Reverse Inoperable - BMW Luxury Touring Community
post #1 of 41 Old Feb 11th, 2009, 11:32 am Thread Starter
sully2028's Avatar
Reverse Inoperable
I recently tried to use my reverse and found that it will not work. When I put the selecter switch in reverse, the light comes on indicating that it is in reverse, and when I push the starter button, the bike does not move. I read on a post a year ago that the battery may be too weak to operate the reverse motor, but the battery is only 1-1/2 yrs old and I keep it on a trickle charge (Battery Tender) all the time. The leads I have gotten from previous posts are:
- weak battery?
- relay problem?
- loose wire above rear brake lever?
- bad transmission interlock switch?
- loose wire near the battery?
- bad reverse controller?
If anyone has had this problem or something similar please let me know. Thanks!
Dan Sullivan
2011 vStrom DL650
1999 K1200LTC
Hillsborough, NJ
sully2028 is offline
post #2 of 41 Old Feb 11th, 2009, 11:44 am
UncleMark's Avatar
Re: Reverse Inoperable
When the scooter is in reverse and you press the button, does it move at all? Does the engine speed increase when you press the button?
Sounds like a bad reverse circuit to me, not a battery problem. Had mine replace about 4k ago... No problems since...
Uncle Mark
BMW '06' 1200LT "Wild Blue"
BMWMOA Member #127457
Honda CX500 Custom - RIP '00'
"An intelligence agency that FEARS intelligence? Historically, not awesome." . . . From what movie?
UncleMark is offline
post #3 of 41 Old Feb 11th, 2009, 1:35 pm Thread Starter
sully2028's Avatar
Hey Uncle Mark,
Thanks for your reply.
When the scooter is in reverse and you press the button, does it move at all? NO Does the engine speed increase when you press the button? NO
When you say a "bad reverse circuit", would you know if that would be the relay switch? a reverse speed sensor (Clymer p 318)? reverse aid control unit (Clymer p 319)? Do u know what they replaced on your bike?
Thanks again,
Dan
Dan Sullivan
2011 vStrom DL650
1999 K1200LTC
Hillsborough, NJ
post #4 of 41 Old Feb 11th, 2009, 1:53 pm
UncleMark's Avatar
The unit they replaced on my scoot was the speed sensor. But from what I gather from your info, it sounds like it's the control unit, not the speed sensor.
Uncle Mark
post #5 of 41 Old Feb 11th, 2009, 2:42 pm
pozo_izquierdo's Avatar
Typical symptom of the speed sensor fault is that the bike moves few feet on reverse and then stops. Pressing again the button will make the bike move etc. Some people think this a safety feature...
Now in this case the reverse seems to be totally dead so I would not start looking at the speed sensor first. Could be the reverse relay in the electric box under the gas tank or then the big reverse controller under the seat on the left side of the bike.
Regards
Hyvinkää, Finland
pozo_izquierdo is offline
post #6 of 41 Old Feb 11th, 2009, 4:34 pm
Steve_R's Avatar
I'm going to ask what sounds like a dumb question but from your post it's not clear. You do have the engine running when trying to back up don't you? A low battery will have nothing to do with reverse, an engine not running will or an engine running and not in neutral.
BTW, you wouldn't be the first one to make that mistake.
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
post #7 of 41 Old Feb 11th, 2009, 5:39 pm
I think that if he moved the reverse lever to reverse it had to be in neutral. It is interlocked, so you cannot move it if not in neutral, and you cannot shift the transmission out of neutral if the lever is not moved back to forward. Correct me if I am wrong, unfortunately, no bike in the garage, so I work from memory, and that is not what it used to be.
post #8 of 41 Old Feb 11th, 2009, 8:00 pm Thread Starter
sully2028's Avatar
Steve and Dave,
Yes, thanks for your replys. YES, I have the enggine running, in neutral. I flip the reverse switch (near shift pedal) and the "R" light comes on at the dashboard. Then when I press the starter button to activate reverse, nothing happens.
At this point I dont think it s the battery, but either the controller (to the rear of the battery) or the reverse relay (under the gas tank). Next step is to figure out how I can pinpoint which one it is.
THANKS Again to everybody for your input!!
Dan Sullivan
2011 vStrom DL650
1999 K1200LTC
Hillsborough, NJ
post #9 of 41 Old Feb 12th, 2009, 1:24 am
Are you sure that all the wires to the battery are hooked up? I understood that a separate positive cable actually powered reverse. Good luck
bmwstve
Silver 02 K1200LTE
Black 88 K75
bmwstve is offline
post #10 of 41 Old Feb 12th, 2009, 7:51 am
kellenbenz's Avatar
Another possibility is the switch on the sidestand....sidestand must be up before backing.
Ron
IBA 45658 MOA167437
Total BMW miles 509,508
Goldwing miles 238,383
kellenbenz is offline
post #11 of 41 Old Feb 12th, 2009, 8:18 am
Could be a switch, as already mentioned, or a fuse. According to the schematic, it is fuse 4, lower fuse in the block on the right side of the bike.
There are several inputs to the control box, Motronic relay, side stand switch, clutch switch, starter and emercency stop switches, and the neutral safety switch.
If you do determine it is the control box, I have one I purchased as a spare and never needed it. I will sell it for $400. It includes all the cables. New one is $1300!
post #12 of 41 Old Feb 12th, 2009, 12:51 pm Thread Starter
sully2028's Avatar
Hi all again!
Much thanks for your suggestions.
Stve - I checked the battery connections again. Nothing different from when the reverse did work. But no harm to have another look at them.
Ron - Yea I had the side stand up while the bike was in neutral. Still no reverse.
Dave - Didn't know a fuse could be involved. I will check wiring diagram as well. But the fuse you mention is OK. Actually I checked them all. Thanks on your offer re the control box, sounds like a good deal, but I need to determine first if that's the problem. Will get back to ya.
Will keep "youse guys" (I am originally from Brooklyn) posted.
Dan Sullivan
2011 vStrom DL650
1999 K1200LTC
Hillsborough, NJ
post #13 of 41 Old Feb 12th, 2009, 6:45 pm
madmanmike's Avatar
I just had mine fixed, same symptom exactly. We replaced the reverse controller with a used unit. LTparts.com has a couple right now.
Mike Riley
'03 Graphite Met
AMA, IBA
madmanmike is offline
post #14 of 41 Old Feb 13th, 2009, 10:04 am
ibbones's Avatar
My reverse has been out for almost two years now. It does the same thing as yours does. "R" light on the dash comes on and press the button and nothing happens.
I am not too worries as I live in South Texas and it is flat everywhere we go. But it would be nice to have it.
"BONES" <///><
2018 R1200RT
2002 K1200LTC--- Belle
ibbones is offline
post #15 of 41 Old Feb 21st, 2009, 7:51 pm Thread Starter
sully2028's Avatar
Hi All,
Thanks for your input re my Reverse Inoperable post. Have tried some things, and here is the update.
I replaced the reverse aide control unit (got a used but working one for $275) and that was not it!
I am checking the reverse gear (backup aid) switch (Clymer p 229) but dont know how to check if it is good or not. And replacing that is about $168. Do you know any way to test if it is OK?
Some mentioned the reverse relay in the electronics box. I checked Clymer and cannot find a "reverse" relay (Clymer p307-308). Could it be the Load relief relay (shown on the schematic, Clymer p 612)? For that matter, is there a way to check if the relay is working?
Final step will be to check the speed sensor (Clymer p. 318). That is $152. Again, does anyone know of a way to see if this is working or not?
Wow, this stuff gets expensive after a while. I hate just replacing everything by trial and error. Maybe I will follow ibbones example and just ride w/o a reverse!
THANKS AGAIN to everybody for your help!
Dan Sullivan
2011 vStrom DL650
1999 K1200LTC
Hillsborough, NJ
post #16 of 41 Old Feb 21st, 2009, 10:56 pm
The reverse relay is inside the controller and there is a large (10mm) black wire that ties into the starter terminal block behind the battery. There should also be a large red that goes to the battery "+" and a large brown that goes to battery "-" or the "-" terminal block. Note that the large wires may be Black with a yellow stripe on some controllers. In that case they should be marked where they go.
One question you were not asked was what does the "R" light do when you press the starter? Does it blink or stay steady?
post #17 of 41 Old Feb 22nd, 2009, 2:23 am
Originally Posted by sully2028
Hi All,
Dan,
sorry to hear about your persistent reverser problem. I reply to your PM public as others might find it useful as well...
My experience of the reverser problems is limited to the more common symptoms: reverse working but then stopping after few seconds.
I was able to watch my technician at the dealership working on this issue back in 2005 (bike was under warranty). Now looking back he was using a trial / erroe method rather than really having any big experience on the issue.
Anyway, he started by going into the main electronics box under the gas tank. There is a relay (which I personally don't know what it is for exactly) that he changed since "he had once done it to another bike". This did not help.
As the second trial he changed the big control unit. This did not help either.
As this was my second visit to dealer because of the same problem we agreed that the third attempt will be done by myself. (I had already learned from this forum about the speed sensor.) So he gave me one as we agreed that I will change it myself during my winter projects. And this solved it.
Of course trying to solve the problem by trial and error is easy to do when the bike is under warranty. The technician can just order any parts he wishes and he even gets paid for his work by the factory...
I wonder if you have seen the posts on the reverser problems on the old LT site. For instance David Mack (aka beemerlt) wrote an extensive summary on the various reverser issues: (unfortunately the pictures have vanished somewhere...)
http://www.bmwlt.net/ubbthreads/show...e=&view=&sb=&o=
Ar far as checking a multi pin relay functioning you would probably need a diagram of the internal connections of the relay in order to be able to check it with a multimeter. I'm not much more of an electrician unfortunately...
Regards
Hyvinkää, Finland
post #18 of 41 Old Feb 22nd, 2009, 9:03 am
bowlesj's Avatar
Yes, I agree with others here and will emphasize that no reverse movement is NOT usually indicative of a bad speed sensor. However, it could be possible that if the sensor fails in an uncommon mode such as excess speed, the reverser may be shut off completely. Just haven't heard or seen that happen.
I know for a fact that if the speed sensor fails to complete the feedback loop to the controller due to failure, loose connector or broken wire, the reverser will fail in ALL circumstances by reversing a few feet and then stopping with a flashing R light. Keeps this in mind when trouble shooting. I think yours will be that relay, if it is not the controller.
The sensor can NOT be easily rang out with a meter. If you were getting some motion, I wouldn't hesitate to change it if the wiring was all good.
Good luck,
2004 - LT - Anthracite
bowlesj is offline
post #19 of 41 Old Feb 22nd, 2009, 5:23 pm Thread Starter
sully2028's Avatar
Hey John, thanks for your thoughts. I look forward to seeing you at the Spring Training Camp.
See attached photos. The Reverse Aid Control Unit (RACU) has the red wire to the battery + terminal. It has two black/yellow strip wires that go to the starter terminal block and - terminal block. I hooked these up identical to how they were hooked up with the old/existing RACU that I took out. Of course they also have two electrical plug connectors that hook up to counterparts in the wiring harness.
You say that the relay is INSIDE the RACU, so I would take that apart to replace it, yes? Since I replaced the entire RACU with a used unit that was working, however, I guess the relay is OK.
So I guess that leaves the reverse gear switch which I now have access to (see last photo) or the speed sensor switch. From other posts, I dont think it is the latter. BUT is there any way to test the reverse gear switch short of buying a new one?
And BTW, when I press the starter with the reverse light on, the light stays rock solid steady.
Name:	reverse aid control unit.JPG
ID:	21918   Click image for larger version
Name:	wires to starter.JPG
ID:	21919   Click image for larger version
Name:	wire to battery +.JPG
ID:	21920   Click image for larger version
Name:	control unit in bike.JPG
ID:	21921   Click image for larger version
Name:	wires to starter2.JPG
Name:	wires to starter3.JPG
ID:	21923   Click image for larger version
Name:	wires to starter4.JPG
ID:	21924   Click image for larger version
Name:	reverse gear switch in bike.JPG
ID:	21925   Click image for larger version
Name:	gear switch connector2.JPG
Dan Sullivan
2011 vStrom DL650
1999 K1200LTC
Hillsborough, NJ
post #20 of 41 Old Feb 22nd, 2009, 5:32 pm Thread Starter
sully2028's Avatar
Originally Posted by pozo_izquierdo
Dan,
Regards
Ari,
Great ideas. Thanks.
John Zeiler has indicated that the relay is inside the control box. I did not see one identified by Clymer to be located in the Electronics Box. Wonder if anyone else has thoughts here.
Dan Sullivan
2011 vStrom DL650
1999 K1200LTC
Hillsborough, NJ
post #21 of 41 Old Feb 22nd, 2009, 7:48 pm
I presume that the black/yellow with the brown sleeve went to the ground tie point? The other black yellow goes to the starter terminal block? Ok I looked at your photos and they appear correct. The naked black yellow goes to what looks to be a tie terminal but it does not look like the one on my bike.
I am looking at the diagrams to see if there is an easy way to test the two switches at the reverse knob.
Ok I looked at the diagram and the two switches can be checked for operation at the four pin connector. Pins 1 & 2 and 3 & 4 are the switch terminals. In the reverse position both should read open and in the forward position they should both read closed. This is a guess based on the diagram and I don't have access to the my bike until Wednesday afternoon when I get back from this business trip.
If nothing else we will figure it at Iron Horse in April.
post #22 of 41 Old Feb 23rd, 2009, 9:10 am Thread Starter
sully2028's Avatar
John,
OK great, I will check out what u suggest. Meanwhile, I'll put everything back together and see what we can figure out in April at Ironhorse.
I have used reverse about 3 times in the past 1-1/2 years so no big deal to ride without it!
Dan Sullivan
2011 vStrom DL650
1999 K1200LTC
Hillsborough, NJ
post #23 of 41 Old Sep 14th, 2009, 2:02 am
jvfowler's Avatar
May be a stupid question but didn't see it asked in the early posts anyway. You did have the side stand up didn't you? Wont work with side stand down.
Dell Bowling Green KY
2016 R1200RTW
2012 K1600GTL
2001 K1200LTI
jvfowler is offline
post #24 of 41 Old Sep 14th, 2009, 8:43 am
EzyMount's Avatar
I also have inoperable reverse, engaged I get a Flashing R Light. My dealer says it is an RPM Sensor, which is tied to this circuit ?
Jim Lawson 2016 R1200RT
Retired to NC !
EzyMount is offline
post #25 of 41 Old Sep 15th, 2009, 4:52 pm Thread Starter
sully2028's Avatar
Jim et al,
STILL haven't figured it out. Reverse is still inoperable. I will look into an RPM sensor, although at this point I am not sure what/where that is.
Thanks All!
Dan Sullivan
2011 vStrom DL650
1999 K1200LTC
Hillsborough, NJ
post #26 of 41 Old Mar 19th, 2010, 1:09 am
wrmoss's Avatar
Today, I noticed my 99 Lt doing this very thing. The reverse speed sensor sounds like it's at fault...attempting to locate the correct part number...is it #23007660180? Any help would be greatly appreciated.
Yes, this could be a hijack...
Wade
99 K-1200LT
wrmoss is offline
post #27 of 41 Old Mar 19th, 2010, 9:47 am
EzyMount's Avatar
My problem ended up being the Reverse Aid Control Unit (RACU)... Replaced Speed Sensor first, did not fix it. Tech tells me Trial & Error diagnostics required, as there are no fault codes generated for failures within this circuit ! I ended up eating the repairs, in order to sell my bike..
Retired to NC !
EzyMount is offline
post #28 of 41 Old Jun 29th, 2012, 4:06 pm
Sully- just wanted to give you a heart felt thanks for the pictures and info you put in this post about a K1200LT reverser not working. Your pictures saved the day for me! I had my bike all apart to change a rear main seal. When going back together, I was confused on where the reverser controller black/yellow stripe leads were to go. I put them both on the terminal near the rear spring. Symptom was nothing happened when I hit Reverse. I was not confident I was attaching these leads to the right places but the BMW schematics in their after sales electrical schematics were not clear either on where they should go. Your pics got me straightened out and now its working! Thank you so much for your efforts on this post! Sincerely Tom Garrett, Colorado Springs CO.
Kubeemer is offline
post #29 of 41 Old Jan 25th, 2013, 10:20 am
james216's Avatar
Where is this speed sensor located?
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is offline
post #30 of 41 Old Jan 25th, 2013, 10:24 am
james216's Avatar
What & where is ironhorse? Sorry.I'm a newbie.
I'm a 4 percenter.
james216 is offline
post #31 of 41 Old Jan 25th, 2013, 10:46 am
James - click here for the start of the thread regarding Ironhorse and Spring Training Camp. Ya'oughta go!!
post #32 of 41 Old Jan 25th, 2013, 7:56 pm
The speed sensor is located on the right side of the tranny behind the right foot peg plate (three bolts and it is off). When it goes bad you get reverse for about two feet and it quits and you have to release and hit the starter button again to move another two feet. Item #4
post #33 of 41 Old Jun 27th, 2013, 2:32 pm
Xsubmariner's Avatar
Thank You!!
I'm editing the above typos as you read this.
1999 Basalt Grey
Xsubmariner is offline
post #34 of 41 Old Oct 20th, 2013, 3:34 am
Richdude's Avatar
Sorry to drag up a 4 year old post, but was this problem ever solved?
Dan, my friend has the exact problem as you did with his 2007 (recently purchased with reverse still working). My 2008 works perfectly, so we can swap parts to try to pin it down, but that's a ton of work. It would be nice to find out if you found the solution.
One question......The reverser switch box (left side, near gear shift) has 4 leads according to Clymer, but there is no details of how those wires are switched when the knob is rotated. Are there 2 micro switches involved when the knob is set to reverse? Does anyone have a wiring diagram of inside that reverser switch box?
Rich
Richard Wright
'99 K1200LT Champagne(in Heidelberg)
'08 K1200LT Black
Richdude is offline
post #35 of 41 Old Oct 20th, 2013, 9:07 am
sailor's Avatar
Rich
A while ago, John (Jzeiler) has posted a reply on a method to check these 2 switches behind the knob. See this thread:
http://www.bmwlt.com/forums/showthread.php?t=57707
John (Montreal, CANADA)
sailor is offline
post #36 of 41 Old Oct 20th, 2013, 9:12 am
gbob's Avatar
Hello Richdude,
One of the micro switches is closed when not in rev , it makes the 12volt - (ground) wire for the starter relay. The other is a MoTronic imput.
Bob G
2011RT
1999LT sold , an missed by wife !
gbob is offline
post #37 of 41 Old Oct 20th, 2013, 5:42 pm
If the "R" comes on when you flip to reverse then the reverse part of the switch is OK. Often the reason for a dead reverse is the large (10.0mm) black/yellow wire with a red band on the terminal was left off the positive pot when changing a battery. (who puts a black wire on the positive??). the reverser controller has three black/yellow large wires. the one with the red bad goes to the positive post. The one with the Brown band goes to the negative tie point behind the battery (brake side). The one with the black band goes to the starter tie point behind the battery (shifter side).
Name:	Tie Points.JPG
post #38 of 41 Old Jul 13th, 2014, 10:53 am
jenkinskg's Avatar
I thought my reverse did not work.
I was wrong, I read enough and found some peaople saying motor must be running, put in rev, push starter.
Then it worked great!
I read a few people saying theirs worked with engine off, mine does not even try to work.
Also since rpm goes up while in rev, I think that is the designed way it does work.
jenkinskg is offline
post #39 of 41 Old Jul 13th, 2014, 4:15 pm
You are correct. The engine must be running for reverse to work.
post #40 of 41 Old Jul 22nd, 2014, 10:39 pm
Richdude's Avatar
Smile Re: Reverse Inoperable-Solved!!
I finally got arround to fixing my friends '07 K1200LT. The reverse stopped working a month after he bought it. I have an '08 so I planned to swap parts until I found the culprit.
1. His reverse switch tested OK. Forward position: only blk/grn connected to brown. Reverse position: only yel/wht connected to black.
2. His reverse speed sensor looked good, no wire cuts or pinches. Besides, bad speed sensor usually causes stops and start; not total reverse failure.
3. All lock out switches test fine. Kick stand switch, etc.
Only thing left is swapping out the reverse control unit. It has 2 multiwire barrel connectors under the rear seat. One looked connected but was NOT seated and locked. THAT WAS IT! He must have open it while installing farkels shortly after he got the bike and didn't reseat it.
Richard Wright
'08 K1200LT Black
Richdude is offline
post #41 of 41 Old Jul 23rd, 2014, 10:53 pm
Often people will pull those by mistake when removing the top case.
Beware of reverse nplenzick K1200LT 1 Oct 31st, 2008 11:06 am
Update: Radio pause & reverse not working ArthurKnowles K1200LT 6 Apr 17th, 2008 10:29 am
Reverse Inoperative JosephFry K1200LT 10 Aug 22nd, 2007 5:53 pm
Technique/effort to engage Reverse? juggler K1200LT 4 Jan 14th, 2007 6:22 pm
LT Reverse distance Hitman_LT K1200LT 10 Dec 30th, 2005 11:39 pm
