Charcoal canister removed? - BMW Luxury Touring Community
post #1 of 13 Old Jun 12th, 2009, 6:26 pm Thread Starter
drags's Avatar
Why do you remove canister?.IAM getting ready for a 12k and would do it then for a good reason.
drags is offline
post #2 of 13 Old Jun 12th, 2009, 6:34 pm
Palerider's Avatar
Re: Charcoal canister removed?
Should you perhaps over fill out on the road; the overflow winds up back in either the hoses or the charcoal..........the engine will then not want to idle and will probably not want to play very nicely at higher speeds.............personally........and I do not have a clue how many miles you have on it .................if your careful and it's running...............don't get excited............if you should start to encounter those simptoms.............you know what to do...................
Palerider is offline
post #3 of 13 Old Jun 12th, 2009, 7:20 pm
hallzee's Avatar
Living in Commifornia, you may want to hold off removing the cannister. There are new laws blowing in the wind that would require smog checks on motorcycles.
You could remove it, and just save it - just in case. I did remove mine years ago, but didn't save it!
Brian
CCR-R: 2018, Russellville
'13 K1600 GTL-P - "Eva"
IBA #31242 (SSx2, BB, BBG)
MOA #136148
hallzee is offline
post #4 of 13 Old Jun 12th, 2009, 10:17 pm
wa1200lt's Avatar
Or, better yet, just disconnect the hose going from the tank to the canister and reroute toward the bottom of the bike. Put a bolt in the hose going from the canister to the fuel rail and just leave the canister where it is in case you need it later to get through emissions. Make sure the bolt is big enough to plug the hose or you will have a vacuum leak.
Do bypass or remove the canister though. I would gas up and the beastie would run like crap. Did a right side canister ligation and a left side canister reduction and it is smoooooooth as buttah. All the time!
Loren
WAK1200LT
Loren
wa1200lt is offline
post #5 of 13 Old Jun 13th, 2009, 12:24 am
Not just a problem with overfilling the tank. Mine clogged after baby decided to roll over and play dead.
mjordans2000 is offline
post #6 of 13 Old Jun 13th, 2009, 6:59 am
I think the canister is sort of like the appendix - there but no one really knows why. I took mine out as soon as I found out about it on my 02 and have not noticed a difference, which is probably a good thing.
post #7 of 13 Old Jun 13th, 2009, 10:29 am
Loren
Never use a bolt or screw to plug a line and not expect a leak! Unless you get the tubing past any threads and onto a solid portion of the screw or bolt, there will be a considerable leak around the threads. If you want to plug any line without a leak, use a SOLID plug, easily available at almost any automotive parts store.
post #8 of 13 Old Apr 28th, 2014, 8:28 pm
Is there anything needed done with the sol?.....elect......vacuum?
artswaff is offline
post #9 of 13 Old Apr 28th, 2014, 8:59 pm
james216's Avatar
I would pull it out then reroute the tubes to dump overfill fuel down and on the ground. But save canister JIC.
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is offline
post #10 of 13 Old Apr 28th, 2014, 9:32 pm
azccj's Avatar
On both my BMWs I still have the charcoal canisters installed as I haven't had any problems with either bike. On my Guzzi I removed it because it was messing with the idle when hot. Now the thing I noticed with the Guzzi which no longer has the canister and valve, is when the bike is hot and I park it in the garage there will be a strong smell of gas coming from the Guzzi. It usually isn't from any leaking gas but from the fumes in the tank expanding from the heat. When the bike is very hot with little fuel in the tank and parked, a clear liquid sometimes comes out one of the vent tubes. This liquid doesn't smell like gas but appears to be the ethanol in the fuel distilling out of the fuel when it's hot. I know it sounds strange but that's what it seems to be. One of these days I'll try and collect some of the fluid and see if it will burn.
I believe how the evaporative emission control system works is the canister which is full of charcoal, absorbs the gas fumes venting from the gas tank when the bike is parked and the valve in the system prevents any fumes from venting into the atmosphere. When the bike is running the valve opens allowing air to be drawn through the canister and any gas fumes stored in the charcoal are then sucked into the engine where they are burned.
Personally I wouldn't mess with removing the canister unless the bike was acting up because of it.
Current Bikes
2013 Triumph Trophy SE
2013 Suzuki Burgman 650, Ya it's a scooter but it will do over 100 MPH
2005 BMW K1200LT
2004 BMW R1150RT
1972 Moto Guzzi Eldorado
azccj is offline
post #11 of 13 Old Apr 30th, 2014, 4:09 pm
Schmoogdaddy's Avatar
I just did the canisterectomy, but when I took the back cover off, I found the yellow cube flasher or relay looking thing out of it's socket and lying down in the wheel hump. All my turn signals are working. Before I plug it back in, what is it?
Schmoogdaddy is offline
post #12 of 13 Old Apr 30th, 2014, 4:29 pm
zippy_gg's Avatar
Your bike is likely a 99. I had the same on my 99LT and I removed it, instead of unplugging the temp sensor at the air box, to eliminate the engine hesitation in hot weather.
If your temp sensor is still plugged in then you can leave the yellow thingy off, otherwise plug it back in. Others prefer to leave it on and unplug the hear sensor. 6 of one or 1/2 dozen of the other...
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #13 of 13 Old Apr 30th, 2014, 5:35 pm
It's a 2000 LT. Shoulda mentioned that.
I realized the answer to my question about 5 minutes after I posted, but thanks for your reply.
Have you replaced your Charcoal canister? yechave K1200LT 29 Jun 3rd, 2008 8:44 am
Canister Troubleshooting dglenn1 K1200LT 4 Aug 3rd, 2007 10:26 pm
charcoal canister alstrickland55 GS Series 3 Jul 17th, 2007 2:41 pm
Fuel canister problems. CARNEYM K1200LT 1 Jul 9th, 2007 12:44 pm
Canister on gas tank vent line bikertz K1200LT 5 Jul 1st, 2007 6:18 am
