Rear wheel gremlin.... - BMW Luxury Touring Community
post #1 of 6 Old Feb 8th, 2009, 9:17 am Thread Starter
Cochinosucio's Avatar
Question.....
While the Grey Goose is on her center stand warming up, engine at idle, in neutral, the rear wheel starts to rotate.....
Clutch on the way out?
"You can tell more about a person by what he says about others than you can by what others say about him."
Leo Aikman
Remember folks, street lights timed for 35 mph are also timed for 70 mph. ~Jim Samuels
Current Love
2001 K1200LT Champagne (Roxy)
Previous loves...
2000 K1200LT Canyon Red (Suzie Q)
1986 Honda Interceptor Black (Weezy)
1999 K1200LT Graphite (Grey Goose)
Cochinosucio is offline
post #2 of 6 Old Feb 8th, 2009, 9:21 am Thread Starter
Re: Rear wheel gremlin....
Nevermind..... Finally found on similar thread..... Needs to warm up.....
Thanks anyway!
Leo Aikman
Current Love
Previous loves...
post #3 of 6 Old Feb 8th, 2009, 9:21 am
motorman587's Avatar
No, all bikes will do that, put your foot on the rear tire and it will stop with no pull. Why they do that I have not idea, engine vibration is my guess.
Florida
2004 BMW R1150R Black
motorman587 is offline
post #4 of 6 Old Feb 8th, 2009, 9:38 am
My 06 LT always does the same thing. When it gets warmed up it rotates slower. After riding awhile and stopping (fuel stop) and restarting on centerstand...no rotation.
Why? Beats the Beemer out of me. Enjoy your Florida weather. 35 plus inches of snow here at the HEMAN Clubhouse!
v/r
Sereman is offline
post #5 of 6 Old Feb 8th, 2009, 12:01 pm
deanwoolsey's Avatar
The rear wheel rotation is caused by the viscosity of the transmission gear oil. While the drive splines are not engaged with the transmission in neutral, a small amount of force is transmitted to the drive line because the space between the gears and drive splines is so small and all the gears turn the same direction. All manual transmissions will do this. For what it's worth, your gears are always meshed together and the splines select which gear engages the output shaft. Five gears are all attached to the input shaft and five gears float on the output shaft until the shift mechanism engages them one at a time. A five speed transmission has five input shaft gears meshed with five output shaft gears. On a manual transmission the grinding you hear if you miss a gear is actually the spline teeth grinding against the internal spline on the gear.
deanwoolsey is offline
post #6 of 6 Old Feb 8th, 2009, 12:14 pm
blueknightga6's Avatar
EXACTLY what Dean said. I had a 1983 Honda Shadow 500 that was shaft driven and did exactly the same thing until warm if it was on the center stand. Even my 1985 Kawasaki Z1000P police bike did the same thing if I put it on the centerstand and started it when cold. And that bike was chain driven! Since the '88 Harley only had a side stand, I never found out if it did it.
Chris Ehlbeck
blueknightga6 is offline
What Size of Torx Bit for Rear Wheel Bolts? BCVBeck RT Series 23 Sep 21st, 2013 2:06 pm
Lose rear wheel lugs! Wootzman Dealer Experiences 6 Nov 16th, 2012 10:45 pm
Rear wheel spins in neutral on center stand pdawson K1200LT 4 Oct 10th, 2008 6:15 pm
Leaky rear wheel? Voyager K1200LT 4 Aug 31st, 2008 7:33 pm
Rear Wheel Removal Help Needed oldschool78 K1200LT 17 Jan 21st, 2006 10:30 pm
