Oil leak ? - BMW Luxury Touring Community
post #1 of 7 Old Jan 25th, 2009, 8:02 am Thread Starter
Question Oil leak ?
So yesterday while cleaning my 02 lt I noticed some oil on the tranny not on the ground
I run redline tranny fluid but this looks like engine oil
43,000 miles Is this the sign of a rear main seal gone bad ?
Or just road sludge.....
TrackAdaptor is offline
post #2 of 7 Old Jan 25th, 2009, 8:04 am
Steve_R's Avatar
Re: Oil leak ?
Not necessarily a rear main seal. I've got a couple of spots leaking right now. One on the valve cover and one on the water and oil pump cover. Valve cover is an easy fix, the water and oil pump cover is going to be a bear.
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
post #3 of 7 Old Jan 25th, 2009, 8:51 am
gbob's Avatar
Re: Oil leak ?
Hello TrackAdaptor
My 99 transmission has had a small leak somewhere up around the starter , I changed to non synthetic lube and now it has almost completely stopped ,does not drip enough to make it to the ground . I think the PO got an repair estimate and decided to lower the asking price and dump it cheep.
Bob G
gbob is offline
post #4 of 7 Old Jan 25th, 2009, 10:01 am
BecketMa's Avatar
Re: Oil leak ?
After seeing posts and pix here about drilling a drainage hole in the bell housing, I dropped the crash pan, drilled a small hole, and verified my oil leak is from the trany seal.
The only way I was able to get under the LT to drill the hole was to use a cordless drill and cut a drill bit down so that only about an inch of the bit protruded from the chuck.
To cut the bit, I but it in the drill, drill into a vice, put the drill into reverse and put the hack saw to it. I made a notch into the bit, and broke it off--easy.
Best from Tucson
BecketMa is offline
post #5 of 7 Old Jan 25th, 2009, 1:15 pm
Re: Oil leak ?
Mine was coming from the breather hoses on top of the engine... not dripping to the floor.
little_jake
little_jake is offline
post #6 of 7 Old Jan 25th, 2009, 3:43 pm Thread Starter
Re: Oil leak ?
little_jake
How can I locate this hose .... Pics are always good
post #7 of 7 Old Jan 25th, 2009, 6:39 pm
BecketMa's Avatar
Re: Oil leak ?
I scanned the LT section on "breather hose" and found this for you:
http://www.bmwlt.com/forums/showthre...=breather+hose
Best from Tucson
BecketMa is offline
First Solo Oil Change - Complete! hschisler K1200LT 40 Mar 14th, 2016 12:28 am
An Oil Man's View robasay Chit Chat 38 Jun 25th, 2009 8:28 am
$65 oil is coming (maybe) RTTommy Chit Chat 17 Oct 10th, 2008 9:43 am
Brake pads...oil leak itspossible K1200LT 2 Aug 30th, 2008 4:19 pm
Slow Oil Leak from Engine Drain Plug MattKas K1200LT 14 Jul 29th, 2008 12:20 pm
