radio problems - BMW Luxury Touring Community
post #1 of 19 Old Jan 31st, 2009, 3:00 pm Thread Starter
radio problems
I just recently bought an 02 LT with a couple of problems that I was aware of. One was the brake lights flashing that I was able to fix by adding fluid to the rear resviore . the other problem is with the radio, the left channel isn't working. Is there anything I can try besides removing the battery cable for a few minutes?
bamarider is offline
post #2 of 19 Old Jan 31st, 2009, 5:00 pm
Bighopper's Avatar
Re: radio problems
Looks like a lot of message traffic on this issue. I see at the list below posted message.
I also so have seen this very good fix/replacement to the BMW factory radio, if you don't have any luck getting yours working this might be an option..
http://www.bmwlt.com/forums/showthread.php?t=43942
BIGHOPPER (Phil)
BGB 602
2006 K1200LT Grey
1973 Norton Interstate
1965 Atlas 750
Bighopper is offline
post #3 of 19 Old Jan 31st, 2009, 6:58 pm Thread Starter
Re: radio problems
yea i've read that tread and that's a great alternative if a simple fix won't repaire my radio. since i just got the bike i'm just not ready to dive into something that major. i've also read about some contacts that get corroided and can cause problems with the radio. don't know if that would apply to my problem nor do i remember where their located.
post #4 of 19 Old Jan 31st, 2009, 10:03 pm
Re: radio problems
The connectors for the speakers are under the tupperware on the left side under the stingray. There is another disconnect for the rear speakers under the pillion seat.
Some times you get lucky cleaning up and greasing the connectors. But there have been several radios where one of the amplifier chips has gone bad. The "disconnect the battery" trick is usually for complete radio faults as it is essentially a "reboot" of the radio's brain.
post #5 of 19 Old Feb 1st, 2009, 2:33 am
2002LTC's Avatar
Re: radio problems
am I pointing out the obvious by asking if you checked the balance setting?
2002LTC is offline
post #6 of 19 Old Feb 3rd, 2009, 3:13 pm Thread Starter
Re: radio problems
Yea i did check out the balance settings, I wish it could be that simple.
post #7 of 19 Old Feb 3rd, 2009, 3:35 pm
cccpastorjack's Avatar
Re: radio problems
Since you have checked the "balance" setting and it does not seem to be working, it is probably one of the power amps that has gone out. There really is no "easy" fix to this and it seems to be somewhat of a "common" problem with the LT. Sorry....
Jack Homesley
Cornelius, NC USA
Too many others to list...
cccpastorjack is offline
post #8 of 19 Old Feb 4th, 2009, 1:07 am
robasay's Avatar
Re: radio problems
You did not mention if both the front and rear left channel were out. I agree with John. Pull the upper tupperware and check and clean the connections. It is the round connections, twist them apart. apply contact cleaner and then reconnect to see if that is the trick. If it is then disconnect again and apply a little dielectric grease to the pins and reconnect. while your are at it remove the rear seat and clean and grease the far rear round connector as well. If all of that does not work then look at radio replacement.
Rob Asay
99 Canyon Red Lt
"The True Red Dragon"
1982 Honda "Silver Wing"
1986 Gold Wing Interstate "Blue Babe"
1978 Gold Wing
1976 Kawasaki 900
1967 Honda 305 Scrambler
robasay is offline
post #9 of 19 Old Feb 4th, 2009, 1:25 am
2002LTC's Avatar
Re: radio problems
sorry, but like me, you are finding out that there is nothing simple about any problem with an LT.
2002LTC is offline
post #10 of 19 Old Feb 4th, 2009, 8:54 pm Thread Starter
Re: radio problems
It is both the front and rear on the left side. I'll give the connections a try this weekend, but sounds like I'll be replacing a radio if I want to listen in stereo. thanks for all the help from everyone.
post #11 of 19 Old Feb 4th, 2009, 9:19 pm
Yamadog's Avatar
Re: radio problems
Hey I'm thinking of removing my factory radio - its working - to do the Jensen Marine Radio upgrade. Maybe you and I can help each other out. Mine is a 2000 so its the cassette/radio/cd changer. PM me if interested
If you put the federal government in charge of the Sahara Desert, in 5 years there'd be a shortage of sand--Milton Friedman
Yamadog is offline
post #12 of 19 Old Feb 5th, 2009, 1:24 am
2002LTC's Avatar
Re: radio problems
plus, have you tried to plug in a set of headphones to one of the output jacks to see if you hear stereo through the headphones. That might tell you if its the radio itself or a wiring problem.
2002LTC is offline
post #13 of 19 Old Feb 6th, 2009, 3:13 pm Thread Starter
Re: radio problems
didn't know I had output jacks. where are they located? like I said I just bought this bike so I've still got a lot to learn about the bike.
Thanks for the offer yamadog, but my radio has the cd player and I perfer to go that route.
post #14 of 19 Old Feb 8th, 2009, 3:58 pm
Yamadog's Avatar
Re: radio problems
What and miss out on the nostalgia of cassette tapes? All kiddin aside, I do miss my 1963 2 door Electra 225 with 8 track player and reverb...damn pleasant memories attached to that
Yamadog is offline
post #15 of 19 Old Feb 9th, 2009, 12:58 pm
2002LTC's Avatar
Re: radio problems
my 2002 K1200LTC has the headset connector right next to the computer on the left side of the front console. If you don't have a helmet with headset setup, find someone that does and see if you can hear both side that way. Remember there is a switch on the comSystem that selects headset or speakers.
2002LTC is offline
post #16 of 19 Old Feb 10th, 2009, 12:03 am
Walnetto's Avatar
Re: radio problems
Just finished up on installing my Autocom, Autoswitch, and some Aux lighting.
When I put everything back together, no extra screws, but all things being equal, the sound wasn't coming out. I re-checked my connections, everything seemed OK. I found out that the plugs just under the fairing forward of the left side of the stinger were seated, but not "snapped in". Make sure that you feel the "snap" when reconnecting.
At least I thought I was dancing, til someone stepped on my tongue.
2006 Graphite LT
Walnetto is offline
post #17 of 19 Old Feb 26th, 2009, 9:36 pm Thread Starter
Re: radio problems
I just received head sets for the autocom pro m1 that was installed on my bike, plugged them in and I'm getting music from both sides. The autocom looks to be tapped into the rear speakers, so if it's the radio or the connections I don't see how it would be playing thru the head sets. So if anyone has any ideas let me know.
post #18 of 19 Old Feb 27th, 2009, 3:39 am
grahamw's Avatar
Re: radio problems
You may have sound in both headset speakers but is it stereo? It could be that the Aitocom unit is managing to 'work' on one channel. Unplug the music from the Autocom and use something like this to connect a set of headphones.
Regards
Graham Wintersgill
2001 K1200LT
1995 K75RT now deceased
grahamw is offline
post #19 of 19 Old Feb 27th, 2009, 10:12 am
Re: radio problems
If the tap in is the one that includes a switch, then that may be the problem. Mine has become noisey and I have to flip it up and down to clear it. If is does not have a switch then I would pull the tape where it is connected and check that out.
Unusual Radio Issue on an '02 LTE ErnieA K1200LT 20 Feb 14th, 2009 11:12 am
Radio problems 05 LT wvubmw Intercom, CB, & 2-Way Radios 1 Jun 29th, 2008 3:02 pm
More radio problems bob1811 Bike Talk 0 Apr 27th, 2008 9:49 pm
Radio Problems Mr_Bill K1200LT 4 May 2nd, 2007 2:53 am
2001 Radio Problems magnet K1200LT 3 Dec 19th, 2006 6:47 pm
