Where can I get a banjo bolt? - BMW Luxury Touring Community
post #1 of 5 Old Jan 18th, 2009, 9:33 pm Thread Starter
joevano's Avatar
I'm working on the K12RS but as it's the same part, I'll post here hoping to get a quicker response.
I rounded the banjo bolt on the shock adjuster trying to remove to add oil. The parts fiche says that I can't buy that part separate from the shock assembly. Can it be cross referenced to a brake or clutch banjo bolt?
Joe Van Orsdol
Zimmerman Mn
'02 K1200LT
'94 K75S for sale
'11 DR650 Alaska Bike
'13 KTM 250XCW
joevano is offline
post #2 of 5 Old Jan 18th, 2009, 10:58 pm
Re: Where can I get a banjo bolt?
That one is going to be tough Joe. Carefully cut a slot in it and use a large flat blade screw driver or file it down to the next wrench size (I have done desperate things like this before). May be able to find one at a shop the does hydraulic work.
post #3 of 5 Old Jan 19th, 2009, 10:55 am Thread Starter
joevano's Avatar
I'm sure I can get this one out, it's not too bad yet. More worried about replacing it. I find it interesting that you can get the bolts for the clutch system but not this one. I would think one of the other ones on the bike would work. I suppose I can take this one out and take it to the dealer to see if they have any of the other ones in stock to match.
Joe Van Orsdol
Zimmerman Mn
'02 K1200LT
'94 K75S for sale
'13 KTM 250XCW
joevano is offline
post #4 of 5 Old Jan 19th, 2009, 11:24 am
DanMartin's Avatar
you might try Spiegler
http://www.spieglerusa.com/cfm/BrakeAcc.cfm
dan
DanMartin is offline
post #5 of 5 Old Jan 19th, 2009, 11:36 am
My line leaked a little at the banjo bolt and I tried to find a replacement washer - dealer said none were offered within the system.
Still leaks a little.
Lee Nowell
Black 01, LTC
BMWRA & MOA, AMA, IBA
lnowell is offline
Banjo bolt part #34322331540 specs? BecketMa K1200LT 3 Sep 15th, 2008 8:30 pm
Today's Marathon, a banjo bolt BecketMa K1200LT 2 Sep 14th, 2008 9:39 pm
Marathon, front banjo bolt BecketMa K1200LT 0 Sep 14th, 2008 1:34 am
Shock bolt mounting BMWphreak K1200LT 4 Apr 18th, 2007 11:46 am
