Rear Brake rotor tolerance? - BMW Luxury Touring Community
post #1 of 6 Old May 22nd, 2009, 4:08 pm Thread Starter
So according to the manual I have the rear rotor is supposed to be 6.5MM thick to be within spec.
Mine is like 4MM and I have 17k miles on it. I think my manual is wrong as the pads are worn but not gone.
So, what is the proper thickness?
BTW, the dealer told me to pound sand about the replacement by BMW. I was magically .001 MM out of spec.
They would want to do the job anyway. Since I have the rear end apart to do the weep hole I thought I would get this done as well.
mowoc is offline
post #2 of 6 Old May 22nd, 2009, 4:12 pm
Re: Rear Brake rotor tolerance?
Yup minimum is 6.5 MM for the rear rotor. I replaced mine @ 42,000 miles and it was 6.2MM. I got a free spare rotor when I bought a spare rear drive.If your was at 4 MM thick @ 17,000 I would suspect a dragging rear caliper. My first set of rear pads went @ 30,000
I forgot to add the new one was right @ 7.0 MM
post #3 of 6 Old May 22nd, 2009, 5:21 pm Thread Starter
Hmmmm, I wonder if I measured it wrong? No matter as I was going to replace the rotor anyway as I was tired of the cowbell so no biggie there.
how do I check the caliper to ensure it is not draging?
mowoc is offline
post #4 of 6 Old May 22nd, 2009, 7:57 pm
Something is wrong with your measurement. To grind that much off the rotor in 17K and not have gone through at least one set of pads tells me that your wrong about what is left.
The reason the rotor clangs is because it is free to move and you hear a metal to metal sound. To hear that sound there has to be movement.
I had to change mine a few years ago and it would only make noise at slow speed hitting bumps. As soon as the rear brake was applied at all it did not make any noise.
2001 Black LTC
2015 Blue R1200GSA
jackd is offline
post #5 of 6 Old May 22nd, 2009, 8:47 pm
seahabit's Avatar
To check for brake drag, or anything else, use your five senses. Listen, look (check mileage too), smell, taste (probably not necessary), and most important, feel the disc when you stop riding. The heat you feel will give you some parameters to work with.
The LT rear brake is a pain in the rear.I use water to flush the brake dust off and to quiet the squeal. Make sure the disc is cool before putting water on it You may be able to "just clean it up" with water and then apply brake grease to the pads (brake disassembly required). It worked for me, I hope for you also.
seahabit is offline
post #6 of 6 Old May 23rd, 2009, 9:05 am
If you suspect the rear brake is dragging, don't just grab it when you check it! Put some water on your finger tip and "dab" the rotor quickly. If it sizzles, you have a problem ... and you don't have a burned finger!
Tech Session in Easton, Pa. on March 21 firstbeemer North East 61 Mar 11th, 2011 1:55 pm
No rear brake??? JCarver K1200LT 9 Aug 13th, 2007 10:36 am
Hot rear brake rotor kamike K1200LT 10 May 1st, 2006 10:18 am
Drilled rear brake rotor???? DRothermel K1200LT 10 Apr 7th, 2006 1:01 pm
