Where to get BMW style elect connectors - BMW Luxury Touring Community
post #1 of 8 Old Feb 4th, 2009, 9:47 pm Thread Starter
Yamadog's Avatar
Do I have to go to the dealer to get new connectors that match the wiring harness? The application is a 2000 LT. I am going to upgrade the audio, & adding GPS and intercom.
If you put the federal government in charge of the Sahara Desert, in 5 years there'd be a shortage of sand--Milton Friedman
Yamadog is offline
post #2 of 8 Old Feb 5th, 2009, 1:27 am
Some guy on the Interwebs
LodiHal's Avatar
Re: Where to get BMW style elect connectors
Check out our own Raffy's website, everything that you may need.
http://www.motogear4you.com/catalog/index.php?cPath=12
Hal
Lodi, California
If you aren't good for anything else, you can always serve as a bad example.
HDDC Posse
LodiHal is offline
post #3 of 8 Old Feb 5th, 2009, 6:47 am Thread Starter
Yamadog's Avatar
Thanks for the reply. What I looking for are the various connectors that are used in the factory harness. There are a few areas where I want to use or reuse points on the harness but I don't want to butcher it. If they are not available I'll use an aux fuse block.
Yamadog is offline
post #4 of 8 Old Feb 5th, 2009, 3:07 pm
They aren't easy to come by. I've found some of them through Amp Special Industries but getting them is a hassle. It requires an account with Amp and both minimum total and line item purchases. There are some retailers that carry Amp but they rarely have the connectors we need. To further complicate your effort Amp moved away from a 'Master' catalog due to the huge variety of connectors they manufacture to individual product line catalogs so coming up with part numbers is a major effort. If you want to get creative the pins you can buy from various suppliers for Amps circular and Molex style rectangular connectors are compatible with some of our connectors. I have modified similar connectors to work in a pinch.
mjordans2000 is offline
post #5 of 8 Old Feb 5th, 2009, 7:26 pm Thread Starter
Yamadog's Avatar
OK. That sums it up pretty much. I'll look for a harness from salvage to hack up.
Yamadog is offline
post #6 of 8 Old Feb 5th, 2009, 7:43 pm
gbob's Avatar
Hello Yamadog
Pinwall cycleparts on Ebay has an wiring harness for sale ,not cheep enough for me to cut for parts. I would try internet search for Allied Electronics and or Newark Electronics not sure if either one will sell without an account .
Bob G
gbob is offline
post #7 of 8 Old Feb 6th, 2009, 9:12 am
Bear-KLT's Avatar
Originally Posted by gbob
Hello Yamadog
Bob G
I may be wrong but im sure some BMW cars have simaler connectors on the harness.
Bear-KLT is offline
post #8 of 8 Old Feb 8th, 2009, 3:50 pm Thread Starter
Yamadog's Avatar
I walked into the local electronics supply house and walked right to the AMP connector I was looking for...it was the only one they had and had been opened and resealed...I guess it was meant to be. I went ahead and ordered a Centech fuse block with a total of 5 ATC fuses. 3 are switched to ignition through a 30amp relay and 2 are direct to the battery for full time use. Thanks to everyone for your suggestions
http://www.cyclegadgets.com/Products...t.asp?Item=CEN
Yamadog is offline
Final Drive Failure - BMW ON Nov. 2008 WildBil Bike Talk 65 Jan 6th, 2011 7:26 pm
Bmw Mc Training Courses BTSOOM Bike Talk 7 Mar 30th, 2009 1:40 pm
2 More Police Dept Go To Bmw BTSOOM Bike Talk 1 Oct 4th, 2007 8:00 pm
