Hesitation on Hot Days - BMW Luxury Touring Community
post #1 of 8 Old Jun 11th, 2009, 2:57 pm Thread Starter
I read the tech article on the fuel injection map that causes hesitation in hot weather to prevent pre-ignition. I immediately pulled off the topcase and disengaged the yellow connector on my 99 LT only to find that the bike would not start. Is there another way to do this without cutting a temperature sensor?
thanks
rjb1696 is offline
post #2 of 8 Old Jun 11th, 2009, 4:16 pm
Cat Herder
andy's Avatar
Re: Hesitation on Hot Days
I did the cutting the temp sensor back in 01 and I cannot say it often enough: afterwards I asked myself why I waited so long. You will have a new bike and no negative impact on the bike whatsoever. I ran mine until it was shot down with 60k miles on the odo like that.
Do it man, cut the wire. Its not as if you'd loose any warranty.
andy is offline
post #3 of 8 Old Jun 11th, 2009, 4:28 pm
TBob's Avatar
my 03 has the brown wire mod done to it - I believe it runs a different fuel map, not sure. Anyhow it got rid of the bog on my 03, maybe it would work for your 99. I sure someone here in the know will pipe up.
TBob
09 R1200 GSA
'03 LT Impala Brown - FOR SALE
'01 KTM 520 EXC
Interested in a Kontour seat? PM me I would be happy to share my Kontour experience.
TBob is offline
post #4 of 8 Old Jun 11th, 2009, 4:48 pm
CharlieVT's Avatar
thanks
No need to cut. I believe on the 99 model (this is true for my 1999 built 2000 model) you just unplug the air temp sensor connector behind the radiator cap where it is mounted on the air box.
CharlieVT is offline
post #5 of 8 Old Jun 11th, 2009, 5:16 pm
Yup, Curtis is right. Dude at Lone Star reached up under the nose cone and undid ole Toad's airbox temp sensor, back in '00, and it's been running like I stole it ever since!! Not one instance of hesitation, ever! When I later had the chance, I band-aided the connections to keep out debreeze.
BTW - concensus is that after you disconnect the sensor, you should run hi-test gasmoline from then on. The Motronic expects you to!!
post #6 of 8 Old Jun 11th, 2009, 8:30 pm
wacolt's Avatar
Did the RhineWest chip thing with the OEM exhaust and some of the hesitation went away. Then installed the Remus and aftermarket exhaust RhineWest chip; not nearly as noticeable at 95 F.
Rider of Stahlross
1999 Basalt Grey LT
2001 Classic Red Ducati 748
wacolt is offline
post #7 of 8 Old Jun 12th, 2009, 8:52 am
Lynn_Keen's Avatar
If your '99 is an early one the brown wire fix may or may not work. My 1st Lt was a very early '99 and it had the problem big time. Ultimately the engine control computer was replaced and that fixed the problem. I believe that replacement was done as a recall on the early models. You might inquire at your dealership.
Lynn Keen
North East Florida
MSF #28271 Retired
'01 R1150 GS- totaled
'02 R1150 GS sold
'85 K100/EML sidecar sold
Lynn_Keen is offline
post #8 of 8 Old Jun 12th, 2009, 9:11 am
zippy_gg's Avatar
Exclamation Re: Hesitation on Hot Days
thanks
I did just that when I had my early 99 LT and it worked like a charm. Not sure why your bike did not start after you removed the cat plug...
As suggested by others here just unplug the airbox temperature sensor but be sure to put back the cat plug as I believe you should not do both things together.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is online now
10 Days in Italy drmajor Europe 11 Jul 12th, 2007 9:15 pm
Nine Days of Beautiful Roads dmatson Ride Tales 9 May 14th, 2007 10:04 pm
Hesitation & Smoke rjhammetter K1200LT 2 Sep 14th, 2006 9:22 pm
60 Days!!! 60 Days!!! Only 60 Days!!! eljeffe Curve Cowboy Reunion 3 Jun 30th, 2006 6:12 pm
