DDMTuning HID Kits? - BMW Luxury Touring Community
post #1 of 5 Old Feb 16th, 2009, 12:20 pm Thread Starter
DDMTuning HID Kits?
For a 2000 K1200LT.
Should I order the upgrade to 55W ballasts (option $15.00) or use the std. 35W ballasts ?
Low beam H7 ?
High beam H3 or H11 ?
Sounds like the low beam is plug & play?
Has anyone installed the high beam from DDM is it a plug & play or a cut, file, grind out head light housing and glue the light in?
Jim Campbell
North Dakota
Jimbo3 is offline
post #2 of 5 Old Feb 16th, 2009, 12:37 pm
bowdon's Avatar
Re: DDMTuning HID Kits?
Originally Posted by kb0lxx
For a 2000 K1200LT.
Low beam H7 ?
Jim Campbell
North Dakota
I was also looking at a low beam kit for my LT. I heard that the low beam install required no plastic to be removed, just wanted confirmation before I order a kit.
Hopefully someone will answer these questions.
Bowdon
bowdon is offline
post #3 of 5 Old Feb 16th, 2009, 12:49 pm
deanwoolsey's Avatar
You have to drill a hole in the back headlight cover which is attached with a metal clip. It's no big deal if you have a drill and a good spade bit or step bit. I have the 35 watt from DDM and it's all I need. Personally I wouldn't do the high beam but consider getting the dual lamp kit for about an extra $20.00 you can have a spare bulb, ballast, and igniter. Yes, it's pretty much plug and play. The hardest part for me was installing the bulb itself do to working inside the nose cone where it's hard to see. I did pull the right panel to zip strip the ballast and igniter to the side of the air intake but you could do it without removal.
deanwoolsey is offline
post #4 of 5 Old Feb 16th, 2009, 1:47 pm
sheldan2's Avatar
I have the 35w hi and lo hid bulbs because 50% of my riding is at night, I can easily show people in cars in front of me their shadows at midnight when they don't like to move over when I am behind them... I wouldn't worry about the 55w
sheldan2 is offline
post #5 of 5 Old Feb 16th, 2009, 10:21 pm
These are the specs for the stock lights according to the service manual 1999-2003:
Technical Data K 1200 LT:
Lights:
Headlight: H7 tandem headlight with free-form reflector and manual beam throw adjustment
Bulbs:
High (main) beam headlight: H3 halogen bulb, 12 V 55 W, asymmetric
Low (dipped) beam headlight H7 halogen bulb, 12 V 55 W asymmetric
When you find the correct upgrade please post the purchase details, specs and part number(s). I'm interested in upgrading mine as well.
Jose Gonzalez
2001 K1200LT
cjgonzo1 is offline
High idle, lower mpg after HID install pburhoe K1200LT 15 Nov 22nd, 2008 2:30 pm
HID Kits Hollywood Lighting 30 Mar 14th, 2008 6:51 pm
Happy with HID, just installed Motolights Crestwood330 Lighting 5 Jan 4th, 2008 6:41 am
