Uh Oh! starter wizzing sprauge clutch sound - BMW Luxury Touring Community
post #1 of 8 Old Feb 1st, 2009, 3:41 pm Thread Starter
Yamadog's Avatar
Well, Got a great deal buying a 2008 K12 w/106 K on the clock. Knew I would have to deal with some maintenance related projects. I looked at Daves thread and how he solved it. I'm putting on the heat lamp now while I begin the tear down. Need to check the valves, replace the air and fuel filter and plugs. Drill weep hole check slave cyl bleed brakes. Wow I get to go buy a lift I'de rather ride...I need a Clymers if anybody's got one to sell.
If you put the federal government in charge of the Sahara Desert, in 5 years there'd be a shortage of sand--Milton Friedman
Yamadog is offline
post #2 of 8 Old Feb 1st, 2009, 7:06 pm
Re: Uh Oh! starter wizzing sprauge clutch sound
I removed the entire engine when I did mine, someone else has done it by dropping the transmission, removing the clutch, then removing the intermediate housing without dropping the engine out.
I would still drop the engine out if I had to do it again though. Considerably easier to do all the work with the engine sitting in front of you rather than on your back reaching up under the bike. Just my opinion though.
Just a little info for your future use, it is "sprag", not "sprauge".
These were invented decades ago by this company:
http://www.formsprag.com/
post #3 of 8 Old Feb 1st, 2009, 8:32 pm Thread Starter
Yamadog's Avatar
Oh thanks...thought Howard invented it Got the plastic off and put up where I wont be falling over it. Put the heat lamp to start warming it up, installed my GPS harness. Got an idea...soft face drift hammer...4 firm taps later I hear a "SPROING" Tried to start...no joy. Bumped the starter and tapped and Vroom! I'm going to see how frequently it occurs and enjoy denial for a while
Yamadog is offline
post #4 of 8 Old Feb 1st, 2009, 9:07 pm
Old Slow Guy in A Fast Car
katnapinn's Avatar
Originally Posted by Yamadog
Well, Got a great deal buying a 2008 K12 w/106 K on the clock. :
I just want to make sure read this right. A 2008 with 106,000 miles ??????
Stevie Shreeve
katnapinn is offline
post #5 of 8 Old Feb 1st, 2009, 9:29 pm Thread Starter
Yamadog's Avatar
Should read 2000 K1200LTI
Yamadog is offline
post #6 of 8 Old Feb 1st, 2009, 10:23 pm
Are you going to put some CD-2 in the crankcase?
2002 K1200LT
Sunderland is offline
post #7 of 8 Old Feb 1st, 2009, 11:21 pm Thread Starter
Yamadog's Avatar
CD-2 goes in tomorrow.
Yamadog is offline
post #8 of 8 Old Feb 2nd, 2009, 6:37 am
murray's Avatar
Smile Re: Uh Oh! starter wizzing sprauge clutch sound
Well if you had a Handy lift you would not be on your back.
I bet less time is spent pulling the intermediate case with the engine in the frame. Also much less hardware to remove. Just my experience, BTDT.
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
latest clutch analysis cyclecamper K1200LT 17 Feb 27th, 2007 10:00 pm
Starter Sprag Clutch TimVipond K1200LT 3 Nov 17th, 2005 3:33 pm
