2003 LT Rear Rotor Noise - BMW Luxury Touring Community
post #1 of 22 Old Dec 9th, 2009, 4:19 pm Thread Starter
MattKas's Avatar
My 03 LT's rear rotor (OEM) makes noise when going over speed bumps, slow speed parking lot riding and when on side stand while engine running. It is like rattling/ vibration noise. EBC Brake pads are around 3mm thick. So it is not time to replace them yet. (My 04 LT does not make that noise at all.) Any ideas on how to fix this rear rotor noise?
Thanks in advance...
Matt Kas
"Riding Year around"
MattKas is offline
post #2 of 22 Old Dec 9th, 2009, 5:59 pm
mwnahas's Avatar
Re: 2003 LT Rear Rotor Noise
if its a clunk or clank sound then its getting loose and needs replacement or just live with the sound. some have use filler materials to make it less noisy. I ended up having mine replaced with a beer discount.
Just Go
Cleveland Ohio
mwnahas is offline
post #3 of 22 Old Dec 10th, 2009, 2:23 pm
bblalock's Avatar
You have what is called "the cow bell" sound. Replace the rear rotor and pads with the EBC unit. My '08 LT had the "bells" at 8,000 miles.
I was told, yesterday, by my BMW shop that the EBC units are hard to get now. Apparently EBC learned they should have been a higher priced unit.
Benton Blalock
"I ride.....the bike doesn't"
'18 Honda Africa Twin Adventure SportDCT
'12 Kawi KLR 650 "Dirty" - traded in
'08 LT Black "Fireball" 113,000+ miles(RIP- transmission - may be seen on the road again)
'05 LT Yeller er Gold? "Ophelia"(RIP- fire) 80,000 miles
'04 R12CLC (RIP- hurricane) 36,000 miles
230,000+ BMW miles
'Rounder'
bblalock is offline
post #4 of 22 Old Dec 10th, 2009, 3:29 pm Thread Starter
MattKas's Avatar
What kind of filler materials and where?
Matt Kas
MattKas is offline
post #5 of 22 Old Dec 10th, 2009, 3:30 pm Thread Starter
MattKas's Avatar
When replacing the rear rotor do you have to drain the brake liquid?
Matt Kas
MattKas is offline
post #6 of 22 Old Dec 10th, 2009, 3:44 pm
Old Slow Guy in A Fast Car
katnapinn's Avatar
No just remove the wheel, Unbolt the caliper ( use a piece of wire threw a bolt hole & to the bike to support the caliper) Then remove the 3 bolts on the caliper.
Stevie Shreeve
katnapinn is offline
post #7 of 22 Old Dec 10th, 2009, 3:46 pm
dvx216's Avatar
the bike I have now is also a 03 the older gentleman that I got the bike off of solved this problem with belleville washers some how but I'm not sure how he did it.
dvx216 is offline
post #8 of 22 Old Dec 10th, 2009, 7:15 pm
mwnahas's Avatar
Search for solutions.
Here is one...
http://www.bmwlt.com/forums/showthre...hlight=cowbell
Just Go
Cleveland Ohio
mwnahas is offline
post #9 of 22 Old Dec 11th, 2009, 1:28 pm
You've got time before the noise goes from annoyance to a real problem. Matt, call Omar (at MotoGhost). He replaced my rear rotor with the EBC after the old one rattled for an eternity. He's got enough LTs coming through for service he may have one in stock.
Motor On ,/'
jkersh1 is offline
post #10 of 22 Old Dec 11th, 2009, 2:16 pm
kinch's Avatar
I tried RTV between rotor & hub, cutting a radial slot in disc pads, cleaning routinely and the only long term solution was Blue Brake Pad glue as used in auto brakes. I've run this for 3 months & with no noise.
kinch is offline
post #11 of 22 Old Dec 11th, 2009, 5:00 pm
Wolfgang's Avatar
http://www.perfectbrakes.com/products.asp?cat=4624
They have the rear rotor in stock for $157.00. Not only is it quite but you get better brake response.
Wolfgang
K1200LT 1999 Champaign SOLD
R1100RS 1994 Teal SOLD
R1150RT 2003 Blue (Sold)
R1100RT 1997 Blue
Pest, Budapest Hungary
Mark Twain
Wolfgang is offline
post #12 of 22 Old Dec 11th, 2009, 6:44 pm
I check with some K1200LT forum of Taiwan website,they cut the 15mm washer to insert between nail and disc to fix the problem.
attached the the washer picture.http://www.wilin.com/chinese/08ww.htm
fh8932 is offline
post #13 of 22 Old Dec 13th, 2009, 8:38 pm Thread Starter
MattKas's Avatar
The washer makes sense if it does not drop.
I tried Shoe Goo today. I will see tomorrow if the noise is gone. I did not have to take off the wheel or anything at all. If this does not cure the cow bell, I should probably get an EBC rotor. I am only worried about taking off the ABS linkfrom the original rotor. Maybe I should also order a new ABS link.
Matt Kas
MattKas is offline
post #14 of 22 Old Dec 14th, 2009, 8:00 am
rattler50's Avatar
Heat the old rotor with a heat gun and the ABS ring will pop right off. Goes back on just as easy. It's a simple job and you'll be amazed at how easy it is. New EBC rotor and brakes will fix you right up. Relax..........
2006 R1200RT
2005 K1200LT Ocean Blue
2003 K1200LTE Black
Totaled Oct 2, 2010
2006 Kawasaki Vulcan 2000
rattler50 is offline
post #15 of 22 Old Dec 14th, 2009, 2:18 pm
bblalock's Avatar
Wink Re: 2003 LT Rear Rotor Noise
My ABS ring popped right off. Don't bother getting another you will not likely mess it up.
Benton Blalock
230,000+ BMW miles
'Rounder'
bblalock is offline
post #16 of 22 Old Dec 15th, 2009, 11:14 pm Thread Starter
MattKas's Avatar
Shoe Goo works!!! COW BELL is gone....
I hope this last long time :-)
Matt Kas
MattKas is offline
post #17 of 22 Old Dec 18th, 2009, 2:33 pm
Lare's Avatar
Not having had this problem, Matt, where did you put the Shoe Goo?
Custom sig temporarily unavaiulable while I think about it.
Lare is offline
post #18 of 22 Old Dec 18th, 2009, 4:12 pm Thread Starter
MattKas's Avatar
on and around the loose rivets on the rotor.
Matt Kas
MattKas is offline
post #19 of 22 Old Dec 18th, 2009, 6:21 pm
I wouldn't expect the goo to last forever. The high temp RTV held for about a year on my '03. I now have the new EBC unit. Not a hassle at all to put on, either.
Quite a difference when you're going down those brick streets in old Amarillo...
DasBoat2003 is offline
post #20 of 22 Old Dec 19th, 2009, 10:46 am
Steve_R's Avatar
Actually the rivets being a little loose is a design feature, while beit a poor one in comparison to the EBC. for the floating rear rotor on the LT,
The good centering springs for the rear rotor look like this.
A broken centering spring looks like this:
When you get multipe springs missing next to each other like this you start to get the cowbell effect:
Notice the groove in the rivet to allow the spring to center the rotor in the caliper.
A new EBC rotor with the springs located between the hub and the rotor:
These photos were taken in October when I upgraded to the EBC rotor. About an hours worth of work including yanking/replacing the rear wheel. And in my humble opinion a much more forceful braking capability from the rear than I ever had on the OEM rear rotor.
The stop gap measure everybody is using is just that a stop gap. Over time I believe that the silicone will deteriorate and leave you with the same problem you had before.
<on soapbox> I've been in the computer business for 30 years worked on everything from the CPUs to the peripherals and my motto has been "Fix it right the first time." It's not failed me yet and I don't believe it will fail me now. <off soapbox>
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
post #21 of 22 Old Dec 19th, 2009, 12:25 pm
AlaskaFish's Avatar
Thumbs up Re: 2003 LT Rear Rotor Noise
Steve, your pics of the rear rotor and the EBC replacement are the best I can recall seeing! Tks for taking the time to post them. In fact, I say they should be part of our HOW for future reference!
John & Marilyn Fisher
'00 K1200LTC "Katie"
'95 Triumph "Tigger"
Hillsboro, Oregon
AlaskaFish is offline
post #22 of 22 Old Dec 19th, 2009, 5:16 pm Thread Starter
MattKas's Avatar
Thanks for advice and great photos. I will go for EBC rotor as soon as my Shoe Go starts going bad.
Matt Kas
MattKas is offline
2005 Rear End Jerrym K1200LT 28 May 17th, 2007 8:34 pm
Near Disasterous Rear Tire Failure NVRider K1200LT 18 Apr 27th, 2007 12:07 pm
Linked brakes negative bmwrubbercow K1200LT 19 Aug 4th, 2006 4:00 am
Loose Rear Wheel thalpin K1200LT 15 Apr 13th, 2006 2:47 pm
Replacement of rear shock suspension unit PhillWard Australia, New Zealand, and AsiaPac 3 Jan 17th, 2006 6:01 pm
