What kind of Radio is this? - BMW Luxury Touring Community
post #1 of 3 Old Feb 12th, 2009, 8:38 pm Thread Starter
davidpweis's Avatar
Hi ; Sorry if this is in the wrong area.
What kind of radio does the 08 and 09 LT have? Is there a serial number, does it have an amplifier, or is it one piece unit?
I'm really trying to find out if it has some form of pre-amp out on it?
I've already figured out the 'inbound sound' part, and now I'm trying to see how I can route the sound outbound...;-)
Thanks so much
David
davidpweis is offline
post #2 of 3 Old Feb 12th, 2009, 10:37 pm
Re: What kind of Radio is this?
There is but it is a waist of time as there is no control over Bass and Treble and I found it noisey. I ended up tapping into the speaker leads for better audio.
The radio has a main unit (single CD and the Amps/RF section) and a controller (under the push buttons) as well as the Ibus driven display in the dash. Made by Becker
But here are the pinouts from the small connector at the back of the main unit:
1 AUX audio out, right channel
2 NC
3 AUX out Gnd
4 -- audio ground
5 NC
6 AUX audio out, left channel
7 -- power ground
8 -- AUX audio in, right channel
9 -- AUX audio in, left channel
10 -- +12V power -- controlled by radio ON button
You can build a tie in from a standard double row 0.100 header socket. The pins are numbered on the radio connector. This is the port that the VOICE II interfaces into the radio with so fif you have that this is occupied.
post #3 of 3 Old Feb 13th, 2009, 12:17 am Thread Starter
davidpweis's Avatar
Thanks! Know of any pics or the model number or where I can find the manual for the becker?
Thanks! again!
D
Radio Repair Update - When is the next LT ready? Vince_nj1 K1200LT 28 Oct 2nd, 2010 3:46 pm
Unusual Radio Issue on an '02 LTE ErnieA K1200LT 20 Feb 14th, 2009 11:12 am
Motorcycle Communicator radio jimmayor007 Intercom, CB, & 2-Way Radios 0 Dec 10th, 2007 5:46 pm
A New Radio Problem? RVB1019 K1200LT 7 Sep 3rd, 2007 7:55 pm
XM Radio merging with Sirius Radio Tomakazie Satellite Radio 11 Feb 21st, 2007 8:12 am
