and you should not have to remove the fuel tank. Depending on the syle of cables you may not have to remove any plastic either.
NOTE: I could never get this switch adjusted on mine so I just disconnected it to confirm it was the only fault.
Roy
Roy Gregersen
85 K100RT sold
02 LTC DOA 9/21/14
12 R1200RT
bigbear is offline
post #3 of 5 Old Jan 21st, 2010, 10:44 am
dougholck's Avatar
Search "Technical - Hall of Wisdom" for more info.
http://www.bmwlt.net/ubbthreads/show...&Number=220720
Doug Holck
Lodi, Ca
I don't always ride motorcycles,
but when I do I prefer BMW's.
Ride safely my friends
3 Continents -10 Countries - 50 States
02 K1200LTe
04 1150GS Adventure
08 Suzuki DR650
CCR 05, 06, 07, 08, 09, 10, 11, 12, 13, 14
See you 2015 in Coeur d' Alene, Idaho
BMW MOA 109760
AMA Charter Life Member 518333
International Fellowship of Motorcycling Rotarians
HDDC POSSE
dougholck is offline
post #4 of 5 Old Jan 23rd, 2010, 2:37 pm
KJN
KJN's Avatar
Just got mine out of 24K service and the cruise control, that previously worked fine, became intermittent. After doing the diagnostic found the throttle release would fail one time and work the next.
I aslo noticed the tech took up some of the slack in the throttle free play. After adding some more slack (freeplay) to the the return cable, the cruise control worked fine.
Hope this helps. Easy fix.
Kimble
Phoenix
2000 K1200LT
KJN is offline
post #5 of 5 Old Jan 23rd, 2010, 2:58 pm Thread Starter
Doug Thank you for the links. In following the trouble shooting advice I found it to be the clutch switch. Other than learning to work looking in a mirror, it wasn't too bad. This site and all the input and sharing of experience has been a life saver. Thanks again.
2001 BMW LT
JJensen8 is offline
Cruise control diagnosis = what is this telling me? coug66 K1200LT 9 Feb 5th, 2012 10:06 am
Cruise Control OD with new cables. airborneod K1200LT 24 Jun 14th, 2011 7:42 am
MCCruise.com electronic cruise control installed Randy GS Series 16 Jun 22nd, 2007 10:04 am
Section speed trap in The Netherlands vvk Europe 4 Apr 18th, 2006 4:40 am
Speed traps in The Netherlands vvk Chit Chat 0 Oct 24th, 2005 10:38 am
