6 Cd Changer Skipping Baddly-fix - BMW Luxury Touring Community
post #1 of 9 Old Jun 13th, 2009, 9:33 am Thread Starter
For the past few months my CD changer has been skipping badly enough that I deemed it unusable. I spoke to my local dealer to see if they knew of any fixes but drew a blank. They suggested buying a new one or taking it to a local audio dealer. Neither of which I was prepared to do. No confidence in either.
So after striking out with getting any help I decided to go in for a look to see if I could identify any problems. I had searched the web and gotten remedies for skipping CD players, cleaning the lazer, lubricating the chrome rods that the lazer rides on, etc.
I removed the player, took the outer covers off, and then reconnected it to the bike to run it through the check and get a visual. I saw no evidence of a problem as it cycled through the check. It seemed that all systems were functioning like you like it.
WHAT I DID FIND:
The carriage that houses the 6 CD cartridge and player is suspended in the unit by a spring on each end and two shock mounts on each end. I noticed that the right side of the carriage was sitting much lower than the left. As a result of the right side (this is the side with the lazer eye and slide rail) sitting low it put the carriage at the very bottom (should be centered to be most effective) of the two right end shock mounts rendering them uneffective.
THE FIX:
Now that I suspected that the right side shock mounts weren't doing their job I needed to find a way to center the carriage in the mounts. This would mean creating greater spring tension to bring the mounts back to center. I looked at the springs and their mounts and found that they do have an adjustment. It's basically a half moon shaped slot with about four or five detents that you can adjust to. I looked at the left side adjustment for comparison and it was adjusted to the very top slot of the half moon. So, I adjusted the right side spring tension to match the left and it took the carriage back to the middle of the shock mounts.
With the exception of blowing a little air inside the player I performed no other tasks other than adjusting the spring tension on the carriage.
THE RESULT:
I reinstalled the changer and took it for a test ride. The road leading to my house is relatively bumpy and has always caused me to shut down the player because it would skip the whole way. This ride however didn't result in a single skip whatsoever. I rode for a few hours and the changer performed perfectly.
Now I suppose it is possible to take a severe hit (bump) to the rear end that might knock the spring tension adjuster to the bottom detent of the half moon where mine was.
All I can tell you for sure is that I'm back in business with the 6 CD changer and it only took about an hour to diagnose and repair.
I hope this might get some of you guys back in business as well.
BuddyP
"The Carolinas"
2003 LTC "Black Beauty"
aka "Tha Motha Ship"
buddyp is offline
post #2 of 9 Old Jun 13th, 2009, 10:11 am
Re: 6 Cd Changer Skipping Baddly-fix
Interesting, good job.
mjordans2000 is offline
post #3 of 9 Old Jun 13th, 2009, 10:20 am
SilverBuffalo's Avatar
My compliments to your mechanical ability and patience.
Like many others I removed the CD player
rather than tolerate the poor performance and to have more space in the side bag.
I now have two of them sitting on the shelf.
I tried the XM it's alright but still has some drawbacks,
The ultimate cure (for me) is an Ipod, plugged into the Aux of my intercom I can use the handlebar volume controls and have over 1500 songs to choose from, CD players are for sale (cheap)
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #4 of 9 Old Jun 13th, 2009, 10:21 am
RonKMiller's Avatar
My fix: buy an Ipod and ICE and join the rest of us in the 21st century.
Seriously though, excellent job of actually FIXING something instead of just about like everyone else who just gives up.
( I've got one gathering dust with exactly the same symptoms you described.)
"Like Butt-ahh!"
RonKMiller is offline
post #5 of 9 Old Jun 13th, 2009, 10:48 am
gunny's Avatar
Good job!
Thanks for sharing.
Mine is starting to skip more than it used to, believe I'll take a look at it and see.
B D R
gunny is offline
post #6 of 9 Old Jun 13th, 2009, 5:36 pm
seahabit's Avatar
Yo buddyp, guess I'll be a pullin' my changer out of dry dock. Wish I had your critical eye.
seahabit is offline
post #7 of 9 Old Jun 13th, 2009, 8:58 pm
MikeERideWNC's Avatar
Another tip is when creating your own CDs only put twelve tracks / 60minutes of songs on the disk.
It will skip when the eye has to read the outer edge of the CD.
I listen to XM more than anything else.
Visit
MikeERideWNC is offline
post #8 of 9 Old Jun 13th, 2009, 9:06 pm
hallzee's Avatar
I listen to XM. Removed the CD player a long time ago for the extra room.
Good work on the fix though, and glad it worked for you!
Brian
CCR-R: 2018, Russellville
'13 K1600 GTL-P - "Eva"
IBA #31242 (SSx2, BB, BBG)
MOA #136148
hallzee is offline
post #9 of 9 Old Jun 14th, 2009, 7:28 am
A past problem was that BMW put too long screws in the brackets on the side of the changer. It is marked on the side to use 4MM max length screws, but someone at the factory put 10MM long ones in on occasion. Always something to check first when one is skipping.
CD Changer Wiring Tat_n_Telle K1200LT 10 Jun 8th, 2012 10:54 am
Can't install CD changer ?!? Frenchy K1200LT 7 Nov 15th, 2008 8:15 pm
99 LT Stock Radio/CD Changer BaronVonGregg K1200LT 3 Jul 4th, 2008 10:20 am
2000 lt CD changer won't work saileyboy K1200LT 7 Apr 24th, 2007 12:16 am
Anyone use USA-SPEC audio adapter instead CD changer? rdwalker iPod/MP3 2 Feb 5th, 2007 10:00 pm
