Requesting pic or descrptn of ABS bleed wrench - BMW Luxury Touring Community
post #1 of 10 Old Apr 23rd, 2009, 11:57 am Thread Starter
CharlieVT's Avatar
Could I trouble anyone (John Z.) for a pic or description of the special tool used to bleed post-02 ABS.
I understand a normal 7mm wrench can be used, but we have a tech session coming up this wkend and it sounds like there'll be a couple or three bikes to do.
I could cut 'n weld up the tool pretty quick if I knew what it looked like.
A pic or even a brief description would be mucho appreicated.
CharlieVT is offline
post #2 of 10 Old Apr 23rd, 2009, 2:38 pm
Daveh's Avatar
Re: Requesting pic or descrptn of ABS bleed wrench
Is this what you are looking for; http://www.bmwlt.com/forums/attachme...chmentid=20671
2003 K1200LTC Titan Silver
BMWBMW, BMWMOA, AMA, IBA
Daveh is offline
post #3 of 10 Old Apr 23rd, 2009, 6:13 pm
Good job Dave.
Curtis the one on the right is for the early Integral ABS units that had the cross ports on the side of the unit. Not worth the effort to make as it only covers a very small drip or two of fluid. I have found the other one to be useful on half of the the other four bleed ports. It is just a 7mm box end bent at 90 degrees and a square drive added. I have done the whole thing with just a regular 7mm wrench. If you are going to make one - it would be nice if there was just a little bit of a pivot near the box end to help get around frame parts. Not sure how you would do that though.
post #4 of 10 Old Apr 24th, 2009, 7:16 am
Old Slow Guy in A Fast Car
katnapinn's Avatar
Originally Posted by jzeiler
Good job Dave.
Plus 1 on just a 7 mm box end. I slip the wrench on then push on the clear tubing and your ready to bleed. That will be the brakes and your knuckles if your not careful.
Stevie Shreeve
katnapinn is offline
post #5 of 10 Old Apr 24th, 2009, 1:43 pm
joegottberg's Avatar
FWIW I made my own by bending an old Craftsman box wrench.
2005 KLT "Old Blue"
Bruno the "Bugg"
joegottberg is offline
post #6 of 10 Old Apr 25th, 2009, 9:29 am
LAF
LAF's Avatar
While too late for Curtis, could you post a pic of your "bent wrench"?
TIA
Lee
17.5 R1200 GSW Black Low
ATGATT I am breathing proof.
BMW MOA #135959
LAF is offline
post #7 of 10 Old Apr 25th, 2009, 1:46 pm
Gang,
I have the dreaded leaking ABS pump/motor assembly housing problem. I'm told by two different dealers that they will not, and cannot rebuild these units because the factory does not allow. Apperantly, there is no seal kit available. I'm also told that the only solution is to buy a new $2300 unit. Could this be true? Has anyone located and replaced all the seals on thier own unit?
I'm surprised and disgusted with my LT for the first time if a $2300 unit can't be rebuilt.
Marc
Marcslt is offline
post #8 of 10 Old Apr 26th, 2009, 7:22 am
Steve_R's Avatar
Lee510 has had his unit rebuilt and as far as I know, to date it still isn't functioning properly. Know to another question, AFAIK the car dealerships will not put a rebuilt or even rebuild and ABS unit for today's cars. Why should your motorcycle be any different?
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
post #9 of 10 Old Apr 27th, 2009, 12:49 pm
TIA
Nothing Fancy, but, it worked for a "hacker" like me
Sorry about the picture quality, chose the BlackBerry over the I-Phone
Joe
Name:	Bent wrench1.jpg
ID:	22792   Click image for larger version
Name:	Bent Wrench 2.jpg
ID:	22793   Click image for larger version
Name:	Bent Wrench 3.jpg
2005 KLT "Old Blue"
Bruno the "Bugg"
post #10 of 10 Old Apr 27th, 2009, 1:10 pm
LAF
LAF's Avatar
Joe
Thank you and it will be good enough for this hacker also.
Lee
BMW MOA #135959
LAF is offline
Tech Session in Easton, Pa. on March 21 firstbeemer North East 61 Mar 11th, 2011 1:55 pm
Brake Flush '06 ABS II Hilton K1200LT 15 Dec 19th, 2010 12:01 pm
ABS Bleed Tool Mugszy Canada 4 Jan 26th, 2009 5:10 pm
