Sticky front right caliper - BMW Luxury Touring Community
post #1 of 12 Old Apr 27th, 2009, 8:20 am Thread Starter
My front right caliper is sticky which produces a rubbing sound and sometime (but not always) a burning smell. My front pads are pretty thin and due to replacement soon but I am wondering if putting brand new pads will not make the problem worse. Any suggestion in fixing this sticky caliper problem? Anyway that I can lubricate my caliper piston so it retracts more easily or do I really have to change the caliper?
Alain
Vieux motard que jamais
Alpac is offline
post #2 of 12 Old Apr 27th, 2009, 8:27 am
Reid's Avatar
Re: Sticky front right caliper
Had a stiking rotor on my car...heat caused the lube to burn and wouldn't push the other side of the rotor away from the pad (this is a Lexus rotor) and had to disassemble it and clean out the gunk. Based on that experience I suspect you might need to do something similar if the problem is caused by something like that. Only a guess on my part.
Reido
K1600GTL...Blue Metallic
USMC 1971-1975
Ham Radio Call: W0FVR
"The right to be heard does not automatically include the right to be taken seriously."
--H.H. Humphrey
Reid is offline
post #3 of 12 Old Apr 27th, 2009, 8:30 am
Old Slow Guy in A Fast Car
katnapinn's Avatar
Pull the caliper and remove the pads. Then remove the "pucks" (2 on each side) & clean the calipers with "brake clean". Next use a VERY fine sand paper (800 grit or finer) and clean the pucks. You can also use a scotch bright pad but clean lightly as it is more abrasive. Then put it back together. If it still sticks then you will need to rebuild the caliper.
Stevie Shreeve
katnapinn is offline
post #4 of 12 Old Apr 27th, 2009, 8:36 am Thread Starter
OK will try that Thanks
Alain
Alpac is offline
post #5 of 12 Old Apr 27th, 2009, 8:51 am
grahamw's Avatar
If you remove the pucks you will have to bleed the system. You can clean the pucks in situ if you are careful and do not push them all the way out you will expose enough to get at any exposed / dirty surfaces. Make sure the caliper surfaces that the pad can contact do not have any build up on them as that could also prevent the pad moving back.
Regards
Graham Wintersgill
2001 K1200LT
1995 K75RT now deceased
grahamw is offline
post #6 of 12 Old Apr 27th, 2009, 8:54 am
deanwoolsey's Avatar
I would suggest new piston seals as long as you have it apart. Since you'll need to bleed the system after the work you may as well do both sides at the same time. Many times a problem with one side means the other may not be far behind. A little extra effort and some caution are always good with brake systems since the job they perform is the most important one on the cycle.
deanwoolsey is offline
post #7 of 12 Old Apr 27th, 2009, 9:06 am Thread Starter
Thanks for all the advises folks. I will replace the pads by the same token. My LT is a 99 model so no linked brake lines which is good news as far a bleeding the brakes. Any suggestion for the pads beside OEM? I found this http://www.beemerboneyard.com/cl2430sbk5.html
Are these good pads?
Alain
Alpac is offline
post #8 of 12 Old Apr 27th, 2009, 9:14 am
Reid's Avatar
Looks like you got some very good advice on the rotor problem. The linked brakes wouldn't be a problem bleeding even on the newer LT's for the front brakes....it's the rear braking system that gets FAR more complicated. Good luck.
Reido
USMC 1971-1975
--H.H. Humphrey
Reid is offline
post #9 of 12 Old Apr 27th, 2009, 9:23 pm
I had a similar problem, i replaced the callipers with reconditioned ones, it turned out to be that the pads were sticking, i had EBC replacements, the friction surface was bonded on slightly out of square, this combined with a bit of heat under heavy braking was causing things to tighten up/sieze, issue went when pads replaced, if you have a build up of crud it could cause the same issue, probably not this!!, but worth a check.
Regards
Stevie
stevie1 is offline
post #10 of 12 Old Apr 28th, 2009, 7:05 am
katnapinn's Avatar
Regards
No the pucks are between the pistons and the pads the just fall out ,no need to bleed the system unless you remove the pistons.
Stevie Shreeve
post #11 of 12 Old Apr 28th, 2009, 11:36 am
LAF
LAF's Avatar
Yep or you are cleaning them and you pop one out DAMHIK.
Use wood spacers to extend them out and clean them. It is a maintenance task I do every year to see the condition of things and clean the pucks.
Lee
17.5 R1200 GSW Black Low
ATGATT I am breathing proof.
BMW MOA #135959
LAF is offline
post #12 of 12 Old May 3rd, 2009, 8:46 pm Thread Starter
I removed both front calipers today and took the old pads out. I pressed the brake lever to get all brake pistons out to their almost max and cleaned the calipers and pistons with brake cleaner. I lubricated the sides of the pistons with some drops of ATF oil and pushed them completely back by using the old pads and a clamp. Put new pads on, put the calipers back and went for a short ride. The brakes worked like a charm. No more rubbing noise and no more sticky pads. I went for a 200 miles ride today and no problem anymore.
Alain
Alpac is offline
Oil on my front brake caliper phoneix K1200LT 3 Apr 27th, 2009 2:07 pm
Front Right Brake Caliper Question BCVBeck RT Series 12 Mar 27th, 2009 7:00 am
Front brake caliper problem -check all pads Waz K1200LT 0 Jun 10th, 2008 2:24 pm
2005 LT Siezed Front Brake Caliper (not the pistons!) mcousin K1200LT 5 Aug 23rd, 2007 9:29 pm
Front Brake Pad R&R (looong story) was K1200LT 1 Sep 3rd, 2006 10:48 pm
