Reinstalling intake cam problem. - BMW Luxury Touring Community
post #1 of 4 Old Feb 8th, 2009, 1:21 pm Thread Starter
joevano's Avatar
I removed the intake cam to swap a couple buckets and can't get the sprocket back on the cam. I tied the chain to the sprockets and have not turned the engine.
The sprocket for the intake cam needs to come up and out about 1/4" to go on the end of the cam and I can't get it there. I've run a long wire tie through the sprocket to pull on but there is no slack in the chain to get there.
I assume the cam needs to be installed first and then attach the sprocket whick i have done.
Help!!!
Joe Van Orsdol
Zimmerman Mn
'02 K1200LT
'94 K75S for sale
'11 DR650 Alaska Bike
'13 KTM 250XCW
joevano is offline
post #2 of 4 Old Feb 8th, 2009, 2:04 pm
dmatson's Avatar
Re: Reinstalling intake cam problem.
When I swapped cam gears on my 05' i had this problem even though I had the 1/8" drill bit in the tensioner. What i did was take a long flat scew driver and push down on the inside of the cam chain and that made enough slack to get it back on, it didn't need much either.
14' KTM 1190
03' KTM 450 EXC Dually
72' Honda SL 100
67' Triumph Bonneville
65' Honda CB160
70' Honda CB350
dmatson is offline
post #3 of 4 Old Feb 8th, 2009, 4:59 pm
Joe,
The cam chain tensioner will eventually give you the slack you need. Just keep a firm easy pressure on the gear, and she will slide on as it bleeds down. You did tie the cain to the lower spocket as well I hope? Another trick is to put your 19 mm wrench on the lower cam and rotate it to get the slack you need. (Rotate the wrench UP).
post #4 of 4 Old Feb 8th, 2009, 5:13 pm
grifscoots's Avatar
Take the wrench to the bottom cam and move it till the top sprocket will go on. Voila! Problem solved.
-=grif=-
Grok
grifscoots is offline
Radio Problem fixed thanks to the HoW... lhamonic K1200LT 8 Oct 20th, 2016 12:30 pm
Very strange electrical problem starvingdrummer K1200LT 10 May 21st, 2008 11:17 am
Could my '05 center stand problem be this simple? mrbiker K1200LT 3 May 6th, 2008 9:17 pm
Computer Problem Response Form Lonewuff Humor 3 Mar 14th, 2008 4:53 pm
Problem with a BMW car - Am I being unreasonable? DanDiver Chit Chat 8 Dec 20th, 2007 12:51 pm
