Reverse is not working- Need advice - BMW Luxury Touring Community
post #1 of 4 Old Aug 7th, 2009, 2:22 pm Thread Starter
pwmac2005's Avatar
1999 K1200LTC with @ 35K miles
A buddy of mine just called from over in Salado, TX.
He replaced the battery on his K12 last week. Now reverse won't work. Yellow R light comes on as soon as he flips to reverse. Then, when he mashes the starter button, yellow R light flashes, idle speed comes up but no movement.
Y'all got any suggestions?
Paul McClure - Houston
pwmac2005 is offline
post #2 of 4 Old Aug 7th, 2009, 3:00 pm
madmanmike's Avatar
Re: Reverse is not working- Need advice
Paul,
Same thing happened to my 03, it was suggested that I left the hot wire off the positive battery when I installed the new battery. I checked and it appeared to me that all the wires were connected, it ended up being the reverse controller itself. I was able to find a used one for $ 250.00 and it now works great.
Have your friend check to see that he did not leave the hot wire off the terminal, if it as where it should be my money is on the controller.
This fault is different from the common problem, the bike will move backward a little, then stop. My trouble was the same as your friend, idles up, reverse light flashes but the bike doesn't move at all.
Mike Riley
'03 Graphite Met
AMA, IBA
madmanmike is offline
post #3 of 4 Old Aug 7th, 2009, 3:29 pm
alstrickland55's Avatar
I had this problem on my 2002. It turned out to be the speed sensor. Not very expensive and easy to replace...
Al Strickland
Blairsville, Georgia
1967 Honda Cub
1972 Honda CB350
1979 Suzuki GS750E
2009 R1200GS
2013 K1600GTL
2009 K1300GT
alstrickland55 is offline
post #4 of 4 Old Aug 7th, 2009, 3:49 pm
He left off one of the wires to the battery. The one that feeds the reverser controller. Sounds like the controller is working (idle up) just that the feed to the starter is not connected.Have him look for another red 10mm wire that goes back to the controller and put it back on the battery + terminal.
Beware of reverse nplenzick K1200LT 1 Oct 31st, 2008 10:06 am
Things I've relearned working on my LT BecketMa K1200LT 9 Sep 17th, 2008 1:45 pm
Update: Radio pause & reverse not working ArthurKnowles K1200LT 6 Apr 17th, 2008 9:29 am
Reverse Inoperative JosephFry K1200LT 10 Aug 22nd, 2007 4:53 pm
reverse not working tmgs K1200LT 11 Jul 14th, 2006 2:29 pm
