rusted front brake caliper pins - BMW Luxury Touring Community
post #1 of 6 Old Jun 4th, 2009, 2:51 pm Thread Starter
MACSCASTLE's Avatar
Did the search, turned up empty. Has anyone had the issue of a frozen (rusted) caliper pin? I'm talking about the pin the retains the brake pads. Liquid wrench did not help and now the screwdriver slot is shot (on the first one). Before you ask, yes, I pulled the retaining clip. Next step will be cutting the slot deeper with a dremel and heat but I'd like to hear any other experiences before I start.
Thanks in advance for your help
Mac
MACSCASTLE is offline
post #2 of 6 Old Jun 4th, 2009, 3:47 pm
Re: rusted front brake caliper pins
If it's the pin I think you're talking about, I'd get a set of vice grips on it before trying to cut it.
I'm thinking of the two long pins that screw the caliper on to the fork. Is this the one that's giving you a hard time?
Caveno is offline
post #3 of 6 Old Jun 4th, 2009, 4:08 pm
dukey33's Avatar
If I'm thinking of the right thing....I'm not sure what the screwdriver slots are for. The pin in not threaded into the caliper. I had a bit of trouble with mine too (due to corrosion) an ended up driving them out with punch and hammer. It was tricky since I had to remove the caliper from the mountings to gain access to the back side. But that did the trick for me.
-2000 K1200LT
dukey33 is offline
post #4 of 6 Old Jun 4th, 2009, 4:10 pm
Try levering/moving the pads. I presume this is an 99-2000 bike and the pads have a anti rattle spring that may have rusted to the pin. I have gotten stuck pins out this way.
post #5 of 6 Old Jun 5th, 2009, 12:01 pm Thread Starter
MACSCASTLE's Avatar
Thanks Dave. I just assumed that the pin was threaded due to the screwdriver slot. The manual isn't very clear on the removal. I already have the caliper off. I did tap the pin from the back side but not with a lot of force for fear of damaging the threads. I'll give it a try tonight and let everyone know.
thanks everyone
Mac
post #6 of 6 Old Jun 5th, 2009, 12:04 pm
The slot is there to help break the rust that is holding the pin hostage by rotating it. If it won't rotate you will just have to be persistant with penetrating oil and some percussive maintenance.
Front Right Brake Caliper Question BCVBeck RT Series 12 Mar 27th, 2009 7:00 am
Front Brake Pads vs. the Rears VRodPete K1200LT 4 Mar 6th, 2009 6:48 am
Front right brake Colin1952 K1200LT 8 May 1st, 2006 7:06 am
Is it OK just to use front brake only? JoyfulSoul K1200LT 62 Mar 5th, 2006 8:03 pm
Front Brake Lever Issue Jerrod Maguire K1200LT 2 Jan 20th, 2006 11:49 pm
