Odysse Battery - BMW Luxury Touring Community
post #1 of 7 Old Feb 1st, 2009, 4:10 am Thread Starter
mlempenau's Avatar
Odysse Battery
I have a two year old Odysee battery. I just added some PIAA lights and changed the air filter - checked the valves ... went for a ride to friends house and now bike will not start. There is enough juice to run the lights and fan but the engine will not turn over. When I jump it the battery wants to draw a lot of amps. More than it should. With the ignition off I attach the red side and then go to attach the black and get so much spark it wants to weld to the post. Yet I can leave the bike overnight with the alarm on and it will have the same amount of juice in the morning. I am assuming that this is a characteristic of dry cell batterys. Am I correct?
Michael L. Lempenau
85/41 Moo7, T.Nongjom, A.Sunsai
Chiang Mai, 50210, Thailand
mlempenau is offline
post #2 of 7 Old Feb 1st, 2009, 9:18 am
Re: Odysse Battery
That sounds like something is drawing a lot of current when the switch is off.
Not a battery problem. I would check the lights you put on.
beets is offline
post #3 of 7 Old Feb 1st, 2009, 9:28 am
Re: Odysse Battery
Disconnect the battery negative cable, connect the battery charger positive lead, then try connecting the charger negative lead to the battery and then negative cable. That will tell you where the high current draw is. If it sparks heavily on the battery, then this is the problem. If it is to the negative cable, then there is something wrong with the bike's electrical system.
post #4 of 7 Old Feb 1st, 2009, 9:30 am
patroa1's Avatar
Re: Odysse Battery
Mike, something is definitely wrong. I would disconnect the PIAA's and see if thats the problem. Also I would want to know way the fan is running, it should only run when engine temp. is up. I would just disconnect the lights you added and go from there.
Pat Rourke
White Lake,MI.
2002 K1200 LTC, Champange
patroa1 is offline
post #5 of 7 Old Feb 1st, 2009, 9:36 pm
MattKas's Avatar
Re: Odysse Battery
I had a similar issue: I completely drained the battery by forgetting my IPOD on. I started the bike by jumping from another. But from that point on I never had enough juice for more than two days: If I leave the bike unridden for two days it would not start on the third day. It is Odysse and about year and a half old. I finally called the Odysse. I was told to get the Odysee 6amp charger and charge it once month. The reason is that Odysse needs 14.7volt alternator system to fully charge the battery whereas most alternator systems in the market are 14.2 volts. This made sense to me. I should receive the charger some time this week.
Matt Kas
"Riding Year around"
MattKas is offline
post #6 of 7 Old Feb 2nd, 2009, 9:07 am
mallory's Avatar
Re: Odysse Battery
I'm on my second Odyssey (PC680). The first one died what seemed an instantaneous death. Was about two years old.
Mid summer-had taken a day-ride on a saturday. Put the bike up, came back to it the next saturday - wouldn't start. Battery was totally dead. N0 hint of problem when I put it away the week before.
I admit I neglected to have a routine charging regiment. I did use a Battery Tender Jr. to maintain during the winter months.
After some research, felt the best thing to do was purchase the Odyssey Ultimizer (6amp version). http://www.odysseyfactory.com/chargers.html
Could have been just a bad battery, but could have been due to neglect and inappropriate charging.
01 LT - Toscana Green
mallory is offline
post #7 of 7 Old Feb 3rd, 2009, 3:28 pm
Gino's Avatar
Re: Odysse Battery
I guess I'm lucky... Mine finally died just as suddenly (well, won't hold a charge over night) after 4 1/2 years... and I never used a charger on it unless I needed to, and even then I never used the Odyssey specific charger (used a Deltran Battery Tender, even though the Odyssey website says they can't charge a deep discharged battery). I would think that ANY charger capable of 14-15V would be OK for the battery, and at that, is only needed if the battery has been discharged significantly.
Funny is that Odyssey lists this battery as 8-12 years of operational life!
Again - lucky I guess (knocks on wood...)!!
Gino
Modesto, CA
'02 Silver
For they passed a noble law,
Gino is offline
My battery story. motorman587 K1200LT 3 Nov 26th, 2008 4:19 pm
'05 Lt Battery And Recharging With An Electronic Low Amps Tender ajs K1200LT 2 Apr 9th, 2007 11:11 am
Battery Concern please advise Hulkster Batteries, Chargers, & Electrical 8 Feb 6th, 2006 1:41 am
How NOT to treat your battery.... Zotter Batteries, Chargers, & Electrical 8 Nov 22nd, 2005 2:51 pm
