Brake Squeal? - BMW Luxury Touring Community
post #1 of 16 Old Feb 16th, 2009, 8:41 am Thread Starter
Brake Squeal?
Folks. My new to me 2001 has an absolutely horrendous screech when the rear brake is applied. Funny thing is, it's dead quiet when the brakes are applied only at the front lever. I thought these were linked brakes, so the rear gets applied along with the front when the front brake is applied. But it is dead quiet using the front brake lever and ear splitting when the brake is applied at the foot pedal.
I removed the rear brake pads, cleaned and lubed the pins and the back of the pads, but that made only a marginal difference.
Any help out there?
Thanks.
steveboutilier is offline
post #2 of 16 Old Feb 16th, 2009, 9:52 am
c00k1e's Avatar
Re: Brake Squeal?
Quite common. Use of rear pedal and hand leaver put different amounts of pressure on the pads.
One solution is to use EBC FA244HH sintered pads and modify them as detailed HERE
c00k1e is offline
post #3 of 16 Old Feb 16th, 2009, 9:52 am
Mugszy's Avatar
Re: Brake Squeal?
My 06 was not as bad as you describe but the fix was replacing the disc from a floating 12 stud to a 5 stud which was done under warranty. I am not sure why this would not work for you but I would bet that others will pipe in to share their solutions.
Mugz
BMWMOA - #45711
2006 K1200LT - Blue Baby
2003 R1150GS - Yellowbird
1981 R100CS - Sadly gone
1986 K100RS - In the past
Mugszy is offline
post #4 of 16 Old Feb 16th, 2009, 12:52 pm Thread Starter
Re: Brake Squeal?
Thanks! Just ordered a set of the EBC's and I'll let you all know how it works out.
post #5 of 16 Old Feb 16th, 2009, 3:05 pm
Old Slow Guy in A Fast Car
katnapinn's Avatar
Re: Brake Squeal?
My 2000 LT did the same thing. I put the "Premium BMW Pads" on and the noise went away. I'm on my 3rd set now with no noise ever.
Stevie Shreeve
katnapinn is offline
post #6 of 16 Old Feb 16th, 2009, 3:37 pm
ibbones's Avatar
Re: Brake Squeal?
Come on...no one has said it yet? "Loud brakes save lives!"
"BONES" <///><
2018 R1200RT
2002 K1200LTC--- Belle
ibbones is offline
post #7 of 16 Old Feb 16th, 2009, 6:40 pm
Mugszy's Avatar
Re: Brake Squeal?
You want them to hear you BEFORE you have to apply your brakes but now you're talking Harley so that is no solution! On the otherhand, you can always turn up your radio speakers.
I SAY, TURN UP YOUR RADIO. 8Amazing what we have to do as we get older.
10Mugszy
BMWMOA - #45711
Mugszy is offline
post #8 of 16 Old Feb 18th, 2009, 3:52 am
shalei's Avatar
Talking Re: Brake Squeal?
G'day everyone,
I have a 2001 LT and when I first got it I had the usual (same as everyone else) brake squeal and replaced the pads with EBC (same as everyone else). That worked perfectly.
Recently a set of EBC just wore out and needed to be replaced.
I looked closely at the nearly new original BMW pads. I decided that the squealing noise can only be caused by the pad dust dragging across the face of the rotor. So I made a vertical cut with a hack saw blade down the centre of the face of the pad through the pad material until the blade touched the backing plate to remove the dust from the rotor as it was produced. I have now done about 10,000Km with the modified pad and guess what - no squealing.
For what its worth. Cheers.
Shane,
Bright,
Australia
2001 K1200LT Metallic Mauve - Merlot. (Deceased)
2003 Ducati 999 Testastretta, Red (of course) - Demos.
2005 Cagiva Xtra Raptor 1000, Bat Black - Rex.
2006 Cagiva Raptor 650, Red - Gina (sold)
Bike Trailer for Merlot - Cabernet.
2007 Ducati 1098S Tricolore
2015 KTM 1190 Adventure R
2012 Yamaha Tenere XT660Z
2015 Yamaha MT09
shalei is offline
post #9 of 16 Old Feb 18th, 2009, 2:22 pm
c00k1e's Avatar
Oz Brake Squeal Solution
If that turns out to be the best solution, this needs advertising a bit more
Originally Posted by shalei
G'day everyone,
c00k1e is offline
post #10 of 16 Old Feb 18th, 2009, 6:08 pm
Re: Brake Squeal?
Mugz
I plan on doing this when the weather warms up a bit. Figure I'll have the dealer put on a new front tire at the same time so they at least are getting some cash from me while the bike is there (although I do have a $100 dollar gift card from this dealer, so it won't be quite as much).
Tony
2006 K1200LT "SNOB"
IBA 35008
"I don't like repeat offenders, I like dead offenders" - Ted Nugent
living_free is offline
post #11 of 16 Old Feb 19th, 2009, 9:22 pm Thread Starter
Re: Brake Squeal?
That vertical cut down the center of the pad... is that relative to the way the pad sits on the bike, or in the palm of your hand? I guess a better way of saying that would be, was that along the long edge, or the short?
post #12 of 16 Old Feb 23rd, 2009, 3:50 am
shalei's Avatar
Re: Brake Squeal?
I made the cut vertical as it sits in the caliper i.e. the short way.
Shane,
Bright,
Australia
2015 Yamaha MT09
shalei is offline
post #13 of 16 Old Feb 23rd, 2009, 3:55 am
shalei's Avatar
Re: Brake Squeal?
I guess a better way to describe it is imagine a line directly out from the centre of the hub (or axle) though the centre of the pad. Then cut along that line through the pad material to the backing plate.
cheers
Shane
Shane,
Bright,
Australia
2015 Yamaha MT09
shalei is offline
post #14 of 16 Old May 11th, 2009, 4:56 pm
SteveoChicago's Avatar
Re: Brake Squeal?
Thanks for that tip Shane. I have a 00LT and both front and rear squeal but the fronts more than the rears. I replaced the breaks last summer and have to listen to the squealing each time I stop. I will try your suggestion next weekend and let the forum know how it turns out.
Thanks again!
The biggest risk of all is not taking one
SteveoChicago is offline
post #15 of 16 Old May 11th, 2009, 8:25 pm
Human Behaviour Analyst
Re: Brake Squeal?
Like the sound of that solution from Shane down under.
Some hard to sneak up on my buddies on the Goldwings at the stop lights this way ....
wkclark is offline
post #16 of 16 Old May 12th, 2009, 10:16 am
deanwoolsey's Avatar
Re: Brake Squeal?
With the LTs there is the issue of the defective rear rotor which I imagine contributes to many of these brake noise issues, particularly the "cowbell effect". However typical brake squeal normally is a secondary noise caused by the pad backing vibrating against the piston or on an LT the pucks. There are several products available to apply between the two surfaces to eliminate the noise. I use never seize compound applied to the piston face.
deanwoolsey is offline
BMW K1200 LT Brake Squeal bvick K1200LT 5 Jan 2nd, 2008 9:47 pm
NEW Brake Squeal!!!! dezrat57 K1200LT 0 Feb 15th, 2007 10:31 pm
BMW Service Bulletin for Rear Brake Squeal Serebigal K1200LT 4 Apr 8th, 2006 10:40 am
Rear brake squeal linked to front brakes? Vince_nj1 K1200LT 19 Apr 2nd, 2006 11:37 am
Rear Brake squeal woodysLT K1200LT 0 Feb 15th, 2006 1:22 pm
