2002 K1200LT-just purchased - BMW Luxury Touring Community
post #1 of 6 Old Jun 6th, 2009, 11:16 pm Thread Starter
Hi All,
I just purchased a repo'd LT. Unfortunately, it did not come with the user's manual so I am just making my way through the bike trying to figure out things. Question: HOW do you use the reverse on the bike. I switched it to "R" and used the throttle but nothing happens. Also, I am assuming that when you turn on the heated grips they just come on but mine don't heat up. Does anyone know the most common symptom for not working? Last question, what is the BO (could be BC) button on the right side handlebar on top and in front of the throttle?
Thanks in advance,
Perplexed Ed
Kamahalo is offline
post #2 of 6 Old Jun 6th, 2009, 11:33 pm
ipokebadgers's Avatar
Re: 2002 K1200LT-just purchased
Put the bike in neutral and start it, put the switch to the "R" (you may have to rock the bike forward or backward a little to get the reverse engaged) with the engine running press the starter button. The LT uses the starter motor for reverse. When you get where want to be put the switch back to "F" (you may have to rock it).
Enjoy the ride.
2007 R1200R
2000 K1200LT
1978 R100S (long gone, but not forgotten)
ipokebadgers is offline
post #3 of 6 Old Jun 6th, 2009, 11:40 pm
Cat Herder
tvguy's Avatar
The BC button is used to rotate through the temp, MPG, Average Speed, in the little window over on the left side of the dash.
Turn the grip heaters on... grab the grip and keep your hand on it for awhile.(while the engine is running) If they don't get hot check the fuse under the rear seat.
Tvguy
'16 R1200RT - "Golden Eye"
tvguy is offline
post #4 of 6 Old Jun 7th, 2009, 12:24 am Thread Starter
Thanks you guys! Ahhh, the infamous BC button. And here I was hitting the Mode button on the actual LCD to rotate through the functions. Must be the fuse on the heat grips. I've left them on for quite awhile and no heat. I wish I had a manual.
Another question: I know the driver seat has two adjustments. How is this done and how do you get under the seat?
Kamahalo is offline
post #5 of 6 Old Jun 7th, 2009, 5:13 am
Gold Supporter
phydough's Avatar
Kamahalo,
Glad you could join. Keep searching this site for answers to your questions and you will learn more about this bike than by reading any users manual.
Check out the Hall Of Wisdom.
Open the left side case and pull the knob to release the seat.
There is a stamped metal bracket that flips one way or the other to raise and lower the seat.
You will see the shock adjuster tucked in there too. Pull up on it to be able to adjust the setting for different loads or handling.
Good luck with the bike.
Still -
Just a dog without a bone ~...............
CCR '09 Great trip!, 2010 Miles of smiles, 2011 Can this possibly get better? 2012 a Superior trip!
2004 K1200LT - ZZ Trailer
1983 R100
BMWMOA #158807 Michiana BMW Club #122
phydough is offline
post #6 of 6 Old Jun 8th, 2009, 11:51 am Thread Starter
Thanks Phydough-much appreciated
Ed
Kamahalo is offline
Air Filter Replacement for 2002 K1200LT amills308 K1200LT 29 Jan 24th, 2015 7:49 am
Initial maintenance on used 2002 K1200LT PaulDickson_VA K1200LT 38 Mar 28th, 2009 2:46 pm
Looking at a 2002 K1200LT confish86 K1200LT 13 Oct 20th, 2008 10:30 pm
