Do I need a new amp? - BMW Luxury Touring Community
post #1 of 9 Old May 1st, 2009, 8:10 am Thread Starter
PrimePower's Avatar
Just picked up an 05 LT yesterday. Well it runs great as I had a 3 hour ride but the right rear speaker doesn't work. After taking it apart, and checking the speaker and wiring I searched the forum and unplugged my battery. That worked for a while. Then, back to no right rear speaker. So my questions are: do I need a new amp? where is the best/cheapest place to buy one? where is the amp located? Thanks
PrimePower is offline
post #2 of 9 Old May 1st, 2009, 8:17 am
MikeERideWNC's Avatar
Re: Do I need a new amp?
Sounds like you are loosing the rear channels in the head unit.
But don't worry, BMW antisipated this and built a surplus.
You will be able to replace the radio for around 600.00 if you do the labor yourself.
Do a search and you will find some other affordable options.
Also make sure all of your connections are clean and making a good connection.
BMW radios...
I bought mine from Chicago BMA for 500.00 a few years ago.
Installation is is quick and painless. It is the only option for keeping the bar controls.
Sorry for your luck.
Visit
MikeERideWNC is offline
post #3 of 9 Old May 1st, 2009, 9:21 am Thread Starter
PrimePower's Avatar
So the amp is built into the radio. OK. Connections are good as it will work if I disconnect power, but later shuts off. So is it the CD player part or is there another HU somewhere? I can do the labor, but man that is pricey. Might wait till they all go out.
post #4 of 9 Old May 1st, 2009, 9:53 am
JPSpen's Avatar
Might not be the amp.
There are two sets of connections, One on the left side of the stingray. and one at the top box under the passenger seat.
Check clean and di-electric those connections and I'll bet you'll find your problem.
The radios are not nearly as troublesome as those connectors.
91 R100GS "It'sNotAMoneyPit"
JPSpen is offline
post #5 of 9 Old May 1st, 2009, 10:21 am
Vince_nj1's Avatar
I just changed mine on my 03. Both rear speakers were out. My connections were fine. You can try all the creative suggestions listed here, but in the end you will most likely need to buy a new radio. The radio and CD are one unit. Older tape deck models can be repaired, but the CD unit in the 2003 generation can not.
I'm not sure I would describe the installation as quick and painless. It is time consuming and requires that you remove all of the plastic to swap it out. If you haven't done that yet, it can be a little intimidating. There are probably 30 + screws.
One word of advice, the antenna is connected to the radio on the back and you will need to release the little lock that holds the connection before removing the radio. When I removed mine, I broke that connection and didn't realize it. It was a clean break. When I got the new radio the antenna wouldn't go into the new radio, only after inspection did I realize that the old clip was still attached to the antenna. You should be able to see it in the top right of this picture.
I lived with just front speakers for about 1 year, I finaly broke down and bought a new radio and I am glad that I did. If you are going to tear into your bike you might want to change your airfilter and possibly fuel filter while your at it. I changed my airfilter, but didn't want to mess with a fuel filter.
Good luck
Vince - 2003 LT.
Vince_nj1 is offline
post #6 of 9 Old May 1st, 2009, 12:01 pm
To me with a BMW quick and painless is two hours.
Then I about a month later I tore it all apart and added XM with the convertor in placed in the stingray.
If you have checked all the connectors, then you are familar with taking the plastic off.
It is much easier your second, third, forth time.
I agree... Replace the air filter while you have it apart.
I think the peplacement BMW is the best route, however the cost is to high.
Make sure to seal up the stingray when you reassemble.
Visit
post #7 of 9 Old May 1st, 2009, 1:32 pm Thread Starter
PrimePower's Avatar
Thanks for the advice. Because I have just bought the bike, I'm going to wait and just go with three speakers for now. Sucks, but don't have $500 just laying around right now. But when I do, where is the best source for these.
post #8 of 9 Old May 1st, 2009, 4:23 pm
Steve_R's Avatar
If you lucky, ltparts.com, beemerboneyard, and you dealer.
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
post #9 of 9 Old May 1st, 2009, 6:29 pm
Old Slow Guy in A Fast Car
katnapinn's Avatar
Also watch E-Bay there's a lot of LT parts on it.
Stevie Shreeve
katnapinn is offline
