PIAA 1100x Switch Power not needed w/ AutoSwitch?? - BMW Luxury Touring Community
post #1 of 4 Old Feb 13th, 2009, 8:50 pm Thread Starter
Hi...it's been a while since I've posted!
I just installed PIAA 1100x's and added the AutoSwitch Model 5NB on my 2001 K1200LT. Everything is working as advertised, the turn signal cancel button works great, as well as the PIAA lighted switch that came with the light kit.
My question is, do you need to leave the PIAA lighted switch connected or can it be removed completely once the Autoswitch is installed?
The reason I ask is because I just realized that if the PIAA lighted switch (3 pin connector) is removed then the Autoswitch & turn signal cancel button continue to control the lights...which is great!
Second, I disconnected the 12v power source from the PIAA lighted switch, the Autoswitch & turn signal cancel button function & the lights continue to work. It seems to me that there's no need to have two switches or two power sources wired when one of each will do the job?
I'm my missing something here...any thoughts or suggestions?
Jose
cjgonzo1 is offline
post #2 of 4 Old Feb 14th, 2009, 6:21 am
bowlesj's Avatar
Re: PIAA 1100x Switch Power not needed w/ AutoSwitch??
Jose
Yes, you're correct Jose. No need for the extra switch. Actually just one more thing to muck up your trouble shooting if you do have a problem in the future.
2004 - LT - Anthracite
bowlesj is offline
post #3 of 4 Old Feb 14th, 2009, 12:50 pm Thread Starter
Thanks John...that will make the job easier to finish wiring!
Jose Gonzalez
2001 K1200LT
cjgonzo1 is offline
post #4 of 4 Old Feb 14th, 2009, 4:43 pm
dmatson's Avatar
Less clutter! Thats whats so great about the Autoswitch.
14' KTM 1190
03' KTM 450 EXC Dually
72' Honda SL 100
67' Triumph Bonneville
65' Honda CB160
70' Honda CB350
dmatson is offline
Motolights + Autoswitch install tiedend Lighting 6 Jul 7th, 2009 11:30 am
Need Help With PIAA 1100X with Auto Switch eharris Lighting 6 Jul 16th, 2006 2:13 am
Piaa 1100x zippy_gg Lighting 19 Jan 24th, 2006 3:46 pm
Oops, I let out the magic smoke jkersh1 K1200LT 4 Oct 27th, 2005 9:36 pm
Wiring instructions for PIAA 1100X ez-mount EncoreJoe K1200LT 4 Oct 2nd, 2005 10:41 am
