Replace starter relay for 1999 Lt - BMW Luxury Touring Community
post #1 of 6 Old May 19th, 2009, 6:21 pm Thread Starter
I need help in replacing the starter relay on a 1999 K1200LT. If any one has an idea please let me know.
Kellermark is offline
post #2 of 6 Old May 19th, 2009, 8:37 pm
Re: Replace starter relay for 1999 Lt
There is a kit available from the dealer which upgrades it to a later version, one that has a voltage sensing circuit to keep the relay from engaging when the battery voltage is too low, and fusing the contacts together. That kit has installation instructions in it.
If you do not want to do the kit, and use a stock early relay, it is in the electrical box under the fuel tank. You have to remove the tank first, then the cover on the box.
If you do not have a service manual, you should look at getting one, either the BMW one or the Haynes (Chilton?), which is cheaper.
post #3 of 6 Old May 19th, 2009, 10:00 pm
It is right in here:
Name:	Radiator exhaust.jpg
ID:	23077   Click image for larger version
Name:	Old relay.jpg
ID:	23078   Click image for larger version
Name:	New relay.jpg
post #4 of 6 Old Jul 7th, 2016, 10:49 am
so, where does the green wire connect to? The instructions I received with the kit were all in German; and the photos were not clear.
AnonEMouse is offline
post #5 of 6 Old Jul 7th, 2016, 12:16 pm
sailor's Avatar
You can download the PDF file of these instructions in ENGLISH (with photos included) by clicking on the PDF symbol just below item 1 in this MAX-BMW parts fiche page here.
NOTE: you need to scroll down the right side pane of parts list to see PDF file link:
MAX BMW Motorcycles - BMW Parts & Technical Diagrams - K1200LT 99-04 (89V3)
About the GREEN wire:
You can use either GREEN wires coming out of ABS Warning-relay as they are both switched power from same source (ignition switch).
John (Montreal, CANADA)
sailor is offline
post #6 of 6 Old Jul 7th, 2016, 7:59 pm
MountianMama's Avatar
Just make sure you crimp with pliers, just because that little black connector clicks does not mean that it is crimped.
Eric von Laue
3Cyl Kawa ( a long time ago)
450 Yamaha Seca ( maybe it was a Maxim )
1100 Honda Magna
650 Honda XR ( to Guatemala and back)
1990 Honda PC800 ( Mountain Mama )
2000 BMW 1200LT ( Maxamillion )
Keep the rubber side down
MountianMama is offline
Starter Relay kevincook K1200LT 53 Mar 19th, 2016 10:40 pm
Electronic Starter Relay Diagnostics mmalof K1200LT 3 May 18th, 2009 7:25 pm
Starter relay upgrade Justtp K1200LT 1 Mar 30th, 2007 8:52 am
Starter Relay - Puzzled by dealer response Tim_in_NJ K1200LT 4 Sep 22nd, 2006 3:56 pm
starter relay ltride K1200LT 6 Aug 30th, 2006 12:26 am
