Jump Starting - BMW Luxury Touring Community
post #1 of 8 Old Feb 2nd, 2009, 10:32 am Thread Starter
Jump Starting
Is it safe to jump start a 99 LT? Bike has not been started in about 2 months. Still has some power from battery but not enough to turn her over. Are there anythings to be aware of when using jumper gables? Can I use my Nissan pickup as the jumper car? Thanks for any advice.
budzee is offline
post #2 of 8 Old Feb 2nd, 2009, 10:50 am
MattKas's Avatar
Re: Jump Starting
Yes, I have done it many times. You may have to get the battery fully charged with a charger though if Oddysse.
Matt Kas
"Riding Year around"
MattKas is offline
post #3 of 8 Old Feb 2nd, 2009, 11:08 am
Re: Jump Starting
Just be aware a common fault on low battery start attempts is the welding of the relay contacts due to the high current. When you jump or replace the battery and the contacts are welded - the starter will spin uncommanded.
If you don't get them unstuck it will melt the cables as the starter will run continuously. Often a tap on the starter button will free them up. Just be aware of the possibility.
post #4 of 8 Old Feb 2nd, 2009, 3:59 pm
Road_King's Avatar
Re: Jump Starting
...yep, jump starting is no problem at all. Just keep riding until it's fully charged.
If the bike sets idle for an extended amount of time, you should be using a Battery Tender. Definitely helps.
~George
It's the journey, not the destination.
2002 K1200LT-E "StratoLounger"
2000 Road King Classic "StratoKruzer"
Road_King is offline
post #5 of 8 Old Feb 2nd, 2009, 4:01 pm
Re: Jump Starting
You can use any 12 volt vehicle battery to jump the LT. Not an issue at all.
Just be sure to use the correct hookup procedure:
1- attach the positive lead to the LT positive battery terminal
2- attach the negative lead to the LT negative battery terminal (assuring that the clips on the other end of the jumper cables are not touching)
3- attach the positive lead to the donor vehicle battery positive terminal
4- attach the negative lead to a good solid ground, preferably on the engine of the donor vehicle, away from the battery.
5- start the donor vehicle
6- start the LT.
Unhook all the cables in the reverse order.
Normally, one would hook the negative lead to a good ground on the dead vehicle also, but this is not feasible on the LT.
You always hook up the last lead on either vehicle to ground away from the battery to avoid sparks near the battery. That can cause battery explosion from hydrogen gas buildup in the battery, especially dangerous on a recently discharged or freshly charged battery.
post #6 of 8 Old Feb 2nd, 2009, 4:16 pm
LarryP's Avatar
Re: Jump Starting
I carry a set of motorcycle jumper cables. Heavy duty, but small for easy storage
Warm & Safe Heated Clothing Sale- Lowest Prices!!
Contact Me.
LarryP is offline
post #7 of 8 Old Feb 3rd, 2009, 11:38 am
dukey33's Avatar
Re: Jump Starting
When jump starting a motorcycle from a car or truck, you should not need to start the donor vehicle at all. The battery alone will have more than enough power to start a bike. Even on the big LT.
-2000 K1200LT
dukey33 is offline
post #8 of 8 Old Feb 3rd, 2009, 12:47 pm
garry_kramer's Avatar
Re: Jump Starting
What do motorcycle these cables look like? Just a smaller version (smaller gage, smaller clips) of regular cables?
Garry
IBAID 26718
BMWMOA 117552
2012 RED KLR650
garry_kramer is offline
starting problems Michaeldale K1200LT 3 Feb 24th, 2008 5:26 pm
Hang on or Jump Off jniemuth K1200LT 20 May 22nd, 2007 2:15 pm
Jump starting the LT Offwego K1200LT 6 May 21st, 2007 8:48 pm
Starter cranked when jump starting? jrlakin K1200LT 3 Nov 28th, 2006 2:08 pm
Hard starting when hot bigbear K1200LT 11 Aug 14th, 2006 8:35 am
