speed odometer fix? - BMW Luxury Touring Community
post #1 of 8 Old Jan 25th, 2009, 8:36 pm Thread Starter
speed odometer fix?
While I am replacing the air filter and the antifreeze in my 2000 lt. I thought I might as well fix the error on my speed odometer. I used Randy Prade's directions and everything has gone well. I went to Radio Shack to get either a small wire jumper or a O ohm SMD resister. The two workers didn't know what I was talking about and couldn't find either one of these.
Where can I fine one of these and can a novice do the sodering or should I take it to a TV shop?
Carl
cw1200lt is offline
post #2 of 8 Old Jan 25th, 2009, 8:44 pm
Re: speed odometer fix?
Hi.
Wire jumper means a small thin (in this case) piece of wire. As I am not fully familiar with American wire diameters I hope I am not making a fool of myself for suggesting maybe a AWG 26 or higher cable
A 0 Ohm SMD (Surface Mounted Device) resistor is simply a conductor packaged in an SMD package. It does the same thing (0 ohm = wire)
Good luck
cyberphysicist is offline
post #3 of 8 Old Jan 25th, 2009, 8:46 pm
itspossible's Avatar
Carl,
I just finished the modification and used 1 strand of wire unwound from a braided electrical wire. One piece soldered in easily and the second piece ended up being a bridge of solder between the 2 points.
Its incredibly small and you need a steady hand, I haven't been able to test it yet but am expecting it will work. I also thought about having an electronics service store do the soldering but gave it a try, it wasn't too pretty.
good luck
Ron
2008 RT
2002 LT champagne
2003 Shadow
1986 Yamaha 500
1981 Honda Twinstar
itspossible is offline
post #4 of 8 Old Jan 25th, 2009, 9:25 pm
Carl
Soldering is fairly easy but until you get the feel of it I'd stay away from anything expensive. Under or overheating the component or circuit board can lead to damage or poor operation. Get yourself some wire and scrap circuit boards and practice first. The main trick is to heat the connection enough that the solder melts on contact. If you use the iron to melt the solder the wire itself may not be hot enough for the solder to flow across the connection resulting in an ugly 'cold' solder joint which can come apart or corrode. If you overheat the connection you can damage the component or cause the 'trace' (plated metal circuit path on the circuit board) to break or come loose from the board itself. Also, be sure you chose the right soldering iron for the job. Circuit board work is done with fairly low wattage pencil type irons. Keep that big high powered soldering gun in the draw unless you're trying to solder large wires or other items that obsorb a lot of heat before things are hot enough to solder.
mjordans2000 is offline
post #5 of 8 Old Jan 25th, 2009, 11:11 pm
BecketMa's Avatar
You want a low wattage iron.
I used a strand of wire from a scrap of stranded wire.
Tin the piece of wire, then cut it to length.
I had to use a lighted magnifier to see the solder pads.
I placed the wire where it should go and then held the iron ontop on the wire until the solder flowed. When I went to the other end of the wire, I got the solder to flow there, but, unfortunately, on the other end also.
I'm use to soldering on printed circuit boards.
Best from Tucson
BecketMa is offline
post #6 of 8 Old Jan 30th, 2009, 10:28 am
Carl
I'm new here and I have a 02 LT and wanting to fix my speed odometer error but can't find it in the search. Could someone give me the solution or the link. Thanks
Bimmerman is offline
post #7 of 8 Old Jan 30th, 2009, 12:08 pm
deanwoolsey's Avatar
Smile Re: speed odometer fix?
Here's a tip for soldering that I used. Set your PC board inside the corner of a metal work bench drawer which has sides taller than the PC board. Then you can steady your soldering iron on the drawer edge. The effect is similar to bench resting a rifle and makes the process much easier.
deanwoolsey is offline
post #8 of 8 Old Jan 30th, 2009, 1:16 pm
Select "Technical" at the top of the page followed by "FAQ", then "Common Issues" and the fourth one down refers to Speedometer. In there is another link to the article in the archives.
Speeeeeeeed. cfell Bike Talk 21 Nov 9th, 2008 9:16 pm
Section speed trap in The Netherlands vvk Europe 4 Apr 18th, 2006 4:40 am
Speed traps in The Netherlands vvk Chit Chat 0 Oct 24th, 2005 10:38 am
