Vandalised Antenna - BMW Luxury Touring Community
post #1 of 28 Old Jan 11th, 2009, 3:55 pm Thread Starter
Vandalised Antenna
One of my wonderful neighbours has snapped the top off my antenna. Part of the reason is the antenna tends to stick out and catch passers by.
Does anyone know of a short version of the antenna. Otherwise can the rod (long upright piece be bought seperately). Replacing with same will probably lead to a re-occurrence.
axamax is offline
post #2 of 28 Old Jan 11th, 2009, 4:03 pm
Ajlelectronics's Avatar
Re: Vandalised Antenna
Sorry to hear of that. I despise scumbags who do that sort of thing.
Have you tried Motorworks for a second hand one? It is listed as a seperate part but I bet it will not be cheap. One good point though is that the connection will be better, so you could just unclip the aerial from its base when parked. A shorter aerial will be a mismatch to the radio impedance wise, so will not work so well.
Just pussin' through.
Ajlelectronics is offline
post #3 of 28 Old Jan 11th, 2009, 4:14 pm Thread Starter
I notice motorworks seem to be listing a replacement used one at £10. But if I just replace it and neighbours get pissed off they may do something else to bike. Can't be doing with removing it all the time. If a short one is fitted will I be able to use an FM modulator with good results?
axamax is offline
post #4 of 28 Old Jan 11th, 2009, 5:37 pm
Get a VERY large friend to inform your neighbors that he will be VERY pissed if anything happens to your bike. It may help if the friend appears to be mentally un-balanced
Morley is offline
post #5 of 28 Old Jan 11th, 2009, 5:41 pm
pjessen's Avatar
http://www.crutchfield.com/p_12044UA...a.html?tp=3449
Pete Jessen
CCR 02, 03, 04, 08, 10
pjessen is offline
post #6 of 28 Old Jan 11th, 2009, 5:57 pm
sheldan2's Avatar
Talking Re: Vandalised Antenna
I wonder if they have ever had their windshield wipers superglued?
sheldan2 is offline
post #7 of 28 Old Jan 11th, 2009, 6:24 pm
It will only affect reception, not the modulator, assuming the modulator is hard wired inline. All I can say is suck it and see. With your new aerial, how about tying it back or putting a piece of hosepipe over it?
post #8 of 28 Old Jan 11th, 2009, 6:40 pm
I would suggest wiring 110V (make that 220 since you are, UK, right?) to the antenna next time you park your LT. I'm guessing after a few hits your neighbor will leave it alone!
post #9 of 28 Old Jan 11th, 2009, 8:04 pm
deanwoolsey's Avatar
I used to have a neighbor's dog that pissed on my Yamaha. Then I put a rubber pad under the kick stand and hooked a weed-burner electric fence charger to the wheel. I was lucky enough to see the result. It only happened once.
deanwoolsey is offline
post #10 of 28 Old Jan 11th, 2009, 8:54 pm
RonKMiller's Avatar
Allrighty then!
"Like Butt-ahh!"
RonKMiller is offline
post #11 of 28 Old Jan 11th, 2009, 8:57 pm
Forget the wipers...superglue in the door locks is a real B__ch!
Morley is offline
post #12 of 28 Old Jan 11th, 2009, 10:57 pm
Diehly's Avatar
Question Re: Vandalised Antenna
What am I missing here? Where are these passers by that they are getting caught? I want to avoid this situation in my neck of the woods. This is the first I have heard of this. Do you mean while it is parked or going down the road?
Diehly
Poke it through, tuck and roll
Diehly is offline
post #13 of 28 Old Jan 12th, 2009, 1:02 am
fpmlt's Avatar
Not trying to hijack here, but I did the same thing to my neighbors dog, only I used 110 right out of the wall. Steven King would have paid big bucks for the sounds that dog made.
fpmlt is offline
post #14 of 28 Old Jan 12th, 2009, 8:49 am
Shorter antenna will give you weaker reception - but you may not care, depends where you ride. Worth trying.
There are no impedance mismatch issues on a receiver; a coathanger works as well. You only worry about reflections (impedance mismatch) on a transmitter.
Just get anything that fits mechanically.
Robert in Northern NJ
rdwalker is offline
post #15 of 28 Old Jan 12th, 2009, 9:06 am
blueknightga6's Avatar
Now that's a good one!
Chris Ehlbeck
blueknightga6 is offline
post #16 of 28 Old Jan 12th, 2009, 12:38 pm
There may be no damage issues, but the impedance mismatch is WHY a shorter (mismatched) aerial will have poorer performance, ignoring the effective aperture issue.
post #17 of 28 Old Jan 12th, 2009, 3:18 pm Thread Starter
Bike is parked at about 60 degrees to the kerb, (back tyre against kerb) in a narrow street with a steep camber. Therefore the angle has to be chosen carefully. The bike needs to be parked tyre against the kerb. The Topcase and rear of the panniers overhangs the footpath (also narrow, about 4ft wide) and the antenna sticks out even further at approximately head height.
axamax is offline
post #18 of 28 Old Jan 12th, 2009, 3:24 pm Thread Starter
like the idea about the windshield wipers.
axamax is offline
post #19 of 28 Old Jan 12th, 2009, 3:41 pm
Here's a thought, why not swap the antenna to the other side? There is a CB antenna bracket that fits on the other side of the top case. You could use that base bracket but fit the standard radio antenna to it. Then the long antenna would hang out above the bike, not out over the sidewalk.
post #20 of 28 Old Jan 12th, 2009, 4:04 pm
It is possible to cut and modify the standard bracket to fit the other side, but I think the angle of dangle might need altering too. I used mine for a comms aerial so the problem didn't arise.
post #21 of 28 Old Jan 12th, 2009, 6:13 pm
Never looked into it myself when I had my LT but, is there a "Wing-like" antenna that folds down out of the way?
Uzirider is offline
post #22 of 28 Old Jan 12th, 2009, 6:15 pm
mwnahas's Avatar
Why not just bend it out of the way? Hook into the luggage rack, or remove it?
Just Go
Cleveland Ohio
mwnahas is offline
post #23 of 28 Old Jan 12th, 2009, 7:14 pm
Enjoy The Ride
saddleman's Avatar
I'm blind in one eye so I'm very conscience of things at eye level. I have a flag on the end of my antenna. If you have the rack you can do this.
Name:	bike teardown 003.jpg
ID:	21430   Click image for larger version
Name:	bike teardown 004.jpg
ID:	21431   Click image for larger version
Name:	bike teardown 005.jpg
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #24 of 28 Old Jan 12th, 2009, 8:40 pm
azredline's Avatar
This is a great idea! Would also make for easier bike covering. Anybody know of one?
Steve
Chandler, AZ
2000 BMW 1200LT
azredline is offline
post #25 of 28 Old Jan 13th, 2009, 10:24 am
RonKMiller's Avatar
NOW I get it!
I subscribe to the KISS principle - Keep It Simple Stupid.
Soooooo.... when you get off why not attach a small string to near the top of the antenna - and somewhere on the opposite side of the bike - and temporarily bend it over to vertical? And if you're concerned about the luggage cases intruding into the footpath a small scrap of wood left on the street should take care of that issue by changing the "lean" angle when parked on the side stand.
Someone is going to get an eye poked out.
"Like Butt-ahh!"
post #26 of 28 Old Jan 13th, 2009, 3:35 pm Thread Starter
I tried tucking it into the rack but the antenna was starting to split at the bend. Might have a look at the CB bracket though. Also want to look into the crutchfield aerial.
axamax is offline
post #27 of 28 Old Jan 13th, 2009, 8:07 pm
GlennM86's Avatar
I used a quick disconnect like this one my Jeep...mainly for low parking garages. http://www.bellscb.com/products/ante...sconnect.htmon
I switched over to a different kind of mount that lays the antenna down at 90 Deg (in any one direction of your choice).
Glenn
Iron Butt Membership # 45813
<By Motorcycle>
<By Car or Ship>
GlennM86 is offline
post #28 of 28 Old Jan 15th, 2009, 12:54 am
If you look in the Hall of Wisdom under Customization:
(m) Radio and Optional Extras you will find a sub heading of Antenna.
There are a couple of recommendations. The one I installed a couple of years ago was the one that Grif posted. The short flexible antenna. It has worked very well for me.
sbrown is offline
XM Antenna mount for Garmin 2730 RealWing Satellite Radio 3 Feb 28th, 2013 11:20 pm
FM radio antenna counterpoise PerfectSwitch RT Series 4 Jul 20th, 2008 9:39 pm
BMW CB Antenna Discovery -- Range-- GBaker Intercom, CB, & 2-Way Radios 3 Dec 6th, 2007 9:41 am
Instructions for Tuning the SWR on Your CB GBaker Intercom, CB, & 2-Way Radios 8 Nov 18th, 2007 12:49 pm
Antenna help Benzbuilder Intercom, CB, & 2-Way Radios 1 Mar 6th, 2007 9:54 pm
