'05 Radio Aux Input - BMW Luxury Touring Community
post #1 of 24 Old Feb 2nd, 2009, 12:13 pm Thread Starter
mtdey1's Avatar
'05 Radio Aux Input
Just returned the LT ranks this weekend with a lightly used 2005. I'm looking for a way to input my MP3 into the stereo system. My 2000 LT had a cassette so the adapter was a no-brainer. Since this one has a CD in dash, I've lost that option. I did notice that the stereo selector pages through an auxiliary or accessory port. I've looked through the "Halls of Wisdom" and searched the threads but may not be using the proper search terms. Help please...
Mark
mtdey1 is offline
post #2 of 24 Old Feb 2nd, 2009, 12:23 pm
Turbocat's Avatar
Re: '05 Radio Aux Input
try this:
http://www.bmwlt.com/forums/showpost...24&postcount=1
Turbocat is offline
post #3 of 24 Old Feb 2nd, 2009, 12:30 pm Thread Starter
mtdey1's Avatar
Perfect! Thanks.
2000 LT sold
2005 LT sold
2007 R1200GSA
St. Louis, MO
BMWMOA #147759
mtdey1 is offline
post #4 of 24 Old Feb 2nd, 2009, 12:53 pm
Old Dawg
scottydawg's Avatar
Does your new LT have the Voice II system?
Scott
Sacramento CA
HDDC Posse
''03 Ducati ST4S with ABS - '12 KTM 500EXC - '19 BMW GS/A
(Jessica Focker's) '15 BMW S1000RR - '17 KTM 350EXC-F - '09 Yamaha XT250
Some of the most asinine things people do are typically preceded by the two words "Watch this."
scottydawg is offline
post #5 of 24 Old Feb 2nd, 2009, 12:54 pm
A 3.5 mm connector with 2 male ends connects easily from the MP3 player to the Comm system's auxiliary input. It does not charge while playing nor does the player get controlled through the system (other than volume). Not elegant or "the final solution" but it works great from me. I call it the $6 solution (for the price of the cable).
wholland is offline
post #6 of 24 Old Feb 3rd, 2009, 2:17 am Thread Starter
mtdey1's Avatar
No comm system on the bike. I ordered the AUX input based on a 2002 525i radio per the first response to this thread by Turbocat. Looks like the best solution IMO but will involve removing the radio which I've done on my 2000 LT. No big deal. I'll be wiring my power cord for my Nuvi at that time as well which is also the source for my MP3.
Thanks for all the suggestions.
Mark
2000 LT sold
2005 LT sold
2007 R1200GSA
St. Louis, MO
BMWMOA #147759
mtdey1 is offline
post #7 of 24 Old Mar 16th, 2009, 5:05 pm Thread Starter
mtdey1's Avatar
Update...
Installed but ran into the same low output/input issue using this connection. I bought a cheap amp off eBay and cut it down to fit under the stingray. You'll need some basic electrical wiring skills to make the connections and to power the unit. I used a relay powered to the first detent on the ignition switch, same as the radio, so it can be on at the same time.
The amp I used is this one (see attached)
No way its 180 watts though...more like 10 watts per channel. Price is right and it fits nicely under the stingray above the radio.
2000 LT sold
2005 LT sold
2007 R1200GSA
St. Louis, MO
BMWMOA #147759
mtdey1 is offline
post #8 of 24 Old Mar 16th, 2009, 6:54 pm
Mark
Hey Man,
I also just bought an 05 LT and had the same question, half a day of intense research and I came up with two solutions but you need the 6 disc CD changer (or at least the harness) and trade from an MP3 to an IPOD. I found Dice Electronics courtesy of another inmate (thats what we call us on Adventure Rider), and a set-up from mp3yourcar.com (which I purchased).
Since our bikes have the same control and changer as the BMW 3 series sedan and the MINI Cooper so there are some plug and play solutions...If you have the IPOD, supposedly (sp) once installed you will have all of the functionality to search (and text, to a limited degree) and control the IPOD. I had a Sandisc MP3 player but I purchased a Nano for this, I should have all of the bits in three days and if you can wait that long I will provide a detailed report. If in the meantime your research finds a solution like this for non IPOD applications please let me know.
IronRey is offline
post #9 of 24 Old May 9th, 2009, 10:55 pm
PrimePower's Avatar
Could someone tell me where the aux input is exactly. Is it not accessible?
05 LT
Marine Engineering Officer
US Army
PrimePower is offline
post #10 of 24 Old May 10th, 2009, 10:57 am
No...you have to remove the plastic off..then the radio
5150 is offline
post #11 of 24 Old May 10th, 2009, 12:38 pm
PrimePower's Avatar
Not what I wanted to hear, but thanks.
05 LT
US Army
post #12 of 24 Old May 10th, 2009, 6:53 pm
just take your time....buy your aux cable first..you need to go to a bmw for cars...the part number#65120153501
5150 is offline
post #13 of 24 Old May 10th, 2009, 7:03 pm
PrimePower's Avatar
Thanks, I think though I will eventually add an amp to replace using the HU power (as the right rear speaker is out) and swap the cd changer for my zune. Will be later this year though as I am moving and won't have the equipment or time.
05 LT
US Army
post #14 of 24 Old May 11th, 2009, 9:40 pm
billr's Avatar
There is an aux input on the face of the radio in the oddments box. Buy a STEREO 1/8 cable with two male ends and plug one end into the AUX input and the other into a Boosteroo mini-amp that costs about $20.00. You will need this to boost the sound out of the iPod. Plug the Boosteroo cable into the Aux input of the Voice II and the music volume can be controlled by the handlebar control. You won't be able to change tunes by the handlebar control or see whats playing on the LCD display with this setup but if all you want is music while riding you don't have to tear the bike apart either. Some people have wired a twelve volt plug into the oddments box so the iPod will charge while riding.
Hope this helps,
Bill Reitz
Surf City, USA
'06 Storm Gray Metallic LT
billr is offline
post #15 of 24 Old May 12th, 2009, 5:44 am
PrimePower's Avatar
I'm sorry, but you could you give me a pic. I can't find it. Thanks
05 LT
US Army
post #16 of 24 Old May 12th, 2009, 11:48 am
Old Dawg
scottydawg's Avatar
>Bill there is only an Aux Input on the front if he has a VoiceII.
> Prime Power, If you don't have a VoiceII you will need to buy the mentioned part that 5150 put in his post or get an Aux input device (like a BlitzSafe for example) that takes the place of your CD changer.
Scott
Sacramento CA
HDDC Posse
post #17 of 24 Old May 12th, 2009, 12:40 pm
PrimePower's Avatar
I don't know what I have. I just bought the bike two weeks ago. I know it says aux and something else when I scroll through the menu. I would go look but it is pouring here and I rode it to work. I believe it might have it, but don't know.
05 LT
US Army
post #18 of 24 Old May 12th, 2009, 1:12 pm
Old Dawg
scottydawg's Avatar
Why don't you take a photo of whatever is in your oddments box and post it? A VoiceII is a communication system.
Scott
Sacramento CA
HDDC Posse
post #19 of 24 Old May 12th, 2009, 2:07 pm
PrimePower's Avatar
Got some time between the rain and it does say intercom after aux. However in the oddments box I only see the cd player. Where at in there is the aux input?
05 LT
US Army
post #20 of 24 Old May 12th, 2009, 5:20 pm
Unless you have the factory installed intercom there is no obvious AUX input. The cable mentioned above plugs into a port on the rear of the radio - the same port the factory intercom uses.
post #21 of 24 Old May 12th, 2009, 5:50 pm
PrimePower's Avatar
I believe I do have the factory installed intercom as it is an option when I scroll through the menu. Just can't find the port for it.
05 LT
US Army
post #22 of 24 Old May 12th, 2009, 5:53 pm
Bighopper's Avatar
If you do then the AUX port, Phone & GMRS inputs are to the right & above the CD slot.
BIGHOPPER (Phil)
BGB 602
2006 K1200LT Grey
1973 Norton Interstate
1965 Atlas 750
Bighopper is offline
post #23 of 24 Old May 12th, 2009, 11:06 pm
You can get the AUX to show up on the sceen with out having the factory intercom. If you do have the Voice II there will be an LED readout and big knob just above the CD slot.
post #24 of 24 Old May 13th, 2009, 7:15 am
PrimePower's Avatar
Well, guess I don't have it then. Thanks
05 LT
US Army
Installing Aux cable in Stingray graydude K1200LT 71 Oct 20th, 2014 11:09 am
BMW radio - AUX input? Deek Satellite Radio 6 Jul 13th, 2008 8:51 am
Select AUX input??? kflanigan Satellite Radio 3 Jun 20th, 2007 5:53 pm
Radio Aux input. Where is it??? kmcg K1200LT 9 May 5th, 2007 7:23 pm
Using Dice as AUX input - Keeps switching to Radio fitsman iPod/MP3 0 May 3rd, 2007 9:59 pm
