brake fail and rapid flashing warning light - BMW Luxury Touring Community
post #1 of 4 Old May 3rd, 2009, 3:51 am Thread Starter
Hi have had a search cant find anything can anyone help please
Riding my Servo LT at 90 brake fail light comes on and I try the brakes and nothing. I cost to a halt reset and after 50m they fail again. I check fluids and switches all seem fine.
At one point the brake lights were stuck on but now are fine.
servo sounding all the time gets louder when brakes applied
Get recovered to BMW and they plug in and it in. Pressure to high in front system is found
Hed checks levels and switches
Tech guy pushes back front brake pistons and the brakes reset and work. He says it must be sticking front pistons.
So I ride home and srtip the pistons out front and rear and they are all fine I can push them back in with my fingers.
So as you turn on brake fail light flashes slowly for a few seconds and then flashes rapidly and sometimes the servo sounds.
so any ideas please
itsallpoo is offline
post #2 of 4 Old May 3rd, 2009, 3:54 am
Re: brake fail and rapid flashing warning light
I had the same thing a little while ago. The battery was dieing.
Morley is offline
post #3 of 4 Old Sep 17th, 2009, 10:06 am Thread Starter
Hi did your brakes actualy fail due to a failing battery ?
post #4 of 4 Old Sep 17th, 2009, 10:20 am
The servo system must have enough available current to run the pumps up to pressure. A low voltage will cause that to fault out. The BMW test should have been more conclusive as to the cause of the problem. Typically it is in the ABS unit (electronic brain) and not a caliper issue.
Has the system been flushed with new fluid regularly? That can have an impact on internal faults. The brake light switches (handle bar and foot) feed the electronic ABS brain which then drives the brake light relay. If one of these is making contact all the time that can overheat the servo (and cause the brake light to stay on). Make sure they both are adjusted correctly.
