2003 Commsystem Aux not working - BMW Luxury Touring Community
post #1 of 8 Old May 15th, 2009, 11:36 pm Thread Starter
JohnR's Avatar
I used to be able to listen to my MP3 through the Aux input on the commsystem, but it has stopped working for some reason.
I'm not sure what happened, but when I connect my MP3 via the mini-jack cable, I get no sound.
Is there a connection under the stingray that might have come loose?
Could it be corrosion?
Is there a setting on the commsystem that needs to be reset?
Any help appreciated.
John Robinson
Shawnee, KS
2003 K1200 LTE
JohnR is offline
post #2 of 8 Old May 16th, 2009, 12:22 pm
KJN
KJN's Avatar
Re: 2003 Commsystem Aux not working
John,
I have a 2000KLT with a Commsystem. You might try the spkr/ext push button next to the aux jack.
Kimble
KJN is offline
post #3 of 8 Old May 17th, 2009, 8:23 pm
billr's Avatar
Did you possible push the mute button???
Bill Reitz
Surf City, USA
'06 Storm Gray Metallic LT
billr is offline
post #4 of 8 Old May 18th, 2009, 5:18 pm Thread Starter
JohnR's Avatar
Are you kidding me? How stupid do you think a person could be?
I write these questions only after trying all the normal things to get things to work. I expect the member here to give me reasoned advise or none at all.
And by the way... that's a big No on the Mute.
Also, Pushed the Speaker/intercom button back and forth just like I did when it used to work fine... last year.
John Robinson
Shawnee, KS
2003 K1200 LTE
JohnR is offline
post #5 of 8 Old May 18th, 2009, 9:16 pm
Old Dawg
scottydawg's Avatar
Wow, he is just trying to be helpful and you have to answer like this, sounds like you need to go take ride and relax.
Scott
Sacramento CA
HDDC Posse
''03 Ducati ST4S with ABS - '12 KTM 500EXC - '19 BMW GS/A
(Jessica Focker's) '15 BMW S1000RR - '17 KTM 350EXC-F - '09 Yamaha XT250
Some of the most asinine things people do are typically preceded by the two words "Watch this."
scottydawg is offline
post #6 of 8 Old May 19th, 2009, 9:33 am
KJN
KJN's Avatar
Sorry John,
I'll do some more research and try to post something more helpful to you.
Kimble
KJN is offline
post #7 of 8 Old May 19th, 2009, 6:45 pm
blkswan's Avatar
I had the same problem on my first 03LTE. The intercom is made by J & M, I spoke with John at J&M and he suggested I send it back to them for repair. They replaced a relay inside the unit shipped it back to me and didn't charge me. I would contact them directly to see if they can help you.
Good Luck
Will Hedgspeth
03LTE
blkswan is offline
post #8 of 8 Old May 19th, 2009, 7:39 pm
BigGeo's Avatar
Dear John,
Understanding that you are from KS and reading your response as to "how stupid you may be", it is apparent that we under estimated your stupidity. Try placing your MP3 player closer to your ear (which is connected to your head) and you will find them both firmly tucked up in your butt.
BigGeo is offline
Installing Aux cable in Stingray graydude K1200LT 71 Oct 20th, 2014 10:09 am
Things I've relearned working on my LT BecketMa K1200LT 9 Sep 17th, 2008 1:45 pm
CommSystem Newbee Question hmbmartin K1200LT 7 May 11th, 2007 11:59 am
Aux tank Help RMW K1200LT 7 Apr 8th, 2006 9:56 am
