Map Light removal - BMW Luxury Touring Community
post #1 of 6 Old Jan 18th, 2010, 2:53 pm Thread Starter
AlReich23's Avatar
Map Light removal
I need to remove the back side of the dashboard in order to change the side windshield deflector. With the help of Sean, I was able to locate all the screws except the one behind the Map Light above the dash. Does anyone know how to take this off? Should I just pry it off?
Thanks.
2004 K1200LT (Black)
AlReich23 is offline
post #2 of 6 Old Jan 18th, 2010, 3:06 pm
jers99lt's Avatar
Re: Map Light removal
Turn off ignition switch.
Insert small screwdriver through the notch on the left side of the cockpit light and carefully pry the lens assembly out of the dash.
Jer
Jerry Palma
85 R80RT 'Lady in Red'
08 535xi Space Gray metallic
09 328i Silver Convertable
17 X3 Glacier Silver metallic
jers99lt is offline
post #3 of 6 Old Jan 18th, 2010, 3:07 pm
You need to gain access behind the map light. Pry the lens off with a thin screwdriver - the latch is on the side.
Robert in Northern NJ
rdwalker is offline
post #4 of 6 Old Jan 18th, 2010, 3:09 pm
AlaskaFish's Avatar
Wink Re: Map Light removal
Thanks.
To remove the Map Light you just need a small (tweaker) straight slot screwdriver to poke into the small opening to the left of the bulb and depress the tab which holds it into the dash. Lift it out carefully, then remove it entirely, and unplug the wires. You will then be able to see the elusive screw that resides up and slightly to the left (as you are sitting on the Bike) which must be removed in order to remove the instrument cover.
HTH,
John & Marilyn Fisher
'00 K1200LTC "Katie"
'95 Triumph "Tigger"
Hillsboro, Oregon
AlaskaFish is offline
post #5 of 6 Old Jan 18th, 2010, 4:27 pm Thread Starter
AlReich23's Avatar
Thanks...
John / Jerry / Robert
I would have surely broken this little but expensive piece had it not been for your responses.
post #6 of 6 Old Jan 19th, 2010, 12:09 pm
larryschumer's Avatar
This may help. Here's a close up photo of the map light (this is the one in the trunk, but it's the same as the one in the front).
You can see the plastic piece that holds it in on the left. This is what you're trying to push in with the small screw driver.
BTW: The map lightt in the trunk is much harder to remove--you have to drill a hole first.
Name:	Map Light.JPG
Larry Schumer
Salt Lake City, UT
2003 K1200LT (Black/Yellow) BigBee
Unigo Trailer (Black/Yellow) Stinger
larryschumer is offline
How many forum posters does it take to change a light bulb? brianbeemer Humor 24 Mar 26th, 2010 2:46 pm
Help w/diagnosing cruise light stays on? coug66 K1200LT 7 Sep 17th, 2007 10:05 am
How many of us does it take to change a light bulb?! Bruce_Yates Humor 4 Mar 1st, 2006 9:03 am
How many forum members does it take to change a light bulb? RoyvL Humor 12 Feb 13th, 2006 1:49 pm
