Rear speaker not working????? - BMW Luxury Touring Community
post #1 of 4 Old Jan 16th, 2010, 8:39 pm Thread Starter
rear speaker not working can anybody offer advice on how to fix?
ToolmanTim is offline
post #2 of 4 Old Jan 16th, 2010, 9:56 pm
Re: Rear speaker not working?????
Two things can cause this. Blown output chips in the radio (not real likely) or corroded connections in the barrel connector(more likely). There are two barrel connectors. One is under the rear seat and the other is under the left side tupperware (opposite the gas filler). Often a disconnect and clean up with some contact cleaner followed with some diectric grease will restore the sound.
Before doing anything double check the fader control to ensure it didn't change. Step through the "note" button until you see FAD.
post #3 of 4 Old Jan 18th, 2010, 8:00 am
BMWWANDRR's Avatar
This has happened twice to my rear speakers. Both times it was bad amps and the whole unit had to be replaced. Good thing is, once it is replaced by BMW the warranty is two years on that part.
Greg and Melanie
06 BMW K12LT "WANDRR"
05 DL1000 "WNDRR2"
02 Triumph Trophy 1200 "WNDRR3", in Heidelburg
WANDRR Motorcycle Tours
wandrrmotorcycletours.com
BMWMOA, BMWMOAL, IBA, MTF
ITS ALL ABOUT THE RIDE
BMWWANDRR is offline
post #4 of 4 Old Jan 18th, 2010, 11:30 am
Over the past 5 years I have replaced a rear speaker and a front one. They had simply stopped working.
Replacing the rear one is a piece of cake compared to the front one.
simoncharles is offline
Tech Session in Easton, Pa. on March 21 firstbeemer North East 61 Mar 11th, 2011 2:55 pm
Rear Speaker Replacement Suggestions wkclark Intercom, CB, & 2-Way Radios 1 Aug 25th, 2008 10:46 am
Rt Rear Speaker Out-'03LT reggosnell K1200LT 15 Jun 28th, 2008 7:18 pm
Yet another rear end mystery! gdroege K1200LT 10 Oct 28th, 2007 1:59 pm
Linked brakes negative bmwrubbercow K1200LT 19 Aug 4th, 2006 4:00 am
