Me thinks me screwed up - BMW Luxury Touring Community
post #1 of 8 Old Feb 9th, 2009, 7:45 pm Thread Starter
joevano's Avatar
I pulled the intake cam to swap two buckets and then could not get the sprocket back on. I think I may have turned the crankshaft when I turned the exhaust cam to try to get slack in the chain for the intake sprocket.
The pistons are not equally deep from the head, so I guess that means I turned the crank?
At this point, do I need to pull the timing cover off and time it all from the crank?
Joe Van Orsdol
Zimmerman Mn
'02 K1200LT
'94 K75S for sale
'11 DR650 Alaska Bike
'13 KTM 250XCW
joevano is offline
post #2 of 8 Old Feb 9th, 2009, 8:41 pm
grifscoots's Avatar
Re: Me thinks me screwed up
Put the bottom sprocket on the bottom cam. Take your wrench and turn the bottom cam upwards. This will give you enough slack to put the top sprocket on. You may have to turn the top cam to align the key to the top sprocket. (I've done 14 valve adjustments)
-=grif=-
Grok
grifscoots is offline
post #3 of 8 Old Feb 9th, 2009, 8:46 pm Thread Starter
joevano's Avatar
Thanks, that worked great.
In reading the manual, and assuming I started with the pistons in the correct position being midway through their stroke (my interpretation of the manual ), they are not all midway through their stroke at this point.
How can I be sure I have not gotten the cams out of time with the crank without removing the timing cover to check.
Is this an "interference engine"?
Joe Van Orsdol
Zimmerman Mn
'02 K1200LT
'94 K75S for sale
'13 KTM 250XCW
joevano is offline
post #4 of 8 Old Feb 9th, 2009, 8:50 pm
JPSpen's Avatar
As long as you haven't jumped any teeth you're fine..
Just rotate the intake camshaft to match the sprocket..Bolt her up..
If you rotated the lower camshaft upwards then you haven't screwed up..
you can fer sure turn the motor from there.
Stop panic...Breath deeply...
Finish bike..
Ride bike.
Good Luck
91 R100GS "It'sNotAMoneyPit"
JPSpen is offline
post #5 of 8 Old Feb 9th, 2009, 10:21 pm
grifscoots's Avatar
What he said. I always measure the valve gap after adjustment and before I put the bike back together. Murphy and all that.
-=grif=-
Grok
post #6 of 8 Old Feb 9th, 2009, 10:27 pm Thread Starter
joevano's Avatar
Got her back together but the swap did not work. I've got one intake at .05 so I guess I'll have to get a micrometer and order a new bucket!
Fun learning experience though!!
Joe Van Orsdol
Zimmerman Mn
'02 K1200LT
'94 K75S for sale
'13 KTM 250XCW
joevano is offline
post #7 of 8 Old Feb 10th, 2009, 10:07 am
JPSpen's Avatar
Nuthin' like doin' it twice... Good for practice and confidence..
JPSpen is offline
post #8 of 8 Old Feb 10th, 2009, 11:51 am
If the chain was Ty-wrapped to the sprockets, you will not have the engine out of time. The chain cannot come off the crank sprocket due to the close clearance, so that is not an issue.
The only thing I have seen a couple of times is that someone thought the sprocket was on correctly when it was not over the timing pin yet, and when they tightened the sprocket bolts they sheared part of the pin and broached out the sprocket hole. That will throw the timing off a little bit.
Ways To Describe An Idiot Lonewuff Humor 23 Sep 26th, 2013 3:23 pm
Am I screwed? Lost torx head sonnata Other K-Bikes Discussion 12 Oct 25th, 2009 12:47 pm
This time I got screwed! drew0570 K1200LT 18 Sep 30th, 2008 2:42 pm
ESPN's Gregg Easterbrook think's we're all morons for riding motorcycles eljeffe Bike Talk 33 Aug 29th, 2006 2:06 pm
