White wire ? - PIAA project - BMW Luxury Touring Community
post #1 of 7 Old Jan 19th, 2009, 2:14 pm Thread Starter
Silverhair's Avatar
I'm in the home stretch on my PIAA 1100X project. Yea!
I've run all my wires under the tank.
On the PIAA harness, theres a switch power wire (thin gauge white wire) that I want/need to tap onto the positive side of the low beam. The instructions say "Find a power source to connect the switch power wire to.
I see a sub-harness connector going into the headlight housing. Is that the best place to tap into?
The botton white wire on that connector traces to the yellow wire running to the low beam lamp.
2005 Kawasaki Z750S
1999 BMW K1200LT
1972 Honda CL350
BMWMOA # 139202
Silverhair is offline
post #2 of 7 Old Jan 19th, 2009, 3:55 pm
Axle's Avatar
Re: White wire ? - PIAA project
I used the the power from the litttle front parking light globe to power my switch. key off no power to switch ensures the lights are not left on.
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #3 of 7 Old Jan 19th, 2009, 4:14 pm Thread Starter
Silverhair's Avatar
I'm about to do the same thing! Access seems easier that the low beam wire too.
Did you use one of these "PIAA one touch connectors?" It seems to be three parts joined as one piece of plastic. I understand how the wires lay in the connector bridge. I assume you separate the other two pieces on top of the bridge...
2005 Kawasaki Z750S
1999 BMW K1200LT
1972 Honda CL350
BMWMOA # 139202
post #4 of 7 Old Jan 19th, 2009, 4:41 pm Thread Starter
Silverhair's Avatar
I think I figured out the "PIAA one touch connector." One touch it ain't!
Pain in the butt to close it, but I got it done with the help of some needle nose pliers. It sort of folds on itself. Tapped off the little parking light. Good to keep options open.
It would help if PIAA did better with their directions...
2005 Kawasaki Z750S
1999 BMW K1200LT
1972 Honda CL350
BMWMOA # 139202
post #5 of 7 Old Jan 19th, 2009, 5:25 pm
grifscoots's Avatar
I'd take that "one touch connector" off, solder, shrink wrap and tape. Those connectors impinges the structural integrity of the wire and opens them up to the elements.
There's a reason you don't see a bike come out of the factory with them.
-=grif=-
Grok
grifscoots is offline
post #6 of 7 Old Jan 19th, 2009, 5:50 pm Thread Starter
Silverhair's Avatar
Good suggestion.
If this thing doesnt work, it'll be the first think I do!
2005 Kawasaki Z750S
1999 BMW K1200LT
1972 Honda CL350
BMWMOA # 139202
post #7 of 7 Old Jan 19th, 2009, 6:34 pm
Axle's Avatar
Grifs spot on that connector will eventually corrode and give you problems, at least they do here in the salty air
Regards Linton
2002 K1200LT
My Toys
1976 Datsun 260Z
Axle is offline
PIAA lights vs . . . (product review) Seattle Lighting 7 Jul 11th, 2009 2:13 pm
Another Dauntless wiring/relay question, need someone to look @ theirs! Rick-L Trailers, Sidecars, & Trikes 2 May 30th, 2008 2:31 am
55w piaa extreme white plus goober27 Lighting 4 Aug 11th, 2006 5:08 am
Piaa 910 wire to High Beam... Mike_the_Rat K1200LT 1 Oct 8th, 2005 7:22 am
