2003 LT Cruise Inoperative - BMW Luxury Touring Community
post #1 of 8 Old Jan 15th, 2010, 5:32 pm Thread Starter
GDRDoc's Avatar
Anyone have any ideas where I can start with a Cruise Control in troubleshooting? I got a BMW Clymer book, but it doesn't have anything in there for troubleshooting. Any ideas?
GDRDoc is offline
post #2 of 8 Old Jan 15th, 2010, 6:13 pm
Re: 2003 LT Cruise Inoperative
There are some threads/posts regarding the cruise control diagnostic tests that can be performed on the LT - click here for just one, and you can read further info throughout those pages. I found this in the HoW section by inputting "cruise control diagnostic" in the search line. Good luck with chasing down the problem.
post #3 of 8 Old Jan 15th, 2010, 8:04 pm Thread Starter
GDRDoc's Avatar
Dick,
OK.. Items 5, 7, 9 failed. Does this mean the control box is bad?
GDRDoc is offline
post #4 of 8 Old Jan 15th, 2010, 8:32 pm
Dick,
Hey, Erv - I don't gotta clue. Ole Toad's cc has never failed, so I haven't had the pleasure of running thru the diagnostic procedure. I just knew where it wuz in the technical forums. However, there are a ton of folks around here that do have some experience with it, so somebody'll pop on here shortly to help out (I hope!!). Good luck, Erv.
post #5 of 8 Old Jan 15th, 2010, 8:51 pm Thread Starter
GDRDoc's Avatar
Dick,
I found the problem. It was in the Throttle stop. After I got that to work, all the steps after that were ok.
It was sitting for three months for the winter. I guess before I start it, rotate the throttle it to the stop,
Thank you for your help.
Gdrdoc
GDRDoc is offline
post #6 of 8 Old Jan 15th, 2010, 9:15 pm
I found the diagnostic area, but not many suggestions for a fix. When running the test I got as far as the rear brake pedal. When pushing the pedal it operated as described turning on the light with the pedal and off after a few seconds, however when released ther was a loud "clack" somewhere in the rear of the bike and diagnostic ended. Any ideas. I assume it is something with the rear brake switch???
JJensen8 is offline
post #7 of 8 Old Jan 16th, 2010, 11:52 am Thread Starter
GDRDoc's Avatar
I saw the same thing..how to troubleshoot, but not how to fix on the net. I guess if ya come up with a step that failed, one might on here if anyone has the same problem, or take it to the dealer.
GDRDoc
GDRDoc is offline
post #8 of 8 Old Jan 17th, 2010, 1:38 pm
I re-ran diagnostics this morning and the indication this time is the throttle stop. It looks like you made this adjustment. I am a new owner of a 2001 lt. Any tips or suggestions for the throttle stop adj. In the Clymer manual it looks like they suspended the switch and built the bike around it.
JJensen8 is offline
Cruise Control OD with new cables. airborneod K1200LT 24 Jun 14th, 2011 7:42 am
Alaskan Cruise before 2010 rally??? BMWWANDRR Rides, Rallies and Get-togethers 6 Feb 6th, 2010 9:17 am
Special Cruise Package Lonewuff Humor 5 May 3rd, 2009 7:08 am
MCCruise.com electronic cruise control installed Randy GS Series 16 Jun 22nd, 2007 10:04 am
K1200LTC Cruise Control Quirks maxgusdad K1200LT 6 Aug 28th, 2006 1:55 pm
