Another Radio thread.... - BMW Luxury Touring Community
post #1 of 18 Old Jun 6th, 2009, 8:28 pm Thread Starter
shoswell's Avatar
Unhappy Another Radio thread....
Looked to the HOW for advise and found a little information back in '03. After recently washing her, the radio will not work , tape will not work either . She will not power on. Back light on the display however does. Yes, i do have a slit in one of the boots around the buttons, but it would appear that I have been lucky up to this point. Other than the obvious (fuse issue) or the dreaded she's a goner Anyone have any last words to say on the subject? or better yet, anyone have a control head for sale?
Hoss
'05- K1200LT - Gretchen
MOA, IBA, EXR & RCB and TMI
shoswell is offline
post #2 of 18 Old Jun 6th, 2009, 9:48 pm
Re: Another Radio thread....
Have you tried disconnecting the battery for ~30 minutes? This will reset the radio (pulling the fuse will not). You will need to reset the throttle position sensor after reconnecting the battery. Key on, fully open the throttle (x2), key off. Start as normal.
ďRes ipsa loquitur, sed quid in infernos dicet?Ē
Alan Stuber
2003 K1200 LTC Titan Silver
Austin, Texas
astuber is offline
post #3 of 18 Old Jun 6th, 2009, 10:04 pm
You can try to take it apart and dry it out, may get it working again. Then find a suitable soft translucent rubber cover for all the buttons and RTV it in place.
post #4 of 18 Old Jun 6th, 2009, 10:17 pm Thread Starter
shoswell's Avatar
Thanks for the suggestions. Both very good. I have the negative side off as we speak. H Hit the bottle and attempting to forget until tomorrow morning. At which time I will be taking the stingray off to accomplish the second task.... While crossing both fingers and toes mind you!
Will cry later when I post the results....
Hoss
shoswell is offline
post #5 of 18 Old Jun 6th, 2009, 11:41 pm Thread Starter
shoswell's Avatar
-1 for the battery "reset"
Hoss
shoswell is offline
post #6 of 18 Old Jun 7th, 2009, 12:00 am Thread Starter
shoswell's Avatar
O.k., hating the fact that I may have to goto the dealer, so found a 2003 stingray complete with radio off of an '03. Seeing that i'd be replacing the entire radio assembly it sound swap right over, correct? simple plug and play, right? again I have an '00. Assistance requested from the powers at be....
Hoss
shoswell is offline
post #7 of 18 Old Jun 7th, 2009, 5:54 am
They will work but there are some issues with SW versions between controllers and radios. Here is how to check.
I know if you have an old controller and a newer radio there are some current drain issues if you don't turn off the radio before shutting off the bike. Not sure if there are issues the other way around.
post #8 of 18 Old Jun 7th, 2009, 12:10 pm Thread Starter
shoswell's Avatar
Thanks for that! Just ordered the parts, I will have to wait to see what the new one says. I do however "religiously" use my battery tender. So you left me an out!
Hoss
shoswell is offline
post #9 of 18 Old Jun 7th, 2009, 2:23 pm Thread Starter
shoswell's Avatar
Call me stuid, but if I have one unit, i.e- RDU and the internals inside the stingray from one bike the "issues" should not be a problem, right? the only pcs left from the old radio will be the handle bar controls. If I read your post correct, its only when you try to combine different RDU's and Radio's. You may still refer to me as stuid. I'm a big boy! I can take it...
Hoss
shoswell is offline
post #10 of 18 Old Jun 7th, 2009, 8:47 pm
Slim's Avatar
all the radio problems, mine was fine till i left the radio on all nite and ran the battery down ive tryed every thing posted front left speaker works all the time radio or cd other speakers just work when they want mostly as soon as you turn on the key and 5-15 seconds after bike is started low voltage ? the bike starts fine tho
Slim is offline
post #11 of 18 Old Jun 9th, 2009, 2:09 am Thread Starter
shoswell's Avatar
I have cecum to the inevitable.... Replacement needed.
Hoss
shoswell is offline
post #12 of 18 Old Jun 9th, 2009, 6:56 am
Slim's Avatar
looked back thru previous owners records and he replaceded the radio less than 10000 miles ago is that all they last?
Slim is offline
post #13 of 18 Old Jun 9th, 2009, 8:48 am
KMC1's Avatar
I have about 26k on my LT and my 2nd radio just shorted out from washing the bike. So, in 26k I'll basically be on my 3rd radio, but the good news is that they usually last more than 1k
This time around I'm going to try something different. (If i decide to fix the radio instead of trading in the LT or sellling it off that is) I'm thinking about finding some kind of membrane (3M Clearshield or similar) and covering the stingray/radio controls area with it to give a layer of water protection that the stock setup is obviously lacking.
HTH
(Down to ONE BIKE - ARGH!)
KMC1 is offline
post #14 of 18 Old Jun 9th, 2009, 9:42 am
Steve_R's Avatar
Don't know what's going on with the radios, my '00 had 104K on it and was still working when I totaled it. Current '01 has 91K and it is still running just fine. You guys must be awfully hard on your equipment.
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
post #15 of 18 Old Jun 9th, 2009, 11:27 am Thread Starter
shoswell's Avatar
"Barbara" had 117K before she shut up! and I thought it was a prerequisite to drive the @*&$ out of the LT's? the view is so much better at light speed!
Hoss
shoswell is offline
post #16 of 18 Old Jun 11th, 2009, 4:14 pm
ez_rdr55's Avatar
Talking Re: Another Radio thread....
That's funny because thatís what my stealer blames every thing onÖitís all my fault.
I did have the last laugh though. When it was time to get an adventure bike, guess what I didnít buy.
EZ-RDR55
The opinions expressed herein are mine, and do not represent that of any other humanoid past, present or future on this or any other planet.
'95 H-D FXDWG
'06 Honda CRF250X
'04 KTM 450EXC
'97 Honda XR-600R
'04 K1200LT (Sold)
'07 K1200GT (Sold)
'09 Wee-Strom DL-650ABS
ez_rdr55 is offline
post #17 of 18 Old Jun 11th, 2009, 4:15 pm
TBob's Avatar
Had the same thing happen to my 03 - radio had to be replaced
TBob
09 R1200 GSA
'03 LT Impala Brown - FOR SALE
'01 KTM 520 EXC
Interested in a Kontour seat? PM me I would be happy to share my Kontour experience.
TBob is offline
post #18 of 18 Old Jun 20th, 2009, 12:37 pm Thread Starter
shoswell's Avatar
see http://www.bmwlt.com/forums/showthread.php?t=47525 for the underlying issue!
Hoss
shoswell is offline
Radio Repair Update - When is the next LT ready? Vince_nj1 K1200LT 28 Oct 2nd, 2010 2:46 pm
Unusual Radio Issue on an '02 LTE ErnieA K1200LT 20 Feb 14th, 2009 10:12 am
Motorcycle Communicator radio jimmayor007 Intercom, CB, & 2-Way Radios 0 Dec 10th, 2007 4:46 pm
A New Radio Problem? RVB1019 K1200LT 7 Sep 3rd, 2007 6:55 pm
