Clutch/Slave Master Cylinder ??? - BMW Luxury Touring Community
post #1 of 7 Old Apr 19th, 2009, 2:10 pm Thread Starter
Silverhair's Avatar
I've been having trouble with sticky shifting.
I checked the linkage & replaced bad bushings & lube. Good stuff, but no difference.
I then bled & flushed the clutch using a speedbleeder & the Sayegh videos for reference. For the first 25 miles of my test ride, all was well. Then in some stop & go riding, it started to stick again. When it would stick, double-clutching seemed to help most of the time. So it seems to me, I probably have a hydraulic clutch problem.
If so, the trick here is isolating this (master vs slave). My clutch lever seems to make a noise when I pull it -- sounds like a soft clicking, sort of like a bellows compressing & expanding. I don't know if this is normal...
Anyway, any ideas? I wonder if the master cylinder needs a rebuild/replacing? I also could change the trans lube - its only got about 10k on it.
2005 Kawasaki Z750S
1999 BMW K1200LT
1972 Honda CL350
BMWMOA # 139202
Silverhair is offline
post #2 of 7 Old Apr 19th, 2009, 2:53 pm
vernvernvern's Avatar
Re: Clutch/Slave Master Cylinder ???
My '03 clutch lever makes no noise, click or otherwise. That may be your culprit.
Just my 2 cents worth.
Vern
78 years young!
Converted HD rider.
Vern
vernvernvern is offline
post #3 of 7 Old Apr 19th, 2009, 2:58 pm Thread Starter
Silverhair's Avatar
Vern,
Thanks for the word. I didnt think it sohld make any noise as well.
2005 Kawasaki Z750S
1999 BMW K1200LT
1972 Honda CL350
BMWMOA # 139202
post #4 of 7 Old Apr 19th, 2009, 3:30 pm
sperra's Avatar
There is a rebuild kit fot the clutch master cylinder. Can't remeber the part #. Check the adjustments for free play, in the clutch lever. BMW calls for 1/4 turn beyond no play.
Any slipping when accelerating in3rd gear?
sp
sperra is offline
post #5 of 7 Old Apr 19th, 2009, 3:38 pm
Question Re: Clutch/Slave Master Cylinder ???
sp
Sp,
That's news to me. I didn't think there was any adjustment on the lever other than for hand/finger size!
Vern
78 years young!
Converted HD rider.
Vern
post #6 of 7 Old Apr 19th, 2009, 4:23 pm
Old Slow Guy in A Fast Car
katnapinn's Avatar
The clicking sound my be the CC micro switch. I hear mine from time to time.
Stevie Shreeve
katnapinn is offline
post #7 of 7 Old Apr 19th, 2009, 9:52 pm Thread Starter
Silverhair's Avatar
I've had no slipping at all - and I'm grateful for that!
The noise the thing makes when pulling the clutch is definately not the faint little click you hear as when you pull the brake lever & hear the brake light switch click. This is a soft click, almost a breathing sound.
I just re-bled it (speed bleeder and a one man brake bleeder hose) and saw lots of super small bubbles for a while. I kinda suspected this would happen. Got them all out so I can see if I have the same experience again on a road test, as I did earlier today.
If I need to work the master cylinder, I'll compare the rebuild kit cost vs the new unit price to see if the juice is worth the squeeze. Anyone have experience & knowledge of costs here?
2005 Kawasaki Z750S
1999 BMW K1200LT
1972 Honda CL350
BMWMOA # 139202
master cylinder leak gpolakow K1200LT 5 Sep 24th, 2008 12:18 am
Rear Master Cylinder Brake Line Placement hallzee K1200LT 0 Aug 2nd, 2008 12:11 pm
Wanted: brake and clutch master cylinder lids/covers wildwestrider K1200LT 3 Apr 23rd, 2008 11:39 pm
New Twist on the Slave Cylinder robasay K1200LT 2 Jun 29th, 2007 12:32 pm
Disabling the locking Gas Cap justincase K1200LT 25 Apr 15th, 2006 9:39 am
