Electrical turn signal question - BMW Luxury Touring Community
post #1 of 6 Old Jan 11th, 2009, 3:03 am Thread Starter
Cochinosucio's Avatar
Hiya Fellas,
When I use my turn signals, (both sides) they intermittently blink fast. The bulbs all work, I have cleaned and lubed all of the bulbs and sockets. Also, the auto cancellation on the turn signal doesn't work. Hmmmmmmm Any ideas?
"You can tell more about a person by what he says about others than you can by what others say about him."
Leo Aikman
Remember folks, street lights timed for 35 mph are also timed for 70 mph. ~Jim Samuels
Current Love
2001 K1200LT Champagne (Roxy)
Previous loves...
2000 K1200LT Canyon Red (Suzie Q)
1986 Honda Interceptor Black (Weezy)
1999 K1200LT Graphite (Grey Goose)
Cochinosucio is offline
post #2 of 6 Old Jan 11th, 2009, 9:50 am
deanwoolsey's Avatar
Re: Electrical turn signal question
Unless you've added one I don't think there is an auto cancel on the LT. Try pulling the plug on one of the front bulbs and see if the fast blink rate is the same as what you are getting on the road. If it is, trace the ground wires and check for a loose or corroded connection.
deanwoolsey is offline
post #3 of 6 Old Jan 11th, 2009, 10:39 am
Chockkicker's Avatar
My 2000 LT has auto cancel
Sonny
Chockkicker is offline
post #4 of 6 Old Jan 11th, 2009, 10:55 am
I stand corrected. It just seems like they're manual. With that in mind though it could be the control module if they were canceling properly before the intermittent blink started.
post #5 of 6 Old Jan 11th, 2009, 11:45 am
Have you changed the bulbs? A few years ago, I decided I was going to use and LED bulb for the turn signal lights. When I turned on the turn signal, they blinked fast and did not cancel. I took them out and put back in the incandencent bulbs, and it worked fine. Something about the load not being right. I don't really know the technical reason.
jrlakin is offline
post #6 of 6 Old Jan 11th, 2009, 6:17 pm
BMWROLLIN's Avatar
Smile Re: Electrical turn signal question
While somewhat quirky, the LT does have the self canceling feature and will be affected by standard LED replacements. There are LED bulbs that are made to emulate the load of standard incandescent bulbs so as to not affect the operation of the control module. If all bulbs are working and you havenít switched to LEDs, then the most likely source of your problem would be the control module. I am not an LT mechanic however and you may get some different thoughts by other forum members. Good luck resolving your issue.
BMWROLLIN is offline
Wings Of Gold (Turn Signal Question) Jimbo3 Lighting 14 Oct 17th, 2013 7:38 pm
Where to get to the turn cancel signal wire Bobnoxous K1200/1300GT (The Next Generation) 4 Oct 15th, 2008 1:26 am
Clear / smoke turn signal lens ... question motorhead K1200LT 14 Jun 12th, 2007 2:34 am
Clear or smoke turn signal on a champagne LT ? buffalo K1200LT 7 Jun 27th, 2006 8:40 pm
Wings Of Gold (turn signal saftey question) Jimbo3 K1200LT 1 Jan 16th, 2006 10:45 am
